Fix for air bed (OT)
Larry in nw ohio
As in the subject I have an air bed, and it has a very slow leak. So the question is, is there an easy way to find a slow leak and how can it be fixed. Thank You
Larry in nw ohio
Re: Fix for air bed (OT)
Tom Dunlap
that is going to be a challenge!
After having two that leaked I stopped using them.
What I read on another 'slow, invisible leak' thread was that they usually leak from the welded seams. This is from either over-inflating or inflating then over-loading. Like any weld if the parent material is thinned during welding the weld is going to be weak. In typical metal welding there is filler material added to the weld. When sheet are welded the pieces are fused but no filler. This can lead to thin spots.
Windex is a nice solution for leak finding.
Once you find the leak/leaks you can patch it with available patch kits. The adhesive has to match the plastic. If you use an adhesive backed 'band-aid' patch be sure to radius the corners so that it doesn't peal later on.
A friend had an air bed with a built-in battery powered airpump. If/when the mattress would get squishy in the middle of the night all the sleeper had to do was reach over and hit the switch and get pumped up.
Good luck, those leaks can be evasive and recurring.
Tom
Larry in nw ohio
Thanks Tom. Can the patch kits be gotten most anywhere. But very good news for me, I found the or maybe a leak. It was where I kind of thought it could be, on the bottom. It actuall only took a couple of minutes, so got lucky. Looks like something was under the bed, like a stone or so, an make the hole. Now need to try the patching thing. Larry
A water bed store should have a patch kit.
Or you could use E-6000 adhesive (Walmart fabric dept.) and a piece of plastic. The one I had had a little platic tag on it that woudl have served the purpose.
Larry in nw ohio
Thanks Barry, I kind of thought you would chime in with an idea, I`ll go to Wal mart in a while and see if they have glue, and see if I can round up some sort of plastic, Thanks again.Larry
