Help with resawing again....Please
I posted earlier about getting a good resaw blade for my 14" Delta BS with a riser block. I got a Wood Slicer form Highland hardware.
The saw is well tuned and the blade is running centered on the wheels. the wheels are coplanar. Got a good finance and it is set to the drift angle. Has an Iturra spring.
Tried sawing some 1/8" slices off some spalted maple. (worked well on 2" thick ash.) Then tried some 12" wide spalted maple. The blade wandered and got some barreling. Wanted five slices out of a 3/4" piece. Ended up with three. Feed rate seemed very slow.
What do I do now? Can anyone reliably saw 1/10" slices of veneer? Proceedure? I really want to make veneer.
Re: Help with resawing again....Please
suggestions
Bill Tindall
blades wander when the teeth fill up with sawdust and effectively you loose set, or you try to force the blade off its preferred track. Try glacial slow feed and as high a tension on the blade as the saw will deliver.
Do you have the lateral guides snug against the blade? You should not be able to twist the blade if these guides are sufficiently tight.
paul in AZ
I also have wasted some really nice wood on occasion. There are several culprits in this but I can't say which is most important.
Blade tension is one. I go higher on this.
Check and recheck the guides, specially those lowers that are a PITA to set up and easy to ignore.
Feed rate seems to have to be much slower than I would like.
After jointing two faces I use one of those magnetic featherboards to keep the bottom corner of the board tight to the fence. Keeps the wood from wandering and getting slices of uneven thickness.
A new, sharp blade always seems to be better than an older one.
del schisler
barry i used to use the woodslicer for a couple yrs. This blade from this co suppercutbandsaw My opion it out cut's the woodslicer. I am not saying you will get 1/8" cut's but you should. I bet what happen the teeth got full of sawdust and made the blade bow in the middle? Is it a 4 tpi and 1/12" wide ?that is what my blade is from this co. I looked at the blades only difference i see is the gullet is deeper on the blade from http://www.supercutbandsaw.com/ . that can make a difference. Now the cut is a little ruffer but you sand it down or plane? I do a lot of 2 3/4" resaw and make the box part out of that size. What i do is put the smooth side inside and than when i sand down the dovetales all of the box is smooth so the ruff side doesn't make a difference to me. On the veneer the ruff side down or up shouldn't make a difference you sand it down . They don't put a price on the web site call them and see what they have to say as far cutting 1/8" veneer. I have the delta usa made with the 6" riser about 18yr old and still going strong
Robin Corell in Atascadero CA
It sounds like the fence is not adjusted correctly for blade drift. Try free hand resawing a board of similar thickness and if it cuts straight then you fence definately needs adjustment.
Another thought is that most people adjust their guides with the arm down close to the table. It is worth a quick check to see if the blade guide arm is square to the table. I just did a quick tune up of a 14" j-line and that was one of the things that was way out of allignment. if you adjusted the guides with the arm down low and established the blade drift with the arm down low and then raised the arm but it is out of square it would throw every thing out or whack.
On some saws the arm is easy to adjust with a couple of bolts and on some you adjust the arm with set screws. It is also worth double checking the guides when you raise them up for resawing.
Robin
Jesse Cloud
Good advice above. However, 12 inches is pretty ambitious...
Might think about cutting smaller pieces and taping them together before veneering.
1/10th inch is doable. I usually slice to 3/32.
