Spray Gun Question
Spray Gun Question
Spray Gun Question
I have an old Sears Spray gun (about 40 years old). It has been sitting in my shop since about 1979, unused. I pulled it out, Cleaned it thoroughly and put it back in service. I have long since forgotten anything I might have known about using it.
It was working well, but has developed a drip. Very annoying to have it drool onto the piece. I have the ring and nozzle and a plastic inner ring soaking in lacquer thinner, cleaning them up thoroughly. Any other suggestions?
What pressure do you use to spray? I have a separate regulator for the gun. Spraying Deft Gloss from the borg. How much do you thin?
Re: Spray Gun Question
You Have a Leak
After you've cleaned the air cap and other parts, rinse with alc, then fill the cup with water. Pressurize (50PSI on a "straight" gun) and start spraying. Watch to see when you're developing the drips. Chances are you've got a seal that has dried out/cracked over the years. SEARS sold a lot of Binks knock-off guns back then, so you should be able to find parts without going to SEARS, who will try to charge you the price of the gun for a washer.
not clear
Bill Tindall
what is dripping? Odds are it is the seal between the cup and the gun. Solution is to buy the 3M PPS system of disposable cups if you intend to spray regularly.
I fought dripping cups for all the time I sprayed. The cup seals build up finish, get hard and leak. In an emergency I wrapped a tee shirt around the cup. Then I invested in 3M system and it has been wonderful. You can spray upside down with it. Only takes an ounce of solvent to clean gun.
To answer your questions. about 30 psi and thinning should not be necessary.
Mine does that sometime...
Dale Lenz
Wagoner gun, fairly new. I play around with the top adjuster, control the amount of finish going though the tip, I think. Very well could be a leaking seal(?).
Good luck
OK, So Here's the thing....
The plastic ring under the "nozzle" is cracked and broken. The leak is around the ring that holds it onto the gun.
I looked at Binks and Devilbiss guns and it looks more like a Devilbiss. I did not see what appeared to be a similar part in either one.
I am going to the Sears site and check it out, but I suspect it is too old.
What would you suggest as a new gun?
new gun
Bill Tindall
ck Ebay for Binks and Devilbiss. Son in law got one for $50.
Re: new gun
What type would you Buy? I have the type with the cup under the gun now but I don't know if there is something better.
What are you spraying
Finish type? Piece size? What's the SCFM rating on your compressor?
How much are you willing to spend?
Re: What are you spraying
I'd have to look, but the compressor is about 7 or 8 CFM. I generally spray lacquer. On furniture. Often small pieces like end tables and sometimes turnings, but occasionally larger pieces such as a chest of drawers. I would like to keep it under $200. This is a hobby.
I just spent a while looking on Ebay and they have endless gravity feed Devilbiss guns. I know nothing about gravity feed. Very few syphon feed guns that appears to be what I have now. The Gravity feed guns and a number associated with them like 1.4. I am guessing that is the nozzle size. What am I looking for to spray lacquer.
Robin Corell in Atascadero CA
One of the better guns for spraying clear coat is the old Binks Model 7, unfortunately your compressor dosen't put out enough CFM to power one. This is a gun that for years was the standard for many auto body shops and it puts out a lot of paint. As paints have changed and other better guns have come on the maket few have surpased the ability of the binks #7 at laying down clear coat.
Since you seem to do smaller projects perhaps a touch up gun would suit your needs beter than a bigger gun.
If you will only be shooting deft lacquer there is really no need to clean the gun after each use. When it starts performing poorly then pull the tip off and clean it.
Barry, I spray a lot of Behlen Qualalacq spraying lacquer - usually satin - although I sometimes spray a coat or two of gloss under the satin. I normally use a Binks, can't remember the number but it is a 707 or something like that. I have 3 or four guns I purchased at estate sales of various brands. I have used at least 2 of then to spray the lacquer with good results. Sometimes I thin up to 50% even though the lacquer is supposed to be ready to spray. By thinning and putting on several coats I feel I can get a more even finish. I usually rub the finish down between coats with 0000 steel wool - if I have any runs I use a block with 400 or so sandpaper to remove and flatten before re-coating. I would think the compressor you have would work with my guns since you normally aren't spraying continuously on large projects. Another thing, I did purchase one of the HF HVLP conversion guns - think it was around $20, it does work pretty well. I use it when I am spraying inside shelves, boxes, chests etc. as it doesn't "bounce" back as bad as the conventional guns. I leave the lacquer in the gun, and have left it as long as 3~4 months without any problem other than having to mix the "Satin" material as it settles out. You might look on Craigslist or Ebay for a Binks or Devilbliss gun as there are a lot out there at reasonable prices. At estate sales I purchased all of mine for under $25 each, some for $5.
