A55 Smoothing Plane
Entry door
Entry door
Entry door
John B. Chicago burbs
Hello Guys and Gals, I wonder if you could help me with the design i have in mind for an entry door. The door will be 36" x 84", north facing set back in a large overhang, does not get direct sun. I plan to build it using 1 3/4" thick quartersawn white oak. There will be a raised panel about 45"x20" and an insulated glass lite at the top. Where i need your help is with the raised panel. I would like to build the panel with two 3/4" panels with a 1/4"foam panel (blue or pink) between them. The foam would be a tight fit in the dadoes, the white oak not so that they can float. Can i glue the oak to the foam with a single strip of glue running vertical? How wide do i make the dadoes for the oak foam sandwich. Thanks John B.
Re: Entry door
Re: Entry door
roger lance
John....3/4" dado should work....1/4" lip for each panel and 1/4" for the foam core....why glue the panels to the foam??....just free float all three....does the wide overhang prevent the current door from getting wet??....much weather coming at you from the North??....you might be lucky and the door not suffer from the elements very much....I guess I'd be concerned about wind/cold air getting in around the panels....something to consider....Norm Abram built an entry door on New Yankee Workshop that was expected to get weather perhaps that video is still available....good luck.
Re: Entry door
Re: Entry door
Roger the door does not really see any weather there is a full length glass panel storm door in front of the door. The foam will be a snug fit in the door and glue the wood to the foam only in the middle will i hope allow the wood to expand and contract with the weather. Thanks John B.
Re: Entry door
Re: Entry door
Keith Newton
It sounds like you should be OK. Even if your wood moves, the glue would probably just tear the face off the foam before it would stop the foam from moving, so don't start expecting something magic to happen.
Anytime you have solid wood, with any width, you should just count on it moving, and not fight it.
If you have a little extra space, and want to keep it from rattling, I would suggest using something really flexible between them, like silicone.
