THE WOODRAT IS BACK!
Gluing Corian Question....
This goes along with the Throat Plate question I posted below. I have some scraps of Corian that are not big enough to make throat plates unless I glue them up. What glue would I use?
Re: Gluing Corian Question....
Use
"No Glue" ie, get a solid piece to fit or buy a new plate. I would never, EVER, rely on what you propose for a throat plate. One wiggle in the blade, the plate fractures on the joint, we read your obit. Thank you, no thanks [please!]
PS: On second thought, perhaps Galapagos Hide Glue would be most appropriate. That way, you'd satisfy the purists on the Darwin Award Committee. ;)
I would not risk this adventure
Bill Tindall
A glue failure in the plate would send the piece being cut, as well as the plate pieces, into the saw blade. Any shop working Corian will give you mountains of scrap for this application.
Re: I would not risk this adventure
Larry in nw ohio
Barry I certainly agree with the other posts. One easy thing is to use some hard scrap wood you have lying around, and get a piece big enough for your plate and make one. Put your plate on top and trace it and cut it on the bandsaw and a patteren bit in the router and a little sanding and you should have one. Good Luck Larry
Barry, I certainly wouldn't try this, as others have said, this could end up in a disaster. I made a about a dozed inserts for my Unisaw about 5 years ago and seldom use the originals. I had quite a bit of 1/2" Baltic Birch cutoffs laying around and found a partial sheet of Formica. Using solvent based contact cement, I glued the Formica to one side of the Birch, then using the original insert, traced the outline & band sawed the new inserts about an 1/8" from the traced line. Then I clamped the original insert to the blanks and using a pattern bit routed them to exact size. I drilled the hole in the end for the pin and inserted rolled dowel pins into all inserts. Then I drilled holes for adjustment screws, installed them, put the inserts on the saw, adjusted the level (with an indicator, and adjusted side screws to remove all side play. I installed an 8" dado head on the saw with about a 1/2 or so cut and set the fence over the insert. I brought the blade up - took several tries to cut the slot depth to leave about 1/4" at the thinnest section of the insert. I then lowered the blade counting the turns required, installed the inserts one by one and slotted them all. I replaced the dado head with my WW2 and installed the MJ splitter in a couple of the inserts - as some will be used for dado and angle blade work I didn't install the MJ on the rest - can always do it later. I stored the inserts for later use and have used 2 or 3 in the last 4 years. None have "warped" but I do have an air conditioned / central heated shop. I don't know if it would be necessary to apply laminate to both sides if the inserts were exposed to large humidity changes. The inserts took me the better part of a day to make but I have enough for a few years. I do have to adjust the screws once in a while (every few months) but so far have worked great. The only thing I might do different next time is to set up the router table and make the undercut for the blade instead of using the dado head.
Bill Howatt
Like the other's said,l don't do it.
There are all sorts of other things to use. My favorite is to use kitchen plastic cutting boards which I think are a fairly hard polyethelene.
Bill
Thanks, And.....
I should have made it clear that my scraps are long enough, they are just about a 1/2" too narrow. I would never have considered gluing them end to end for this application.
I think I will be re-examining my BB and Formica scraps and make up about ten. Should last me a lifetime or at least until I get the urge to make more.
If I find a countertop shop I may check out a few Corian scraps also.
Thanks for the concern and the help.
Re: Thanks, And.....
Steve Kreitler
Corian is just not a suitable material for this purpose, even if it's large enough. I've worked with it quite a bit (epoxy works just fine with it, btw), and I've found it be be brittle, with very little structural strength of it's own (it's intended to be used over a substrate). The baltic birch and laminate idea is a much better one (this is what I do, as well, and it works fine).
