THE WOODRAT IS BACK!
serious glue up question
eliot d
I'm fairly experienced , but this project is a little different. I made a speaker cabinet from 3/4 furniture grade plywood and cut all the edges at a 45 degree bevel so no end grain would show. The size is 11.25 x 13.5 x 24 inches. The piece really is fine furniture, of a sort, and I want all the edges to meet more or less perfectly with little or no glue out. It checks out perfectly as a dry fit. I know only three ways to glue up the long sides. ( The top and bottom would fit in easily last.)
(1)Tape the long edges with all four panels laid out and "roll" it up. I know small boxes are often done this way, but my cabinet may be a bit large for this method.
(2)Fashion inside right-angle and matching out side right- angle fixtures( as for picture frames) and squeeze long panels together two at a time with a small clamps against these fixtures.
(3)Hammer in very thin brads along the insides of the bevels, cut them off with a wire cutter so only about 1/ 32 " protrudes and then rely on these little "teeth" to keep the glued bevels from slipping.
I suppose some kind of rope-like jig would be useful, also.
What would you suggest? Other ideas welcome.
Re: serious glue up question
splines
Bill Tindall
You are tackling one of the most difficult tasks I have faced in construction. Most would have assembled the box and then veneered it. In your case you need to get the joint perfect to the thickness of the veneer (0.020" or less) for the corner to be perfect and leave enough face veneer to be able to round the edge a bit to make it durable. I am so skeptical of my ability to achieve this precision that I would never have attempted it.
Splines strengthen a miter and they can help keep the joint aligned for assembly. Whether they will be good enough for this task is questionable.
If it fails you can always veneer over what you have.
Splines would be a great choice....
roger lance
and you must have a table saw as you already cut 45s that line up well in the dry fit....so you have the tool to make the cuts for splines....another way is biscuits, but you probably do not have a biscuit jointer....so splines are a great solution.
RobCarr
Glue blocks along the inside edge of the miter. Not only will it give you some place to shoot a couple of brads, but will also give you extra gluing area.
Used packing tape..
McKay
I have used the packing tape trick for cedar chests. I am sure that I have done over 100 this way. If you use pins then it no longer is fine furniture.
Re: Used packing tape..
PaulSV
If you end up with a little bit of an open outside joint, you can sometimes run a round piece of steel. like a scraper burnisher, along the joint to roll over the two edges a little to close the gap. Splines or biscuits would be ideal, and dry clamp it carefully so that you know your clamping procedure will close all the gaps. You might even consider trying a few strap clams, with blocking near the corners.
Another option I have used (before I got a biscuit joiner) is to clamp a board at the edge of the bevel on a panel and a second board on the adjacent panel that butts against the first board. This can be done on all panels (8 positioning boards) then clamp the panels on the outside after applying the glue. Bit tricky to get everything aligned but will work. Biscuit joiner or splines probably are easier but at the time I didn't have the joiner and didn't think about using a spline.
Worry About the Table Saw Blade angle
George Colonel's Workshop-Havertown PA
Good Afternoon Eliot.
Good advice from the others. I use a Beale Tilt Box to insure my angles are correct, before I make a mistake in cutting. This assures me that any problem is caused by me. When frustration reigns, shut down the shop and reach for a proven hand tool, a beer bottle opener. Mine works every time. ;)
George
Hey Paul,
Good afternoon Paul,
Those clams sound good!
George
Re: Splines would be a great choice....
eliot d
I do have a biscuit joiner, and I did think about this option. I was a bit worried about the cut into the bevel on the board that has to be upright during the cut. It just occurred to me that I could clamp it upright to my table saw fence -- hmmm!
Re: Worry About the Table Saw Blade angle
eliot d
I just bought one of those digital angle meters( about $30) that attach to the table saw blade with a magnet. I set it at 45 then tested it out on some very flat MDF to see if four equal length mitered boards would fold up to an exact square. It worked perfectly!
eliot d
Sorry about the reply to my own post. But am I missing something? It just occurred to me that there may be a way to cut the biscuit slots both perpendicular to the beveled faces. I have to take a look at my biscuit joiner. Am I right?
Bill Tindall
you will need better precision from a biscuit joiner than I ever got.
roger lance
your biscuit jointer may have a fence that is made for this very purpose....it will be set at 45 degrees.
roger lance
also remember that you are not in a race....if you got perfect alignment in the dry fit, you could glue just one edge at a time and place the other boards in place as in the dry fit....then after the glue is dry, proceed to the next edge...etc...etc.
I never had much luck doing it that way...
John in NM
The few times I tried using biscuits they were a bit too sloppy for good alignment. I prefer splines.
agree biscuits worthless for alignment
roger lance
understand....I'm not advocating biscuits as the perfect solution....if, for some reason, you do not want the splines to show on the ends or some other consideration, then a few biscuits might work for you...again, I'd advocate taking your time....do one edge at a time....get that edge right and move on to the next edge....save your sanity.
Re:I Disagree biscuits worthless for alignment
I have had great alignment using my Porter Cable Plate joiner and Porter Cable biscuits. I had absolutely 0 (zero) movement and as perfect alignment as I could ask for. I didn't even have to "rake" the edge to correct for a small crack. I have done it on at least 2 projects in the last 3 months.
I also have the Porter Cable Plate Joiner and had joined things like this with no misalignment problems. And I have used splines. I CAN fiddle the splines into perfect alignment, but the plate jointer does it with ease. Just set the fence down at 45 degrees and put in 3 or 4 biscuits close to the heal of the miter. I'd use band clamps to pull it up with a little tweaking from bar clamps.
Another approach
My go-to method for gluing mitered corners is to use hardwood corner blocks, wax paper and band clamps. I use biscuits for reinforcement, not particularly alignment, at least not for something where I only have a few thousandths of leeway. Biscuits are supposed to be .152" thick, but I've always found that they vary by brand and moisture content, and besides, my biscuit joiners don't all cut uniform slots, or perfectly parallel to the fence for that matter. They're pretty close though.
I used to keep corner blocks of all sizes around for different length miters, from picture frames to boxes to cases. Some were kerfed out like the drawing below to allow the glue to squeeze out, others were perfectly square inside corners to help insure alignment. In any event, you'll want to use a rubber mallet to persuade the individual corners manually before you fully tighten down on the band clamp(s).
Re: Another approach
This is why Ellis is the Boss around here. I was going to suggest corner blocks but don't know how to post a picture of a hand made drawing and don't have a drawing Program.
Have recently acquired a cheap HF rubber mallet ad its a wonderful persuader and alignment tool. Just be sure to get one that does not leave black "heal" marks.
Any chance the wax paper leaves residue that interferes with stain or finish? I use polyethylene as in from a plastic bag.
eliot d
I believe this thread shows how good this forum is. I had forgotten about splines and had ruled out biscuits because I didn't understand that the cuts could be made on an angle. (I guess I did know it but never used that option and forgot about it.) I also learned about a new finishing product to reduce blotching and already bought it.) I will try out biscuits and try out splines on some test pieces to see how it works with my tools.
The plot for me thickens because I'm making this furniture for a dear relative in Georgia (I live in Maryland) who has limited wood working skills and tools and who wants me to send him the parts not finished nor put together so he can have the enjoyment of doing some of the project himself. (He tells me that he has two clamps.) So now it has become obvious that I had better talk him out of that and do the whole thing! I believe he will actually be disappointed, but I just don't see any other way at this point. Fine woodworking is too important to see it spoiled! This posting has been a good experience for me!
And another thing
If you set up the router bit perfectly, a miter-lock joint will give you the kind of accuracy you're after. That's somewhat of a big "if" though. Try one and see.
Tell us details about the speaker
Tim Greif - West of Chicago
I've made a couple and a past contributer here and years ago on Badger Pond was Terry Cain. Google Cain & Cain" and you'll see some of his work. Definitely fine furniture. He passed away a few years ago but his contributions to the speaker world are well remembered.
