Bandsaw Burning
Bandsaw Burning
Michael Donaldson
Bandsaw Burning
Michael Donaldson
So, I am trying to cut some curves for a few Christmas projects I am working on, and I have a 1/8" blade on my bandsaw (14" Jet, with 6" riser), but on my test pieces, the blade burns the wood really bad. The test piece is a block of hard maple (the actual workpiece is poplar). Is there something wrong with my adjustment of the saw? I set the tension to the 1/8" mark, I have the saw tracking straight, I have the blocks and rollers and such set so that they are just barely not touching the blade when the saw is running. In short, how do I get this thing to not burn my project?
Re: Bandsaw Burning
Re: Bandsaw Burning
Jim in N. Va
Sounds frustrating. A bit more information will help folks come up with suggestions for you.
How thick is the wood that you are cutting and how many teeth does the BS blade have? If there are too many teeth in the wood at one time then it's hard for the blade to clear the saw dust and you can get heat and burning. You might be going too slowly, in which case the blade will keep rubbing the wood and generating heat. Finally, are you letting the blade do the cutting or are you pushing the work through the blade? It doesn't matter if the guides are properly adjusted if you wind up pushing the side of the blade against the work...especially easy to do while cutting curves. Are both sides of the cut showing burning, or only one?
Re: Bandsaw Burning
Michael Donaldson
Re: Bandsaw Burning
Michael Donaldson
The blade has 12 tpi, and the work piece is about 4" thick. As I have 4 boxes to finish before Christmas, I think I have been 'helping the blade along' too much. I will let the blade do all the work and I'll see if that helps. Thanks.
Re: Bandsaw Burning
Re: Bandsaw Burning
Jim in N. Va
It's a lot to ask of a 12 tpi blade to clear saw dust from 4 inches. That's 48 tiny teeth buried in the work at any one time. If you possibly can, I'd suggest trying a blade with far rewer teeth.
Good luck. I know time is short and the pressure is on.
Re: Bandsaw Burning
Re: Bandsaw Burning
If you have a wider blade with fewer teeth I would try that. sometimes the wider blades have more set and will still let you turn a pretty tight curve if you don't force the cut.
Re: Bandsaw Burning
Re: Bandsaw Burning
Bruce, a MN Galoot
Not to suggest anything offensive here, but I had a friend do exactly this one time. I was trying to diagnose the problem over the phone, and remembered that he's a wood carver, not a regular wood worker. I suggested that maybe he had the blade on upside down. He checked, and sure enough he was trying to burn his way through the wood, not cut it.
I suspect the other suggestions are right and that a 12 pt blade is too fine to cut 3" maple, but go check the blade orientation just to be sure. ;)
Re: Bandsaw Burning
Michael Donaldson
Re: Bandsaw Burning
Michael Donaldson
Nothing offensive, I have been a woodworker for just over 6 months, so nothing is off the table. I looked at the orientation of my blade, and it was installed correctly, but I did notice that the teeth were all clogged with purpleheart. So I am using a toothbrush to clean out the teeth (brushing my teeth, I laughed a little when I started). Thanks for the help, I'll let you know if it works, and will be posting pics of the finished boxes.
Re: Bandsaw Burning
good excuse to buy a power tooth brush
Re: Bandsaw Burning
Re: Bandsaw Burning
Alex Grigoriev
1. Maple burns much more readily than poplar. Poplar will cut easier, too.
2. You should get a blade with at most 4 tpi for that thickness. 2-3 recommended.
3. Clear packing tape stuck on the top of the workpiece may provide a bit of lubrication. I never tried that, but I've read it helps even with cherry which is known to get burned very easily.
Re: Bandsaw Burning
Michael Donaldson
Re: Bandsaw Burning
Michael Donaldson
Well, I am off to woodcraft tomorrow after work to get a new bandsaw blade, I will get a 3/16" 4 TPI skip tooth blade, that should work a bit better. Thanks for all the help, I love this site.
Re: Bandsaw Burning
Re: Bandsaw Burning
del schisler
I didn't read any post yet but i belive if you go to a 3/16" 4 tpi skip that should not burn but the cut will not be as fine as the blade you are using now a 16 tpi is real fine and maple and cherry has a lot of sugar in the wood and will burn. Make sure you have a sharp blade and a good brand. I belive your's should be 105" order a good brand also. I do a lot of resawing and also small cut's i have the delta with the riser. The saw's aren't any problum with small blade's. The blade guide's should be set with a dollar bill thickness to the guide to blade. my 2 cents
