Utterly OT
Utterly OT
Utterly OT
Well, maybe not utterly, but darn close. Here's the situation. We have an old cat, Roxy, who used to live in the house but couldn't be trusted, except to do her business anywhere she saw fit. That's grounds for dismissal in my world.
Soooo, a few years ago I made her a cat house out of R-Max foil-backed insulation. It has a loft, a swinging Plexiglas door, beds upstairs and down, a feeding area and a picture window. It also has a light fixture that provides heat and an old photo thermometer stuck through the R-Max roof so I can monitor the temperature inside.
Here's the rub: To change the temperature, we have to change to a different wattage light bulb. That's getting old, so I want to put in some kind of dirt-cheap thermostat. Truth be known, I am not sure of how to rig it up. I'm assuming I need a 12-volt power source and some kind of relay that will turn the bulb on and off as needed to maintain a constant temperature. (I don't care if she has light, I just don't want her to deal with big temperature swings.)
So, can someone tell me the most cost effective way to do this, and how to wire it up? I guess I can find an old thermostat at a garage sale or flea market, but I'd buy them outright if they're cheap enough.
Sorry for the OT question.
Re: Utterly OT
Easy answer....
A little piece of lead, in one ear, from and .22 and she won't care what the temp is. NO! Wait!, that's for horses......
Use a baseboard heat T-stat. About $15, maybe $20, or better yet, I have some used ones (I think) and I will send you one. Send me your address.
They are set up for 220, but you could just use one side for the black (hot) wire or you could switch both sides. They are labeled 1 to 10 or what ever, but it would not take long to fiddle in an acceptable temp. After all, she has a fur coat.
You might put in two bulbs, one as a backup in case the other fails and you don't notice.
Re: Utterly OT
Re: Easy answer....
Bill Turpin in WNC mountains
Use a series circuit. Start at hot side of male plug (small prong) go to one leg of thermostat, leave the t'stat go to light socket, leave the socket and go back to plug. One big circle of single wire. There could be exposed terminals on t'stat that are HOT. Insulate carefully.
Re: Utterly OT
The other term for this thermostat type
is "line voltage thermostat." Any decent supply shop should have them, although Barry's price sounds best.
Re: Utterly OT
Moses Yoder
Great
Moses Yoder
Now if my wife sees this, she's going to put a cat house on my list. Really, a picture window. I thought our animals were spoiled.
Re: Utterly OT
Re: Utterly Simple
Ellis,
I have a dog that would be quite willing to help you end your problem. Total cost, one milkbone.
Tommy
Re: Utterly OT
When Done
Call HBO. This'll put a whole new spin on there Cathouse series!
Re: Utterly OT
Re: Utterly OT
Robin Corell in Atascadero CA
How about leaving the high watage bulb in and putting a standard light dimmer switch inline. I used to use a similar solutin for heating my gle pot. After a bit of observation you can even calibrate the backing plate with a fine line sharpie.
Robin
Re: Utterly OT
One problem with a thermostat, though *LINK*
This link may fail past today - if so, look for the December 8, 2011 cartoon.
But it's certainly apropos.
http://muttscomics.com/strip.aspx?m=12&d=08&y=11
Re: Utterly OT
Might call Lennox, include A/C  :-)
Re: Utterly OT
Re: Utterly OT
Dave Long
Messing around a cat house always seems to product problems
Re: Utterly OT
Re: Utterly OT
Tom Pilsbury (Chicago)
Do you think maybe an aquarium heater would suffice? Heater and thermostat all in one. I'm not sure if they have to be under water to work though.
Re: Utterly OT
how about a cheap electric blanket or heating pad
Dick Coers
both have thermostats.
Re: Utterly OT
Must be automatic
The temperature in the cat house changes with the time of day, the weather, outside temp, etc., so the point of this exercise is "set it and forget it."
Re: Utterly OT
Re: how about a cheap electric blanket or heating
I'm picturing a cat liking the temperature and doing that bread kneading thing cats to, claws out, and penetrating the wire insulation. I believe reptiles require a fairly narrow temperature range, which implies a thermostat.
Re: Utterly OT
Lizard/snake terrarium heater?
I don't know if terraria are heated just with heat lamps, or if they have separate heaters, but I would think the sort of pet store that deals in lizards and snakes might have some ideas about how to heat your kittie domicile.
Re: Utterly OT
A dimmer maybe?
Alex Grigoriev
http://www.amazon.com/Lutron-TT-300H-WH-Electronics-Plug--Dimmer/dp/B0000BYEF6/ref=sr_1_1?ie=UTF8&qid=1323378206&sr=8-1
Rated 300W
Re: Utterly OT
Re: Utterly OT
Ken Garlock, Collin County Texas
You surely are making a simple job into a major event.
Step one: bring up your favorite browser spelled Firefox.
Step two: enter the google search phrase "cat heating pad outdoor" and press enter.
Step 3: review the multiple pages of available outdoor cat heaing pads.
Step 4: select the pad meets your requirements.
Step 5: Order the thing.
Step 6: when it arrives, install in cat house.
Step 7: go back in the house, grab a refreshing beverage and rejoice in a job well done.
Google is your friend, as is Amazon..
Just friends helping friends,
Merry Christmas
Ken
Re: Utterly OT
PS, I you continue to use lights bulbs....
you should collect a few incandescent ones. They are being phased out of production and there may a time when you won't be able to buy them. CFLs and LED lights don't put out enough heat to help you.
Re: Utterly OT
Wow. I'll have to check that out.
Re: Utterly OT
Maybe she needs a lap pool, too
We could heat the lap pool with the aquarium heater and it would keep the rest of the place warm, like the coastal effect. Hmm, I wonder how cats feel about lap pools?
Re: Utterly OT
Re: Utterly OT
Ellis, if the bulb you are using is doing the job, keeping the house warm enough, all you have to add is a thermostat like this one - http://www.amazon.com/LuxPro-Line-Voltage-Thermostat-Cool/dp/B000E7BTFO. It is capable of running several 100 Watt bulbs - think it is rated at 12 amps (would run 12 - 100 Watt bulbs with a little safety margin). As to wiring, you wire the incoming line neutral (white wire) directly to the white terminal of the bulb socket, and the black incoming line (hot) to one of the two terminals of the thermostat. Then you have a black wire (jumper) from the second terminal of the thermostat to the gold screw of the light socket. If you want to add more bulbs for more heat you just wire the next light parallel to the first - add a black jumper wire from gold terminal of 1st light to gold terminal of 2nd light and white wire jumper from white terminal of 1st light to white terminal of 2nd light.
Re: Utterly OT
Way too easy Ken.
Don Orr
What-no playing with tools involved? Where's the fun in that? :D
Re: Utterly OT
Oh shucks, I forgot the table saw and 20" planer
Re: Utterly OT
Re: Utterly OT
PaulSV
I have made a few cat houses with light bulb heaters for some feral cats living under my porch, just so they don't freeze to death over the winter. I used this:
http://farm-and-pet.hardwarestore.com/111-618-stock-tank-accessories/thermostat-outlet-527340.aspx
It turns the light on when it gets down to 35 degrees outside, and turns it off when it gets up to 45. Not a thermostat, but, coupled with choosing the right wattage of bulb, it keeps the temps within an acceptable range. I looked at the thermostat in the link above, but it says it is "for cooling only"- I assume that means that it turns on when heat rises to and above the set temp. Not sure if the wiring instructions reversed that or not.
