MDF
Jack
I have a set of plans that call for MDF where this is a painted project with exposed edges plywood won't work however MDF is not available in this area is there anything I can use in its place
MDF
Jack
Re: MDF
paul in AZ
how about edge banding the plywood and then painting it?
Re: MDF
Jim Hoeller
Another option is joint compound. I used it on the edges of corbels made from MDO. They are under the eaves of my house and after priming and painting still look like solid wood after 6 years.
Re: MDF
I agree about he edge banding, but Have you really looked for MDF? Lowe's has it locally and there are a number of People that supply the cabinet industry will sell to you as well. Wurths Wood Group (formally Plywood and Plastics), Central Wholesale, Diamond Hill, Etc.
If you use MDF you should experiment with sealing the edges.. Glue size or shellac. Experiment and paint some scraps first. There is also MDO, Medium Density Overlay which is used in the sign industry.
Re: MDF
Robin Corell in Atascadero CA
out of curiosity where are you located? All the places around me that might have an alternative to MDF also carry MDF.
Dending on what the project is particle board may work, but the edges will need to be filled with putty of some sort.
Robin
Re: MDF
Doug Reynolds in Seattle
I took a class from Paul Schurch and he said you could also use Bondo as an edge treatment. If this is a painted surface on plywood I seem to remember reading one needed to treat the flats as well if the effect was to be a smooth finish and one did not want the wood grain to telegraph through the paint. Another reason to go with MDF.
Re: MDF
He's right, drywall compound works well. I have used it on pine shelving boards, just smear it on as thin as you can let it dry and sand at about 100 Grit. They don't look perfect, but much better than untreated ones. OTOH It is soft and provides essential no impact resistance.
If you use plywood you want to use a fine grained hardwood like birch. Anything coarser, the grain shows through badly.
curious......
Bill Tindall
where is MDF not available?
Re: curious......
Randy Johnson
My local home center for one.
I’m not positive, but I don’t think the nearest Lowe’s (Richmond, IN) does either. Several years ago I needed some for a project and the nearest place I could find it was Home Depot in Harrison, OH. This was after an unsuccessful trip to the afore mentioned Lowe’s.
I have no doubt that many Lowe’s stores do carry it. Just not the one in Richmond. This may have changed since competition, in the form of a Menard’s down the road, has entered the equation.
