Re: Beginner Wood Worker
Guillaume Dery
Advice on this is all over the map and if you ask 10 woodworkers what are the best starter tools, you will get 11 different answers
That being said, here is my 12th answer:
Stationary power tools:
The bandsaw vs tablesaw debate still rages on but as a beginner you will be well served by a tablesaw for a good long while.
If you are planning to work with solid stock whatsoever, and especially with rough-sawn (not S4S), I would add a jointer and a planer to the must have list to ensure you work with flat square stock. I have heard arguments made that you only need one but to me, they are both a necessity. A lunchbox planer will serve you fine however. No need to get stationary.
I also support the drill press recommendation made. I would even move it near the must category.
Armed with these, you will be able to tackle many projects and they would form the core of your workshop, even as you grow.
Many people swear by the bandsaw and it has many advantages. Ability to cut curves, ability to rip, safety and ability to resaw. However, I would hold off on that until you know in which direction you are going. Too many people buy a bandsaw with the largest resaw height available and have yet to resaw anything or slice their own veneer (essentially the same thing).
Handheld Power tools:
On the handheld tools part of the equation, immediate must haves would be a good router and a cordless drill. Starting with only one, I would go for a midsize kit with multiple bases (such as the Bosch 2 1/4 HP). This will do most of what you need to do and has the power to spin anything but the largest bits. The 3 1/4 HP routers are heavy beasts and will get in the way of some operations. Routers open up many doors as they give you the ability to run moldings, apply edge profiles, raise panels, perform some joinery, etc. I would highly recommend building a router table as one of your first projects and you can dedicate one of the bases to it.
Cordless drill: you don't need a heavy voltage one here. No lag-bolts are driven in furniture. I must be light enough and comfortable enough for you to exercise fine control on it. As you grow, you may end up like me and prefer to have 2 but 1 is plenty to start. I use 2 as a time-saver. One does my pilot holes and the other drives my screws.
Random orbit sander: Until you discover the wonderful world of handtools and of a properly sharpened plane, you need to get your surfaces finish-ready. A good 6" ROS comes in here. Not necessary but sure is nicer than sanding by hand.
Jigsaw: cut curves without a bandsaw. In this category there is an immense difference between the good tools and the cheap tools.
Real Handtools
Even if you never plan to slide down the galoot/neander slippery slope, a modicum of handtools is still needed, if only for layout and measuring.
At the very least, either an accurate combination square or engineer's square (use the line/flip/line trick to test accuracy prior to purchase), a 12" rule, a small accurate tape measure and a marking knife.
Personally, I think a few handsaws, some bench chisels and a marking gage fit in the list but if I let myself, I will make your handtool list much longer than the power tool list so I will stop here.
Like I said, you will get as many opinions as there are woodworkers so these are my thoughts on it. You already got a few bits of golden advice from other replies however:
- Only buy tools when you need them
- Only buy quality (ensures you only cry one...when you get the bill, rather than every time you attempt to use the tool)
- Ask yourself what you want to do and which path you want to take before investing.
- Get the minimum you need and start building!
Oh, build yourself a workbench too. It doesn't have to be a Schwarzian version of Rouboesque perfection either. Just something to allow you to work and assemble at a comfortable height. No matter what bench you start with, you will want to junk it and redesign around how you work as your woodworking evolves.
Just my 0.02
Guillaume
