Posting a drawing question....
People post sketches here sometimes....
I have a scanner/printer all in one machine. It will do a number of formats, including Tif, SRCh PDF, PDF, Pic to File, and whatever. So, How do I take a hand drawn drawing and scan it to a format I can post? And, can I scale the or reduce the format size to get in under the size restrictions if necessary?
Re: Posting a drawing question....
Bill Tindall
I take a picture and go from there.
Larry in NW ohio
Barry I usually make up the drawing and scan it to the computer and then see where the computer puts it and then do it like a picture. Larry
Bill Howatt
The most commonly used format for general purpose images is .jpg format. If your scanner doesn't allow you to make adjustments of image quality such as the dots per inch (dpi, larger number is higher quality) when you scan you can put it into any number of photoediting programs and resize it. A common free one is Irfanview but there are many others. If you have photoediting software that came with a digital camera loaded it will probably do it too.
Bill
Moses Yoder
Re: Posting a drawing question.... *LINK*
Moses Yoder
I found a .pdf to .jpg converter, haven't tried it yet but it is free apparently. So you could just scan your drawing on your scanner, turn it from pdf into a jpeg and adjust it and post it just like a picture. See link below. The idea of taking a picture of it is essentially the same thing, just a slightly different process.
PDF to JPG Converter
