Dado blades for Radial arm saws
Carol Reed
I have a CMT Dado blade set I have used on the radial arm saw. The self feed pressure is almost more than I can control - with two hands, arms locked, and legs controling the cut. Way too scary.
Likely this set does not have a negative hook angle. So I need a new set of dado blades for the radial arm saw. Recommendations?
Re: Dado blades for Radial arm saws
call customer service...
Bill Tindall
at your favorite saw blade company. Also, use a smaller diameter blade. Last resort have Misenheimer Saw shop re-grind what you have.
JMOHNIKE
It sounds as if you are pulling the blade into the work. I push mine and have no problems, ever. Also I think you will find that the sawdust port on the saw will actually work. Set your material as you do now and set up a stop. Remove the material, pull the saw back, reinsert the material, and cut.
Don Evans
I've never had a radial but your question made me wonder, do you have to mound the blades backwards? In other words, on the table saw the teeth that are cutting are pointed towards you and they are on the top of the arc. On the radial the bottom teeth would do the cutting and pointing towards you, right? So wouldn't you have to mount them so blades are turned around? This would depend on if you are pushing when cutting or pulling when cutting, which way is it suppose to be done? Sounds like you are pulling to cut.
Has this problem just started or always been this way?
Don
Joseph Mulherin
Don and JM are correct...reverse the mounting of the blades and have them cut when you PUSH the saw into the material. I know this from experience too because I had the Craftsman
ROS many yrs ago before I bought the Shopsmith in 1978.
Alan Schwabacher
The Dewalt DW7670 dado set (same as Delta) has a negative rake, and works fine in a RAS. I have found it very controllable, and while I am usually quite careful to cut slowly, it has never shown a significant self-feed tendency. It is also a good buy, in my opinion.
http://www.grizzly.com/products/35-7670-8-Stacked-Dado-Set/H7200
I cut with a standard pull stroke. The blade forces the work down and toward the fence in that mode. A push mode would tend to lift the work, and would require clamping of the workpiece to make me comfortable. It also would require manipulation of the work while the blade is pulled forward, and I don't like to do that. I have heard of people who cut in both directions to speed up the process, for instance while cutting half-laps.
Carol Reed
Interesting. I do have the owners manual for this machine, ancient as it is. I have been using it as directed from there. Other research indicates that a negative rake angle for the saw blades is necessary.
I have found a few negative rake sets. The one I am leaning towards to a Freud, ~$90 for an 8" set with free shipping from Amazon. It seems few have experience in this area and are commenting from a different perspective. Thanks for your input.
I don't believe that
Pat Evans
Maybe I'm missing something, but blades are unidirectional. Unless you change the rotation of the motor, you can't mount blades backwards. It won't cut no matter whether you push or pull.
I agree with Alan that a push cut is dangerous as tends to lift the workpiece.
Gary Camp, Bend Oregon
Good evening Carol. I have an 8" Forrest Dado King that I use on my older Craftsman Arm saw. It does have a negative hook. It still wants to self feed a slight amount, but I find it to be very managable. I will say it was interesting to watch a coworker I was working with use my arm saw for the first time (with a dado head) he was trying so hard not to let the saw self feed he could barely get a cut started, I must have really put the fear in to him. when we were putting battens on the house this summer Lisa went back and forth between the arm saw and the SCMS depending on the cut she was making, although it only had a regular blade Woodworker I neg hook.
Come back for a visit, sometime. I acutally have shop space now.
glc
Ron Jones
Put me in the negative hook group. I have the DeWalt set but have used it only on my table saw. I have seen a post or 2 here that really concern me. Those that recommend pushing the saw from the front of the radial arm saw scare me. I have used radial arm saws for over 50 years. I taught for 42 years with woodworking as a big part of my class load. I have NEVER seen a manual for a RAS or a woodworking text or a book on woodworking or any reputable source recommend pushing from the front. I have never seen a woodworking magazine endorse pushing instead of pulling. I have seen experts warn against doing this.
When ever you push the saw into the stock the rotation of the blade causes the stock to be somewhat lifted from the table and thrown over the fence. When pulling the saw through the stock the rotation of the blade forces the wood down on the table and against the fence.
I know some of you will think I'm nuts; I may have offended some of you. I understand that--after all I keep the guard on all of my equipment.
I have had a Craftsman RAS for over 40 Years....
Got it when I was about 16 and I am collecting Social security now. I used to put an 8" Craftsman dado set on it. As I recall, it self fed pretty aggressively. Nowadays I use my TS for most of this and on the occasion I cut a dado on the RAS I usually nibble it away. With a standard blade I cut on both the push and pull strokes. I would never try the push stroke with a dado head. I think it would pick up the piece and throw it. (Way back I had it throw a small drawer front through a piece of 1'4 inch plywood covering a window behind the saw.) (I also had it threw a thin strip I was trying to rip through a can of lacquer thinner without knocking the can over. I did not realize the "arrow" went through the can until I smelled the thinner.)
I would suggest a negative rake set and use it carefully. Use a tall(ish) fence.
Stuart Johnson
I have an old manual from when I purchased a radial saw from Sears. The one section talks about the need to always pull the the blade through slowly letting it cut or it will try to run up over the wood. I'm not sure but that almost sounds like what a kickback would look like from the bottom of the board on a tablesaw.
Larry in nw ohio
Carol I didn`t read any replys so if I repeat someone it`ll be a good suggestion. Could you or have you tried to push the blade through instead of pulling and of course you`ll have to clamp your work to really be safe and should not be to much to do. I think that may work. Good Luck AND BE SAFE. Larry
Carol Reed
The saw and its blades are not designed for pushing the cut. That introduces abnormal forces against the fence and allows the wood to lift and launch behind the fence. No good, safe way to hold the piece down. It wasn't designed for that. Saw blades for chop saws and SCMS are negative rake blades. That's the reason for searching for a dado set with negative rake cutters. I only received two recommnedations there - one outside the budget. I am looking at the Freud SD208. It is ~$90 shipped from Amazon. Next pay day.
I was wrong about Wood Worker I
gary camp Bend, Oregon
It also has a positive "hook" although it is only 5 deg.
I have the Freud SD208 and RAS
Tim Greif - West of Chicago
I have this dado set and use it on both my Delta CS and my old Craftsman RAS. It is a high quality dado setup and cuts flat bottom dados. It is a negative hook blade but you still need to be mindful when using it since it's pretty agressive with multiple teeth in the cut at the same time. If you're used to RAS blade control, you'll manage just fine. I also use an old Craftsman non-carbide 7-inch dado set for non critical dados and grooves. Its smaller size makes it less agressive to feed, but it still gets your attention. However, it leaves the outside edges deeper than the inner cutters.
The Picture below shows the dado on the wall behind the RAS and my old Craftsman set on the table. I also run a Freud negative hook blade on the RAS. I used a standard blade for years and could not believe the difference in blade agressiveness when I switched to a negative hook blade. I've had that saw since I bought it new in 1977. I still use it as much as any other tool.
Perspective of age
Rod Peterson—Ormond Beach, FL
I agree with much of what Ron says. I have had a radial arm saw (Craftsman) since 1972. I bought the Sears accessory book for it and learned all I could about the machine. I learned how to use the machine backward and forward (and by that, I do NOT mean mean pushing the carriage into the work). Shudder! I don't even want to think of someone doing that.
I've observed several things since the advent of the internet: There are a lot of people who were introduced to radial arm saws who have no business using them. The ripping controversy is illustrative of one of them. That there were people taken seriously who advocated ripping on their RAS WITH THE ROTATION of the blade, instead of normal was highly disturbing to me. The most obvious point of those advocating it was they'd never read the directions.
The other significant one is blades. In 1972, there was no such thing as a "radial arm saw blade". You went to the store (Sears, for the most part, back then) and bought yourself a 10" blade. Until Forrest came along, there was never a "radial arm saw blade". Now, I will admit that the negative hook angle blade will certainly reduce the pull on the cut, but if that's so necessary, why did the first RASes, introduced nearly a generation before I bought mine, and in many cases, 12", 14", or 16" machines, all come with regular grind blades.
I have Wally Kunkel's seminal book, "How to Master the Radial Arm Saw", which was written based on his experience in that early time of the RAS, and I do not recall him advocating for a negative hook blade, and certainly couldn't counsel for a "radial arm saw blade" because they didn't exist back in the day.
To someone new to a radial arm saw, or coming to it from table saw experience, I can understand how the initial feed may seem awkward or unnatural, but without the prejudice that comes with other saw experience, it certainly is easy to master the motion, and once mastered, there is little difference in approach between a 10" blade (of any flavor) and an 8" dado setup, any more than there's little difference between dragging the carriage across a pine board versus dragging it across an oak board.
Caution? Yes. Inventing new procedures? No. Looking for something in a negative rake? Can't hurt, but not necessary.
Rod
Boy that looks like mine...
Mine's a '72, however. Is your column support a single piece casting or a two part bolt-together? I believe they made that change sometime around '74. I wish your blades weren't in the way. I'd like to see the carriage and the anti-kickback/splitter assembly.
Rod
Re: @Tim re: SD208 and the RAS
Carol Reed
I use a lot of Baltic Birch plywood. How does that set cut in plywoods? Its rating on Amazon for plywood is only 'fair.' To get an 'excellent' rating more than doubles the cost of the set.
Since I already have an 8" CMT set which is causing me the grief on the RAS and a 6" non-carbide non-name set that leaves a horrible cut, I don't want to bust the bank on a set dedicated to the RAS.
BTW, the CMT is 230.024.08. I could not find a rake angle posted anywhere for it, so I am assuming that it is not a negative rake and that is contributing to the excessive tendency to over feed.
Thanks for your perspective.
Ron Jones
Peachtree has one on sale right now. I know nothing about it, but did see that ad for it.
Negative hook blades
Howard Acheson
You are correct, negative hook blades are a development coming out of the miter saw and CMS market. It was found that the negative hook blade produced a cleaner cut.
The negative hook blade also produced a cleaner cut and at the same time somewhat reduced the tendency of a RAS to "climb' as it was cross cutting.
When I bought my RAS in the mid 1970's, carbide tipped blades were primarily used by commercial wood cutters. They were expensive and did not produce a particularly good cut. Cabinet maker's blades were steel and either high tooth cut or what were known as "planer" to tapered rim blades. These blades produced a smaller kerf and cut through wood very easily. These blades produced excellent clean cuts that rival the best of the current carbide tip blades. But, they required frequent resharpening. I had three and one was always at the sharpener.
All told though, I recommend a negative hook blade and dado for use on RAS today.
Rod - here's some answers and more pics *PICS*
See the photos below. Mine has a solid cast rear column. It also has the original carriage guide rails, which are replaceable.
You wanted to see the carriage assembly and splitter/anti-kickback pawls. Shown below. I've used that saw for everything until I got a contractor saw about ten years ago. Heck, I even cut coves with it for a pool ball rack by using it in rip mode with the carriage at a skewed angle. Took very small bites with each pass, but it worked out just fine. Tha would have been so much easier on a table saw.
Good to see you postinhg again. I've been away from the forum for a while since I retired this year.
Re: Some of my own
Hmmm, for some reason I've lost the mojo to post HTML. Discovered this a while back, but with my limited posting, it hasn't cramped my style. Now, I have to use the built in image poster and I can't post multiple images.
Anyway, here's a picture of my carriage showing the splitter I think they only supplied for a year or two. There's a light bulb in that square housing to illuminate the work and cut, but my recollection is it needed replacement fairly often. The blade guard has a power cord which plugs into the top of the motor housing.
There's nothing remarkable about the other side of the splitter—just the thumb screw that locks the splitter in place after sliding it up or down to put the anti-kickback pawls at the correct height for the work.
Second image in next post.
Another of my own
This is a little more standoff and features the solid cast column support in those models.
Oh, that silver plate with holes on the guard above the knob which clamps the internal chute? That's for attaching the exhaust directing chute extension that came with the accessory dust collection collector that I bought, probably in the '80s.
Basically, I think the only difference between yours and mine is the splitter. Oh, and mine is on a cabinet with five drawers—lots of people bought the plain, four legged stand with splayed legs.
Rod
