Dust collectors
Dust collectors
Dust collectors
Jim Breeden
Through numerous searches, I know I've seen comments about dust collectors, among those are the HF 13180 1HP 660cfm, and 97869 2HP 1550cfm, as compared to "the big brands". As I my monetary resources are limited, plus I have a 25% off coupon, plus they're are on sale ! The primary questions would be - are they worth it? Another question is - are the impellers metal or plastic ?
Re: Dust collectors
Re: Dust collectors
Some thoughts on the HF 2 hp dust collector.
Friends don't let friends buy HF.
Okay, I've seen one. The bottom sheet metal is so thin, that you would think it would be a piece of heavy duty Reynolds Wrap. The impeller is cast metal (what type I don't know). The "wye" is okay and has 2 4" ports into a 6". If this is your "forever" dust collector, I'd really consider another.
Hey, if it is what you want, buy it. I'd replace the bag with a decent one though. I would also go directly from the impeller to a separator and then go to either a machine or a short length of ducting.
IMO, you'd be better off with a canister as opposed to a bag and a cyclone as opposed to a canister.
I'd only get the 1 hp if I were using it for a single machine at a time.
Re: Dust collectors
Re: Dust collectors
Jim Breeden
Thanks JL. 8) I don't have a "large" shop, about 1/3 size garage, and I do use only one machine at a time - primarily the lathe. So, the 1hp would probably be enough. Now to figure out how to connect it to my Onieda Dust Devil, so I can continue to use it as a seperator. Something as got to be less of a noise maker than my shop vac! :b
Re: Dust collectors
Re: Dust collectors
Larry in NW OHIO
WOW Jim I don`t know if the Dust devil is big enough to handle a lathe, but all you can do is try, you`ll only be out some of your time and may be a few parts. What do you need to do, go to a 4" to a 2 1/4" on the devil. If so I could mess with mine, I have 3 of them. I could toy around mine to see if I could help, I have done quite a bit with putting odd dust collection fittings together and believe it or not some of them actually worked. If you would like me to help let me know what you are trying to piece together. Larry
Re: Dust collectors
Re: Dust collectors
Jim Breeden
Hey Larry - I have two Dust Devils, one still in the box as a replacement for the original that disassembled it's self. Repaired the original, and am going to work on modifying (?) it, and see what happens. Am using my shop vac now, via the Dust Devil on the lathe. Seems to be working real good, get very little dust in the vac, but not enough cfm to pick up much dust. My shop looks like the proverbial dust bin! I'll let you know what happens. :)
Re: Dust collectors
Re: Dust collectors
Charlie Lenz
Do you mean Dust Deputy ?
