Glue up on Arts & Crafts chair
Bill P.
I would have posted a picture but can't figure out how to reduce the file size. Anyway, I was just wondering how everybody glues up the rungs of Arts & Crafts and or Mission style furniture. I guess "to glue of not to glue" is the question.
Thanks Bill.
Re: Glue up on Arts & Crafts chair
Define
"rungs".
Do you actually mean "spindles"?
Or
Are you referring to "leg stretchers?"
Or
"Something else?"
I glue everything except door panels.
To glue or not to glue?
Those rungs (or spindles or stretchers) are integral to the construction of the piece and should be glued. The reason not to glue a part (e.g., a solid wood panel into a frame) is because its shrinkage or expansion will defeat the glue joint. You shouldn't avoid gluing just to save cleanup work.
Now, if you are talking about how to get all the rungs to hold still long enough to actually assemble the piece, that's a sometimes tricky puzzle and depends on what direction all the tenons are pointing, among other things.
If I'm missing your question, please be a bit more specific.
Ellis Walentine, Host
side slats
Jerry Gibbs
the slats under the arms of my Morris chair are not glued because they are not integral to the chair. The back slats and everything else is glued.
Re: To glue or not to glue?
Bill P.
This is the chair dry fitted together showing the spindles in question. I'm making this as a mate to the A&C style bed I made some time ago. The bed has 76 spindles and I did glue ALL 76 of them. There's a 6" wide armrest that goes on the sides and back. At least theres only 46 on the chair to glue.
roger lance
Bill....I made a similar bed that was a king size and had 46 slats in both foot and head boards. Those slats were fitted dry. I could not imagine the difficulty of attempting to glue in these slats and get them all square etc without losing my mind (not to mention temper)....for me it was impossible....just getting everything in dry was a real process. If slats are not crucial to the structure of the bed or in your current project (a chair), then there is no real need to glue them. The mortice/tenons of your rails/legs will do the real work. I would recommend that after your dry fit, you finish each piece individually and then make your glue up....that bed I made taught me that lesson.
Dave Bair, Eaton Rapids, MI
I will suggest you use a glue with a long open time; I use Titebond's liquid hide glue. I also try to break down the process so that I work with only half the joints at one time. But I guess you're pretty good with the process, my worst glue up was only 13 slats.
M&T Tip - whether glued or not *LINK*
charlie belden
When you've got a lot of M&T joints to fit together at glue up time, getting them all to line up can be a bit tricky, especially when the glue set up timer us ticking(tic-tic-tic). And if they all fit nice and snug, it's easy to have one misalign and the tempation to hammer the joint close - not a good idea.
Here's a way around both problems - alignment and splitting a corner. Takes a little extra time - on the front end. Can save a LOT of time - and aggravation - in the long run.
Another fun and games is dealing with glue squeeze out when you have a bunch of M&T spindles or slats. The glue squeeze out, even when "cleaned off" can make for problems when you apply a finish. Way around that is to use Waxalit. Developed to make tables of woodworking power tools slippery and keep sap from sticking to them. But it also keeps glue from sticking to whatever it's on. Dries white so you can see where it is afterwards so you know you've removed it all before applying a finish. Dried glue pops right off it.
A little goes a LONG ways
Lee Valley - Waxalit
