WC Weekend Accomplishments.......
Dennis E Peacock
7 Nov 2011
Good Morning,
The most recent news around my house is that the LOML and I are trying to loose some unwanted weight. We are using a free app on the iPhone called MyFitnessPal. This has proven to be a really useful tool for use and we feel that we are making some progress. We intend to loose weight slowly so the chances of keeping it off will be much higher....we hope.
The LOML and I have cleaned up the shop some more, but we've also been spending time getting things ready for our heating season, which means putting the wood rack on the back porch, bringing up the trashcans for kindling, bringing up and stacking firewood on the wood rack, and finally seasoning the soapstone stove for another seasoning of heating our home.
Two projects I need to work on that I will be getting advice on? Fixing a veneer bubble in the middle of an old piece that has been redone and fixing or remaking a carved chair seat. Both will be a first for me as well as a real challenge for me as I've never done either one.
Well, that's it for me, so what did YOU do this past weekend?
Best of weeks to you all.
Dennis Peacock
Re: WC Weekend Accomplishments.......
Stuart Johnson
I saw this done on one of the DIY shows so take it for what it's worth.
Make a slit the length of the bubble, force some thinned glue under the bubble, cover with a piece of wax paper and clamp a piece of scrape over the bubble or weight it down if you can't clamp. I don't remember them doing it but I would wax very heavy first so any glue squeeze out won't stick.
Larry in nw ohio
My weekend started early on Friday. LOML and I headed for Dayton, 100 miles away, Ohio to the VA hospital for a bunch of tests that I have been taking for 3 years. These are for a transplant that I pray I do not have to get. We got out of the hospital a couple hours early because I got some of the tests done early. We left about 1:30 for Jeffersonville Outlets and stayed the night there. I know there was a reason my wife wanted to go along. Well it wasn`t to bad, I got some popcorn, a guy sells it at the outlets, and I went back to the motel and ate. Next morning came home and got to work outside, 63 degrees, blowing leaves. Did that for 2 hours and started walking to the house and no more and got half way and the wind picked up and in 10 minutes I could hardly tell I did anything. So I need to do that again already. Sunday got into the shop and worked on the bar stools and bookcase and got another project a shoe storage seat. Thats about nit. Larry
It don't get any better......
Bill Tindall
Went deer hunting before dawn with my trusted traditional muzzleloader. Day was glorious with frost in the AM, clear and sunny later, and leaves still colorful. Was successful. Wife likes venison so she was pleased. So pleased she made sausage subs for dinner ,a favorite meal. .
To appreciate the significance you must understand that here in the culinary desert of E. TN. one can not find a true sausage sub. The sausage is imported from Utica, NY, cheese from PA. I make the baguettes. Peppers and tomatoes are from garden.
Executed a near perfect miter on molding for chest of drawers(more on this later), watched a movie and retired early......
A perfect day.
Thomas S Stockton
I have done what Stuart recommend usually on unfinished veneer. I think the wax idea is a good one I also use either wax paper or a baggie between the caul and table surface. It doesn't take a lot of glue and depending on the bubble I either put glue on a xacto blade and work it in or use a syringe. The only other tricks I use are that when I slice open the bubble I follow the grain and instead of having the xacto at 90 degrees to the surface I angle it a little and this seems to close up better.
Tom
Small Family Project
George Colonel's Workshop-Havertown PA
Good Afternoon Dennis,
This project took a bit longer to accomplish than a single weekend's effort. We got everybody together for a family portrait in the cold. However, the results are pretty good. ;)
The snow has since melted, and the leaves are now dropping from the trees. Our #7, 240# son Jim broke the rails from his bed and I began the patch/repair. Luckily, I have enough birch on hand to do each end of each rail. It was my parents' bed, and I want to do a good job in the restoration work. Small family party last night with only three kids and two grandkids. Enjoyed the weekend thoroughly.
George
Larry in nw ohio
I just happened to think, coulf you put a little tape on the bubble where you are going to cut and cut through the tape and veneer, that way if the glue comes out it`ll be on the tape. Maybe even put tape over all or most of the bubble that way the tape will catch it all. Larry
Garage Full of Cub Scouts
Robby Wright
Not very fine woodworking, but I had a Den of Cub Scouts over to work on their Rain Gutter Regatta boats. The boys were Tiger Cubs - First graders - and weren't very patient. I would have liked to get more hand tool work in, but we ended up roughing things out on the power tools for them. I was surprised that they didn't mind the sanding and actually worked at it until the boats were properly shaped and smooth. And then they packed up and left. Ahh, the joys of being a grandfather!
you have to feed them?
Bill Tindall
Handsome bunch of folks but I'd hate to have to cook for all them.
starting on the Christmas stuff
Charles Yawn
Got these "modern art?" reindeer finished for Christmas gifts. Still working on the ornaments and salt/pepper mills.
Very stylized
Yonak
Charles, are these your own design ? I like 'em. Somehow they look a bit like Odie from the Garfield comic strip. Maple & walnut ?
Re: Very stylized
Charles Yawn
Thanks. These are made from walnut and spalted oak. I used a template obtained from a fellow woodworker - compound cut on the bandsaw with a 1/8" blade.
I like the comparision to Odie; that's funny right there.
Charles
That looks awesome!!..
Re: Very stylized
Frank Orfanello
Charles,
Is the template something you could share?
I'd like to make a couple of those myself.
Frank
Re: Very stylized
Charles Yawn
Sure, send me your email address and I'll forward the template in .pdf format. It's too big to upload here and I don't know how to shrink these files.
Charles
wcyawn@charter.net
