We value your privacy.
I'm finishing a project gone bad with many contractor stories I won't get into, except to say that I'm stuck with a situation and am looking for DIY help.
The project at hand is the installation of stained oak trim (800 lf).
The window and door jambs do not line up with the drywall and "by how much" is highly variable!
The only things I can think of doing are not going to go well:
1) Try to make shims/extensions to fit the tapered gaps and then stain them (2 coats stain + 3 coats water based poly).
2) Slit the drywall under the trim and bash/crush it with a hammer to "make it flat".
Anyone been through this before and have any "learned the hard way"s to share?
The term is "jamb extensions," and they are, alas, not uncommon. Your first approach is the common one.
If you do a really good job on the color match, the variability of the extensions may not be terribly visible. If it's not so good, well...that could be a problem.
From the profile on the edge of the trim in your picture, it looks like you should consider a reveal on the extensions, setting them back by an even amount from the face of the trim.
If you're good with a plane, you can rough-cut each extension to its thickest, hold it in place and mark the back side, then plane each one to fit. If you're not good with a plane, this is the time to learn.
My sympathies; but I can tell you that even good contractors run into this from time to time. Minor inevitabilities add up.
shim it out level with the dry wall.....stained and finished as the rest of the wood is.....get a plane to help dimension the shims.....take your time.....forget about any bashing of the drywall....by the time you are done with this project, you will be fairly good at it.
Mike, How much is highly variable and why? From the pics it looks like the drywall is cut tight to the jambs. Is this preventing it from being from tight to the studs in places? You should cut it back a 1/2" or so and determine why it varies. If it is the jambs that are that are not installed properly, fix them before you start the trim . As for the extention jambs, You should rip them from the already prefinished oak to a uniform thickness that is just proud of the drywall at the miters. As mentioned, both the extentions and the casings should have a reveal and that 3/16" is the only area that will need additional stain/finish. My opinion would be to correct the variation problem before proceeding. George
I like to understand a problem before I set about to fix it.
The framing around doors and windows can be a bit "bendy" resulting in a bit of drywall sticking out, or in, here, and there. A "bit' is not a problem. The back of the trim must have a groove cut into it and the groove will overlap a bit of sticking out enabling the trim to fit tight against the wall. Caulk takes care of drywall sticking in.
However, what you show, if I understand the picture, is almost a full thickness of drywall proud of the window casing. I would want to understand why the casing is not covering the drywall. If it is a simple case of the walls being thicker than the window casing is wide then extension jams are the only solution, and a common one at that. But if the sticky out varies from zero to a full drywall thickness then there is some fundamental problem with the wall or window installation that I would want to understand before proceeding to attempt a fix.
I had a case like this with a door improperly installed in daughters house and the the solution was to install the door correctly.
Clearly you have received many suggestions. "Bashing" to bring the drywall into line is often done by finish carpenters today, particularly when they are paid by the lineal foot. It can be done and it does work, most often when the trim is painted. If you take that approach then recognize that you will always see it, if you live there.
Jam extension are the better solution, particularly when doing stain grade work. If the windows are plumb and square, I presume you have checked, and the windows aren't hanging proud on the outside of the house, then the problem is the studs.
Studs warp and and twist even if they are perfect to begin. If the wall aren't checked to see if all the studs are in the same plane before drywll starts, not typically something they do, then you are must pick you poison.
You can remove the drywall, messy, and use a hand electrical portable plane to bring the studs into line, but that might not be worth it to you. You don't have to remove it all, just 12 to 24 inches or so to get to the closest offending stud.
I used to be a contractor. I have probably death with about a thousand recalcitrant windows and doors. It appears to me your widow was ordered with a jamb extension that was the wrong width, if that extension was ordered with the window, or somebody cut it wrong when they installed it.
The jambs or jamb extensions should extend through to the inner surface of the wall. Actually, they are usually made to extend past the inner surface about a 1/16" and are beveled back toward the outside at a bean 85 Degree angle. So, if you had a 2x6 wall and the studs were actually 5 1/2" and the outside sheeting was 1/2" and the drywall was 1/2" for a total of 6 1/2" you would order windows and doors with jamb extensions totalling 6 9/16" for the back of the brick molding or flanges to the inner edge of the extension. Then you cut the miters at a very slight compound angle to "ease them" and let them lay back on the walls. And, horror of horrors, caulking is your friend. If the trim does not lay flat on the wall, caulk it with color coordinated caulking.
I did not have a compound miter saw, so I cut mine with a tapered shim under the trim.
So, in your case, I would do as Bill Tindall says and examine this closely and figure out what the error is. If the windows are installed over thicker storm siding or sheeting than anticipated the short fall should be fairly consistent. The same if they were just ordered or made wrong. If the shortfall is very irregular around the window it seems there must be some other problem. Like some sort of debris under one corner of the window or the window caught on some part of the sill and not fully seated in the opening. You should determine if the windows are "in a Plane". If they are twisted out of vertical, you need to find out what the problem is.
If the shortfall is consistent with in each window but different form window to window and the are in a plane, you may just have to deal with each one individually.
I would create and smaller extension strip and step it back and 1/8 or 3/16" and rip it to extend inside the drywall about a 1/16" with the bevel on the inner edge I mentioned before. Then I would trim the window as I mentioned before, but be aware that this makes the window wider and taller so you will have to cut your sills accordingly if you are using sills. (Technically they are stools and aprons, but most people call them sills.)
Prefinsh them to match and they will be an improvement on the windows.
So you understand the term "reveal" and other terminology we have used?
PS, its a good thing to bed the trim in caulk or caulk the perimeter. It will cut your HVAC bills.
I decided to avod the "bashing drywall" as best I could and used the "buffer materials" that I finished for the jamb extensions/shims. I had 4 8' pieces that I sized to the various needs and used my 23g pinner to anchor.
I got half way today...will post pics when completed.
