REAL MILK PAINT
Bowed basement
Bowed basement
Bowed basement
Scott d
I know this is a woodworking forum but due to lack of info that I'm able to dredge up on the net I thought I'd ask some of you. I'm in the process of buying a house on the cheap ( ranch) that was built in 1967 and in the basement one of the block basement walls is starting to bow due to poor drainage ( house is a foreclosure and has Been neglected the last several years ) I was wondering if any one has installed soil anchors With the threaded rods? Where would some one buy these and how do you drive the rods out to where the anchors are? Anyone have experiences with doing this? There seems to be lots of adds for contractors doing this , but I think I can handle this ....it doesn't seem like rocket science!
Re: Bowed basement
Re: Bowed basement *LINK*
Tom Dunlap
Putting in anchors without fixing the soil bulge and drainage seems like a patch.
You have more information though so I'll stay on topic.
Search for "duck bill earth anchors" or look at the link.
Drving them in is MUCH easier even in sandy soil. You'll get a stronger anchor too because the soil structure isn't disturbed.
Earth anchors
Re: Bowed basement
Re: Bowed basement
scott d
i do plan on fixing the draniage issues as soon as possable
Re: Bowed basement
Re: Bowed basement
Larry in nw ohio
I had a neighbor fix his just a few weeks ago. He dug about 5-6 feet away from the house clear to the bottom of the foundation, then straighten the walls if you can. Some people I heard of putting a steel beam about like a railroad rail, against the wall and cut a hole in the floor to the dirt and cut a hole in the floor and put it in there to the ceiling and fasten it to the ceiling. Then put stone in the outside hole you dug. When you have the wall open outside you can do maintanence on that wall, like sealing it with whatever they use nowadays. Good Luck with it. Larry
Re: Bowed basement
Re: Bowed basement
Scott, Look up A B Chance Helical piers. They are a large metal anchor anchor mounted on a shaft about two inches square. The Anchor is a heavy metal circle that has been slit and twisted to be one "thread" of a screw about a foot in diameter. They use a "wrench" that is about eight feet long to screw them into the soil. They screw them straight down to support the house or out into the soil or straight out to hold the wall. They leave you a big nut and wrench and you gradually tighten them and may pull the wall back into plumb. The company engineers the systems and determine how many you need. Here in the Richmond, Va area a company called Stable Foundations represents the Chance company.
This represents the "dead man" approach. The old school method would be to go out in the yard and dig some holes and connect run rods or cables through the wall and fill the holes with concrete. once the concrete sets (28 days), you tighten the cables.
Is the inside of the basement finished? Are the walls coated with anything? How badly are they bulged?
There are ways to reinforce the walls from the inside if you can get to them. Some are well within the scope of a woodworker.
As a Home Inspector I see the blue walls all the time and the repairs. If you are interested, I will describe some of the repairs for you. (Got to go to work, so let me know and I will elaborate later.)
As a caution, DO NOT JACK THE HOUSE. Do not put in jacks or screw jacks to "support" the weight of the house while you work on it. Its the weight of the house that gives the wall much of its ability to resist overturning. I have seen well intentioned people put in a row of screw jacks for "safety" just inside the wall. They took the weight off the wall, the wall cave in and knocked down the screw jacks and wrecked the house.
Also, Be EXTREMLEY careful on the outside of the wall with equipment. Just driving a backhoe or Bobcat near the wall may create enough vibration and weight to cause the wall to collapse. DAMHIKT
Re: Bowed basement
Re: Bowed basement
Scott d
There is no coating on the walls and they are unfinished.the crack about 20 ft long is up about 5 ft. From the floor. Most of the fixes I have seen in my area use a threaded rod out to a anchor in the yard 6 or 8 ft. The crack is not bad at this time ,we have had a dry fall and I'm guessing that has relieved some pressure on the wall. I'm guessing it is 2 to 3 inches out of plum. I think if I remedy the drainage issues and use the anchor system in time I could get it stabilized /pulled back. I've found lots of company's that do this but haven't found where you can buy the hardware and how to get the threaded rod driven out to 7 ft. Or so.on some basement repair co. Website I've seen what looks like a really long drill bit?"??
Re: Bowed basement
Re: Bowed basement
Scott, 2" or 3" is huge. How wide is the crack? What is the walls made of? Describe the grading out side the wall. What kind of soil do you have?
If your wall really is two or three inches out of plumb this is dangerous and may be near collapse. This would be time to bring in the Pros.
What I am used to seeing is cracks in concrete block walls. The local walls are not reinforced and the long walls (front and back) have little resistance to buckling, only being braced at the corners. the walls develop a long horizontal crack near the center that spreads toward both ends. Near the ends, the end walls brace the corner and the crack splits and makes a "Y" with a crack radiating toward the top and bottom. Its folding inward like the side of a grocery bag that will fold flat.
At this stage the wall may have bulged inward an Inch or so.
The best fix for they would be to pull the wall plumb, closing the crack and then giving the wall the strength it needs to continue to perform. If it is as far out of plum as you say, it will be very difficult to pull it plumb without removing the soil on the exterior. This can be very difficult because of terrain constraints and damaging things like stoops, utility lines, and landscaping, both hardscaping and softscaping. So, some people think the "real" fix is to dig it up, straighten the wall, repair or improve the water proofing, improve the perimeter drainage at the bottom of the wall, strengthen the wall, and reinstall the soil, improving the surface grading. As you can see there are huge complications to this.
If your wall has moved inward a couple of inches stoops on the exterior might be ready to collapse.
Other approaches to walls that usually have less damage: Use the Dead man out in the yard and tie the wall to the dead man. For this you must find rods or cables and bolts etc. that are heavily galvanized or stainless so they won't rust away in the soil. And you must be extremely careful not to knock the wall down while working on it.
Another approach would be to reinforce the inside of the wall to give it the tensile strength it needs to resist the bulging. There is a system that uses carbon fiber strips bonded to the wall with epoxy. As far as I know, there's a proprietary system sold through franchises that are train to do the work. Another approach would be to use Block Bond or Sure Wall which are wall coatings that have fiber glass mixed in them. They are designed to be applied to dry-stacked block walls in lieu of laying them in the traditional mortar. Both of these methods require the wall to be clean and free of other coating like water proofing to allow for bonding to the wall. This also assumes the water proofing is functioning as it should and the wall is dry on the inside. If the basement is leaking it is a separate issue that should be addressed and may be fixed while fixing the wall. The very best fixes are done from the outside and books could be written on that topic.
Another way to brace the wall is to install steel or even wood on the inside. You could chop holes in the concrete floor, install vertical beams and anchor them at the top. With the top and bottom braced the beams can brace the bulge. You would need an Engineer to design this for you. The steel should be galvanized or otherwise coated to resist rusting.
Another approach would be to use wood to do the same thing. You could saw out a slot in the concrete slab parallel to the wall. Then install treated 2 x6's or better still 2 x8's with the bottoms tucked into the slot and the top bolted to each floor joist. The narrow edge would against the wall. In effect you have built a very well anchored 6" or 8" wall inside the basement wall and the basement wall would have to break through that wall to fall inward. The idea is that the new wall must press hard against the bulge. You could shim it as necessary. Once the studs are in place you fill the spaces between them in the slab with concrete. This would keep them from twisting.
Re: Bowed basement
PS, No matter what you do...
You need to fix any grading problems in the yard. The grading needs to drain water away from the foundation.
Re: Bowed basement
Thanks Barry
Al Goldstein
I have the same problem with a block wall in my basement workshop. I've had several contractors in for estimates and didn't think that I had been given complete information along with their expensive solutions.
Barry, your detailed explanations have taught me a lot and now I believe I have a handle on the problem and can deal with the contractors effectively.
You ask a lot of questions here at WC, but also spend the time necessary to give others good answers from the knowledge that you have acquired over time.
Thanks a lot for your help with my problem.
Re: Bowed basement
Well Al...
You are certainly welcome....
I actually like the OT questions here because I learn a lot from the huge knowledge base shared by the participants. I also like the high level of activity and the fact that responses come pretty quick. You mentioned I asked a lot of questions. Hope that does not imply I am hogging the band width or somehow abusing my presence here? Because I ask OT questions I also like to answer the ones I know something about, and I like to see them answered on the board rather than via e-mail because sometimes somebody else is reading along and benefiting.
The cracked basement wall is a multi-part problem. What is that caused the wall to crack? (Often sunken settled soil out side the wall is a clue. The soil may have settled because it was not properly compacted when the house was built. Sometimes it settled because the wall shifted and "made room" for it. ) If the soil has sunken and/or the grading is poorly established watter may run toward the house or worse, pond near the house. This could be a second part of the problem. The water wets the soil and could leak into the basement and it "liquefies" the soil while adding tremendously to the weight. Dry soil has an "angle of repose". Ever shovel sand onto a pile and notice there is a natural slope? The pile gets bigger, but the shape of angle remains abut the same. That geometry tells us something about how much pressure it exerts horizontally and how much vertically. So, dry dirt presses mostly downward and less sideways. Wet soil presses harder on the wall because the particles are lubricated by the water. Water presses equally in all directions and adds weight. A double whammy. So, its important for all those reasons the water be drained away. Establish surface drainage to divert the water away. Better to not let it get close to the house. If the basement is 6' deep, keep the water more than six feet away. (Think of it soaking down at a s 45 degree angle. IF it starts soaking further out than the basement is deep, its "under" the basement rather than in it.
If your basement is dry and the subterranean drainage is working you can move on to bracing the wall as discussed. If it is wet, you need to consider what to do about that. A very slight problem might be helped considerable by improving the grading. If you divert the water way on the surface, there is less available to put pressure on the wall. As mentioned above, be very gentle installing the soil around the foundation. A front-end loader rumbling around in the yard and dumping huge bucket-fulls of dirt near the house is dangerous.
The soil near house on the surface should be clay to help shed the water away, but that another whole chapter in this epistle. (Look up clay capping) You can take the grading a step further by cover the soil around the foundation with two layers of black plastic and then mulch. (Why two? Top layer protect the bottom one from UV degradation) Make sure the plastic slopes away from the house.
I could go on and on. Good luck with your problem. I bet those expensive contractors never mentioned the grading and drainage did they? (Its hard work and people HATE it when you dig in their yard. And there are some many things that can go wrong. Power lines, water lines, cable, phone, gas, and ??) OTOH think of those sunken areas as a funnel.
Re: Bowed basement
Re: Well Al...
Scott d
Thanks for the help... My wall probably is not that far out of plum I looked at it last week and it didn't seem that bad. We have had a very wet spring and I'm guessing that gutters overflowing and lack of grade has caused the soil to liquify pushing the wall in.the basement has been wet lately. But I think if I fix the grade /gutters I should be able the stabilize the wall.
Re: Bowed basement
Pin the wall
Pat Evans
Scott: I had the same problem in my house and because of a front deck and landscaping couldn't dig out in front of the wall. I had a structural engineer design a fix that he called "pinning" the wall.
We cut vertical slots on the inside face about mid level every few feet. These were just long enough to allow us to insert rebar both toward the bottom and top of the wall with sufficient overlap in the middle. We then filled each of those cells with concrete as well as filling the top 3 courses of the whole wall with concrete. A continuous 6x6 angle was bolted to the wall and to each floor joist. We also filled the top of the side walls and used an angle there also. The effect was to stiffen/reinforce the wall and transfer some of the hydraulic load to the side walls. Now, instead of the front wall taking so much load, the whole house is taking the load.
Re: Bowed basement
Question
Al Goldstein
How can you fill the top three courses of the block wall with concrete? The spaces in the wall are vertical and continuous from top to bottom.
Re: Bowed basement
Re: Well Al...
Al Goldstein
Barry
When I mentioned that you posted lots of questions I stated that you also posted detailed answers to others' questions. I meant this as a complement to you. WC is one of my favorite web sites because of the active, detailed contributions from the members.
You were right that non of the expensive contractors mentioned improving the soil grading around the house as a potential cause of my wall problem. One went as far as recommending digging out the soil 4 feet from the block walls, putting a double layer of water-proof membranes on the outside of the walls and then refilling. I now realize that when refilling this long trench the contractor would be properly grading the soil away from the house.
Since the block walls on the addition to my house were not properly constructed with rebar and cement every 4 feet in the wall vertical voids, there are all sorts of propagating cracks in the motar between the blocks. But I now realize that the bulging of the long wall was probably caused by a vegetable garden raised bed (framed with rail road ties) placed close to the house wall. My soil is clay, but I filled the raised bed with peat moss (I'm a city boy). When I finally removed the raised bed I left the peat moss on the lawn and it probably acts like a sponge absorbing rain water and then discharging it between the block wall and the clay. My wall is bulging 9 mm at the second course above the cement floor (with respect to the bottom course that can't move because it is trapped by the floor). Not a serious condition at present, but one to be stopped before it gets worse.
In the spring after all trapped water unfreezes I plan to have my third and honest contractor (he told me it was a minor problem and he would only treat the affected wall at a much lower cost) mount vertical H beams along the affected wall and fill the space between the wall and the H beams with cement. Also he will chip out the motar at the bottom of the two window wells and insert rebar and cement in one vertical void.
To solve the water problem a great landscaper I have will do the work. You were right that my basement contractor did not want to get involved with outside soil work. The landscaper will dig out the peat moss and fill with clay to the proper grade. He does not have any heavy equipment and he and his workers use shovels and wheel barrows.
This winter while I am removing old kitchen base cabinets from the wall to be repaired I will be making lots of design changes to my shop. I've worked there long enough to know all of the necessary improvements. Also, in cleaning up the shop I've already found several tools that were permanently lost and several others I forgot I even had. Damn garage sales!
Thanks again for your help.
Re: Bowed basement
Re: Question
Pat Evans
You stuff a filler (eg newspaper) down as far as you can, then pour concrete. Tough space to work in, but it can be done.
Re: Bowed basement
Scott and Al,
I had forgotten about using rebar as Pat has suggested.
The closer the rebar is to the basement side of the wall the better. You want something in that will accept pension on that side. As the wall bulges inward the inside face is trying to elongate or is in tension and the outer face is in compression.
If the block are deep enough, say ten or twelve inches you can do what Pat mentioned. The deeper or thicker the wall is the better advantage the steel has. A method I have seen used is to nail two 2x4's to the wall about 8" apart vertically. Break out t inner face of the blocks in between. Arrange the 2x4's so they are on each side of the cavities in the blocks, not where the webs are, so you can expose the voids. Position 2 half inch or 5/8" reinforcing rods vertically in the space about an inch in from the inner face of the 2x4's. Screw plywood to the inner face. Leave the plywood down from the top enough to allow you to pour your column. You can actually start with the bottom piece on and fill it and then add more as you fill. What this does is allow the steel to be inside the basement side of the wall. You have built a pilaster or vertical column. You could put on of these about every four feet. You could also make it thicker if you wanted to.
This system is similar to the one I described using treated lumber. Or you can use steel beams or heavy angles. The advantage to the treated wood is that it is tucked into the slab at the bottom and bolted to the floor joists at the top. If you pour pilasters, you are counting on the anchor bolts a the top to resist the overturning of the wall and the slab at the bottom to keep it from kicking in, but if there is a mortar joint at the slab I might kick in anyway.
The other thing I like about the treated wood is they become studs and you can wire the wall and insulate it.
On last point about improving the grading. It often works well and at least significantly improves the situation, but its not like fixing a leaking pipe. You fix the pipe, turn the water back on and confirm there is no leak. Fix the grading and you have to wait to see if its working. It may take awhile. Create as much slope away from the house as you can. Try for more than an inch per foot.
