Machine Oil?
Machine Oil?
Machine Oil?
I need to get some oil to lube my big machines (planer, jointer) Been a while since I bought any. Are there any new products you'd recommend?
Thanks,
Tom
Re: Machine Oil?
Oil?
Bill Tindall
I have never oiled a planer or jointer. Nothing on either of my machines that would desire oil.
Re: Machine Oil?
Re: Oil?
Jim
I have a Parks planer and the infeed / outfeed rollers are in bushings with oil cups.
I use a light weight 10W non detergent motor oil.
Works fine for me. Any lighter and it leaks past the bushings too quick.
Jim
Re: Machine Oil?
Re: Oil?
Howard Acheson
Does your manual call for 10 weight oil? Most machines use 30 weight machine oil. 3 and 1 sells a 30 wt non-detergent machine oil that I have used on motors and tools over the years.
Re: Machine Oil?
Re: Oil?
Jim
Howard
You are right, the manual does call for 30 wt oil
However
I have used the 10 wt oil as that is what I had and it seems to work OK
But
I should have checked the manual before I responded
Another "look before you leap" moment!
Re: Machine Oil?
Re: Machine Oil?
Ken Oakley- Sunny St. Cloud, Fla.
I like Olive oil and a bit of vinegar on my salads.
Re: Machine Oil?
Re: Machine Oil?
Robin Corell in Atascadero CA
from all that I have read non-detergent 30wt is still the prefered oil lube for oilite bearings. Thats what I use in my spindle sander as well as for the bushings on my Parks planner.
Robin
Re: Machine Oil?
Re: Oil?
In addition to the four oil cups that need attention there are also oilite bushings on each end of the bed rollers. I pulled mine apart and drilled 1/32" holes in the blocks that hold them so I can oil the bushings from the top of the bed without removing the rollers. The saw dust that settles in the holes acts as a wick for the oil.
Robin
Re: Machine Oil?
Thanks!
I appreciate the input. Just happen to have some 30 weight in the shed!
T.
