Re: WC Weekend Accomplishments...New Years Edition
Gary Smyth
What I’ve been up to.
I know I’m obsessing, but the neighbor’s dogs continue to be of concern to me. They’re out all day with no shelter and lately three of the four have been soaked through and through and shivering. I couldn’t take it; I was dreaming of dogs and waking up over sitting by and doing nothing. I built this and finished it Sunday.
It’s big and far more noticeable than I wanted, but two large dogs can fit. Right now it's rough on top as the shingles for the roof just crack in the cold. I left a “lumber wrap” on for a while. Most of the lumber I had and I figured I couldn’t burn the pressure treated stuff so I used it. No paint, as it’s too cold and only limited glue for the same reason. Held together with removable tight fitting hardwood dowels which you can see hammered in on the bottom and window latch hardware. Not only a dog house, it’s also built to break down to an open firewood/utility cart that can be hauled by my lawn tractor to and from the wood pile.
I added a temporary rain/wind stopper using canvas they can pass through and later the door beside that (and the hinged roof) flips up for cleaning and as a shade for the summer. For winter there are removable Plexiglas windows on the sides so that they can see out and I can see if they are there.
The (Golden) dog (Hank) I built it for is not using it inside but the queen (Black Labrador, Bear) sure does. The Golden uses the “porch” which at least, kept him off the ground.
The whole thing took some time because I built the door 16” off the ground to keep out the snow, because it completely breaks down, and because it has 10” casters on the bottom to move it easily with weight over the uneven ground. It is also insulated top and bottom so that the dogs own heat keeps them relatively warm. I could have had it ready much quicker if I could have made it permanent with nails and glue, but who knows what the end result will be.
As I said, I finished it but working outside in the cold and rain provided me a mother of a cold. Had I insulated the walls more I could have used it as a sauna. Whatever. I need a nap. At least now I know that I’ll sleep.
