Chainsaw Users *LINK*
This is an excellent chain grinder at a great price.
Grinder
Grinder
Tormek for chain saws and an alternative
Bill Tindall
I understand that something that seems to lead simply to success for sharpeners has a great attraction, especially if you are new at it. It must explain why there is a market for a $600 sharpening device for sharpening chisels and the like. However, the principal advantage of motor driven abrasion is speed of metal removal. While speed of removal could be important if the chain has hit a rock or the chisel was dropped on the cement floor, routine sharpening does not require much material removal, a fact perhaps not fully understood by beginner sharpeners.
So, the real impediment to sharpening is controlling the abrasion to get the relevant angles correct. Experienced persons can do this free hand but for others an effective sharpening jig leads to success. I find that the file holders from Stihl will enable even a novice chain saw sharpener to be able to quickly and reliably sharpen a chain, with the significant advantage of not needing to remove it from the saw. Additionally, hand filing will lead to much greater chain life because you will sharpen when you need to (dulling hastens when the teeth begin to dull) and I have seen that people tend to remove more than what is needed when power grinding chains.
The key to making the task easy is to secure the saw. While in the woods there are various techniques for holding the saw. At home I sharpen on my bench, a place where it will be easy to learn. I clamp the bar in a wood screw such that the chain is free to move and clamp the wood screw to the bench. Lock the chain with the chain brake and sharpen the alternate teeth that face away from you. For routine sharpening 3-4 file strokes per tooth are sufficient.
The Stihl file holder makes getting the file orientation fool proof. The metal plate establishes the depth of the file correctly and the angle marks on the metal helps to properly orient the file to the tooth (slight deviations are of no consequence unless you are in a chain sawing competition). Chains will last for years when hand filed.
Frugal as I am I find that the Stihl flies are good value because they cut faster and last longer than cheap files.
Pferd is my choice *LINK*
Tom Dunlap
After I found the Pferd file system I traded my Foley grinder to the man who ran a saw sharpening shop. He sharpened the knives for my brush chipper and did all of my circle saw sharpening.
Tim Ard does a great job of showing how to hand sharpen a chain.
Pferd and Stihl files are excellent!
Pferd system
Re: Chainsaw Users
Robin Corell in Atascadero CA
This is not a bad chain grinder but it will not produce professional results. When the original that this was copied from first went into production it had a reversible motor. As sold this sharpener does not have a reversible motor which would be fine if the motor tilted directions like on the expensive professional models. Without a reversing motor and only tilting in one direction this sharpener will put a burr on one side of the chain and not the other and this will cause it to not cut straight.
Because I mill with my saws I do have a greater need for accurately ground chains then the average chain saw user so I may be a bit more critical of this sharpener. That said I hand sharpen all my chains. I use an Oregon guide every once in a while if the angles or length of tooth get uneven, but mostly I free hand sharpen.
Bill is definitely correct about good files being worth the money, but they don't have to cost more. Pferd is a top quality German brand and I pay $13/doz from Bailey's. I highly recommend these files, if you are currently using Stihl files you won't be disappointed
Robin
thanks for the tip
Gees
I've been sharpening my chains for near 35 years, and somehow seemed to have avoided all the hassles you all point to.
I do mic my cutters to .001 and I take very little metal when I refresh my chains. They are balanced, run dead straight and smooth, and I'll refresh the cutters upwards of 25 times or more before discarding a chain.
I do, of course, take spare fresh chains when I have cutting to do, so no chain is forced to cut dull. I also vary my tooth angles depending on the type of wood being cut.
My grinder gives me precisely even cutters, and any slight burrs are gone after the first cut. It may not be a Silvey, but it works for me.
Same here
Jason Roehl in Lafayette, IN
...except for the number of years.
I have a slightly cheaper and slightly less versatile version of what you posted (I bought mine from Harbor Freight before they switched to the Chicago Tool and halved the price).
I see a chainsaw as a rough-cutting tool that uses a precision cutter. As such, I like all my saw teeth to be the same so that every tooth is the same length and taking a 0.025" bite.
The key to getting life out of a chain is to stop using it as soon as you notice the cutting performance begins to drop--you should get chips/flakes when cross-cutting, not dust.
I know there are plenty of experienced sawyers out there who have and do sharpen by hand with good results, but I think that if they stopped free-handing their sharpening and used a precision jig, they would get even better results.
I've amazed people who have been getting their chains professionally sharpened for many years. For one, I go by the motto, "As much as necessary; as little as possible" with regards to metal removal on the teeth. I'll also check for burrs and hit them quick with a flat file if they show up on the one side of teeth that are ground "outward".
Jason
Bailey's has free shipping till Dec 2
Bill Tindall
Use code "FSDEC" at checkout.
