We value your privacy.
We have to build a well house at the church. The wind can get to be quite a force here. This is high desert, very dry, year 'round. Less than 5" of measurable rain a year. This little house will have a footprint in the neighborhood of 4'x4', but have no floor, of course. No eave ovehang, either. Stick built, with asphalt shingles. ordinary door with deadbolt lock.
The reason for the build, it that some seriously creepy dudes have been stealing anything metal, hauling it out into the desert, cutting it up, and then selling it as scrap metal. Including entire well pumps! Thee is not someone at the church site each day, so this is a concern. I cannot understand that if they want to work that hard, why not get a real job? But that is not the point of this post.
So, the plan is to plant anchor posts with a treated lumber frame to stick build a small house on. Yesterday I saw anchor posts in Home Depot that are meant to just pound in the ground. Looks like you just fasten with nails/screws through holes in the anchors into the wood.
Three questions. Think the anchors will keep the well house in place in winds that often (really!) hit 80 mph? Second, is the paint on the anchors sufficient to control the adversative reaction of the treated wood and the metal? Home Depot carries the dark brown stuff. Third, what kind and type of fasteners? Nails, screws, regular, galvanized, stainless?
My father-in-law has a vacation house that uses a deep well with an above ground pump. The well casing is surrounded by a concrete slab with a steel frame embedded in the concrete. A metal enclosure had hinges welded to the frame and the hasp on the cover was padlocked to a fitting on the frame. On two occasions, the lock was cut and the pump stolen. The solution was to have a submersible pump installed with a casing cover lock that makes it too much like work to bother stealing. This may be a more attractive alternative for you.
I prefer concrete. I believe I used a similar anchor when I put in my mail box post. While it worked for my mail box, I'm not sure about your well house. It may work for your application - but I'm not sure. If you use concrete, it would take about 1/2 bag per hole - so two bags should do it.
Yes - it is working for my mail box (3 years).
I used the decking screws (NOT drywall or galvanized). I used the ones with Torx heads. Get the ones specific for ACQ treated lumber. Available at the Home Depot.
Is it possible to set up video surveillance at your church? Stealing metal is a serious problem everywhere it seems...i know of several bronze placques commemorating WWII vets stolen...nothing is sacred to thieves.
Check what the wood is treated with. Locally HD is selling wood treated with Micronized Copper Azole and Lowe's is selling Alkaline Copper Quaternary or ACQ stuff. It was the ACQ stuff that started the "fastener wars". Turns out it is five times as corrosive to metal as the old CCA stuff. So now the deck fasteners have Yellow oval labels on them stating "suitable for treated lumber". Not sure the Micronized Copper Azole stuff requires the up graded fasteners, but they are a good idea until you know differently. So you should use Labeled fasteners or heavily galvanized or stainless steel. High grade stainless being the most expensive and most reliable.
You really need to check with the HD and find out what the chemical is and what the recommendation is for fasteners.
I suspect that water has a lot to do with this. I am sure it enhances the chemical reaction so I am fairly sure the corrosion you get will be less than what I would get here with 40" of rain annually.
And for any parts that touch the earth, you want stuff rated for "ground contact" and it will be more heavily treated (more salt retention).
Most shingles are rated for 50mph winds. What do people use on their roofs locally? Go with that. You are using so few it does not matter what they cost per square.
I don't know what the withdrawal resistance of those posts is but why use metal posts to thwart metal thieves? I'd use wooden posts and dig them about two feet. I would put short blocks bolted on the sides near the bottom to make it hard to lift them out of the holes and tamp dry Sakrete into the holes. I would flair the holes at the bottom to make the Sakrete hard to with draw. After you put the dry Sakrete in the holes, pour a bucket of water on it and it will infuse and set. (Locally we don't bother with the water, mother nature will provide it, but where you are, not so much.) Ordinarily, I would NEVER set a post IN concrete (it accelerates rot) but in your climate it won't matter. Locally I set weight bearing posts ON concrete and fill the holes with gravel to promote drainage. (I could here my Grandfather spinning in his grave as I typed it. He said only a City Slicker wood set a post in concrete.)
As far as separating the metal posts if (you use them) from the wood any reliable durable coating will do. Paint, Duct tape, poly film, anything that will keep the chemical off the metal.
The lack of over hangs will help with wind resistance. Studies of damage after hurricanes teach us that houses with wide overhangs suffer because the wind gets under them and helps to lift eh roof off. The "wing effect" of the air over the roof also creates lift so you want to nail your shingles well, especially at the eaves and rakes.
Wider overhangs are beneficiary in keeping the weather off the building, but you don't have enough rain to get excited about.
Local news stories report them stealing the outside AC units off empty houses, right in front of the neighbors. I am remodeling an house and added a Heat Pump. Decided to leave the outside unit off until the very last minute. Even covered the exposed copper tubing with trash. Nearly every day I hate people stop and ask if I have any scrap metal they can have. On the last house, they stole the copper pipes. I put plastic back so they would not just steal the copper again. They have stolen the copper downspouts off a local Baptist church so often the local scrap deal and them pour red paint through them. When they show up at the local scrap yard the owner (member of the church) tells them "you can leave those here and go and never come back or you can wait here for the police". Then he pays to put them back on the church.
Carol,Get a screw in anchor. They come in different sizes and load ratings. Around here in tornado alley they are required by code to stabilize pre fab buildings. This will secure your pump from winds, but short of a concrete bunker nothing will secure it from your creeps if they are determined.
A recon mission to the county is in order. I heard somerthing about no concrete allowed, but I don't know in what context. There are gazillion wells around here. Many pumps too choose from for the miscreants. The idea is to make ours a little too much trouble.
I'll look into the screw in type anchors. The little house just needs to be anchored well enough to keep it from simply being pushed over, either by two legged creeps or the wind.
This is such a problem that houses for sale don't have signs out front. That would be advertising to just come clean them out. We have an open carry gun law in this state. Sadly, it doesn't extend to openly shooting the buggers. Not terribly charitable, but then there are many others who deserve our charity. These yokels don't!
When I was in high school in rural southside Virginia thieves would spot a cow standing near the fence on a rural road. They would shoot the cow in the head and hop over the fence and cut off a quarter or two of meat with a chain saw, and drive away quickly. Became an epidemic and expensive problem. The local sheriff was run ragged and under staffed and basically unable to do anything about it. So he called a meeting and told the farmers, "Themes Rustlers and cattlemen know what to do about rustlers. Won't be no problem." Soon after the story appeared in the local paper and then about every farmer had a gun rack in their pickups. The problem went away. Nobody got hurt.
I have to agree with Barry on this. Those types of sub-humans will just keep on doing what they are doing until they get caught and something`s done to change their habits. If local law enforcement can`t handle the problem then it has to be solved by the people who are directly impacted by it.
The bad actors in our area all know that if they come down our dead end road my neighbors and I will appear at their door within 24 hours to have a little talk with them. They know this because we`ve made it happen on several occasions.
They don`t even bother to come down this side of the river anymore,too many eyes and people who communicate with each other over here.
Friend of mine had an old abandoned truck sitting out behind the barn. Walking back form deer hunting he noticed the gate was open and went to check There was a guy there stealing the radiator out of the truck. He told him to leave it there and be gone. The guy just grinned at him and said "You won't shoot me over a radiator." and kept walking toward his truck. So, he shot the radiator. It's still laying pretty much where it landed.
Carol It`s to bad a person couldn`t hide close and wait and if you coulkd catch them at the deed, and then light some firecrackers and throw it close at them. Larry
Once they get over the fright, they'll be back with a vengeance
Similarly, I once had some tools stolen that I foolishly left in the back of the truck in my long driveway. I considered getting some empty tool cases from my favorite used tool store and filling them with something nasty (I'll leave that to everyone's imagination), and leaving those for the thieves to find in the truck. But then I figured I'd come out and find a broken windshield a couple days later
Still think of doing that in a HD parking lot though, especially one I don't frequent often
