Wall shelf completed - now how do I hang it?
Stephen Kirk
So, over a few weekends I knocked out this wall shelf for my wife to display some little curios. The plan is straight out of Fine Woodworking - I didn't feel like designing this time. Normally, this is made with all quarter sawn oak, but I used what I had on hand. It is mostly all 3/4" red oak. The columns are not solid but are mitered on the long edge. Shelves are just dado-ed in while the stretcher is M&T'ed.
The fun part of this project was getting over my fear of dyeing. I saw a lecture with Peter Gedrys a few months ago where he discussed dyeing and that it isn't that difficult. So, this project started with a coat of lemon yellow water based dye, moderately strong. At this point, I had a rather yellow project. I had very little grain raising, so instead of knocking it down I put on a coat of shellac, 2lb cut, clear. Then I sanded lightly. Then I followed up with Bartley's Dark Brown Mahagony gel stain (yeah, I still had some of that around!). I'd let it sit for a minute or two and then wipe it off. After it dried well, I wiped on 2 coats of Minwax satin poly - i figure it's a shelf and won't take much abuse so I'd only lightly finish it. I made a sample board, and if you just applied the stain, as opposed to the stain over the dye, there is a huge difference. My pictures can't do it justice, but dyeing, sealing and then staining really brings out the grain.
So, my last problem is how to hang it. I have some of the hangers that you mortise into the back which can accept a screw. However, the shelf weighs around 25 lbs and I'm worried about 2 molly bolts in drywall holding that. The columns are a distance apart that doesn't match up with studs. So, anyone have thoughts on hanging something like this? If you have any non wall damaging ideas, that'd be great.
