Re: Kickback Physics
TomD
- They also just don't get much of a grip on the wood. If the wood gets into position to go, the teeth are quite likely to slip, because the kerf is fine.
- Also the board gets thrown at radial speed, in theory. Though my worst was as a jam to the fence. BUt anyway, radial on a small blade is less than on a large blade. Not if one adjusted to surface speed, but presumably people aren't bothering with that.
- Where jams to the fence are concerned, the blade is very lat flexible, so it gives a little.
- Also, you can adjust down on HP since you need only half the power. That is huge on kickback.
I have been using these blades for like 30 years. They were originally a big deal being sold in Jap. catalogs like Jap. Woodworker, but later we just used the 7.5 circ blades. Main reason was to reduce kerf, but did notice they were pretty easy to use. MY earliest ones were full diameter, in my case 9", but they were still easy.
OTHER STUFF:
- Saw power is way out of whack. I sold my 3HP, and use 3/4 - 1.5. I like a saw that I can win a fight with during kick-back.
- I like a small but high quality saw, that I can really dominate the playing space on. This is great for most solid wood stuff. Obviously if one is breaking sheets for kitchen cabinets that isn't going to work. If I did a lot of that, I might consider a wall saw. As it is, I get the sheets broken at HD.
- Learn the geometry, it is a lot more than spliters. Study the european approach, I think it is a) better ; b) more slated to small shops and solid wood (they still have apprenticeships in much of mainland euro; c) if nothing else, it's another approach.
None of this is really going to save fingers for the extreme newbies, and extreme lunchbucket crowds. They won't be able to get their minds around this stuff, and they either won't pop for the gear, or want to use it. There actually is a product safety issue here, and it would make sense to do something about it. Not my vibe, but for those whose job it is to make sure heart valves are sterile, it's a no-brainer.
I'm not a product safety nut, no bike helmets for me. But, if one has the job of drawing a line and representing the thousands hurt, it makes perfect sense to jump on this with both feet.
