We value your privacy.
I want to make several planter stands that use round tops. I have used a jig saw in the past, but there has to be a better way to get a clean, sharp edge without a lot of sanding. I'm looking at router, bandsaw, and table saw methods. Any special problems with any of these?
My FIL cuts circles on his table saw by drilling a hole in the table top at the desired radius away from the front edge of the blade. He then drops a bolt through the piece into the hole and raises the blade into the wood then slowly pivots the wood around the bolt. He takes several passes, raising the blade gradually.
I don't believe this to be a new method, as his FIL taught it to him.
I've never tried it myself, I've got a bandsaw and router, and just make a circle cutting jig/base for the router.
Perhaps it's just a mean trick the men in my wife's family have played on each other's son-in-laws for generations.
I think I'd clamp a piece of 3/4" plywood to the table top using some method to index it accurately (for reclamping), bring the sawblade up through it, then mark the plywood from there, remove it, and drill my hole in the plywood.
I'm otherwise picturing a tablesaw that looks like the cast iron termites got to it.
I`d use a bandsaw. It`s a very simple setup to do. You can also use the router, which is also a simple and easy to use. If you need help setting it up just let us know and I`d assume a lot of people can help. I`d explane it but it`s a little long for me to do right know. Larry
Larry, I've always had trouble with tracking when using a jig for band saw cuts (maybe I didn't use a sharp enough or quality enough blade). I eventually gave up and went with the sanding method.
I like the router method, I use a shop built jig similar to http://www.rockler.com/product.cfm?page=30473&filter=circle%20cutting%20jig . I you want a real nice edge you can cut the circle out a little large - say 1/8", then do your final cut with either the same bit (for a square edge) or use a roundover with the bearing removed.
I make circle cutting jigs for my router from 1/4" hardboard, plexiglass or thick plastic of some sort. While there is certainly nothing wrong with buying a circle-cutting router base from Rockler, I'm a cheap old bugger and prefer to make my own.
Yonak If you had trouble with the saw, then something was out of line. I have an OLD craftsman and I use to have trouble with it to. Then I went over the saw real good and got it lined up and fixed the blade guides and another thing, the point of your blade has to be right in line with your center point of your circle and as you said a good blade, what kind do you use. Now I get very good circles. What kind of saw do you have? Larry
Larry, the saw I used was either a Delta or an older-model Powermatic 14". I don't recall which I had last time I tried cutting with a jig on a band saw. I remember having trouble getting the focus of the circles positioned perpendicular to the cut. Now, I admit I was, no doubt, using cheap blades. I have since begun using Lenox blades and have been very happy since I switched.
I made a jig somewhat similar to the one Larry Barrett shows from the Popular Woodworking video when I had 300 circles I had to make. It worked out quite well.
I had decided I have much better success when I free-hand cut on the band saw, but now that I use better blades I am more apt to try using a jig again when the opportunity comes up. Thanks for your encouragement.
But again Yonak it is very important that the guides are all in line and straight and close to the blade and I think more important is that the front of your blade is in line with your center of your circle. If I can do it with an old Craftsman you certainly can do it with a Delta of Powermatic. Good Luck. Don`t forget to call if you need help. Also I have been using saw blades from a different place that I usually got them before. I now get blades from Supercut Bandsaw Co. they are just as good if not better that any I have ever bought. I have used most all kinds that have been mentioned here at WC and then some and these cost about the same if not cheaper. I wish you would try one. Also I do not have any afiliation with them at all. Larry
Thank you, Larry. Yes, I have bought some blades from SuperCut. I have not used the ones for the 14" saw yet, but I have used the 3/4" blade for the 18" band saw and have been pleased so far.
