WE MOVED...
An Idea, Maybe? (OT) Kinda
Larry in nw ohio
I just thought of a crazy idea, I have a new shed about 20 feet from the house, mostly for storage and finishing when I need to in the winter. Now the question, I have #4 copper leading to the shed for power, so I was wondering if I could put a generater in there and tap into the panel and would that be OK to run things in the house if power goes out. Of course I`d do all the safety things, Like throw the main of in the house panel. Also I wander if I leave the windows and doors close and open the stairs and run a fan to suck the exhaust out of the motor area up and out the attic area vents. Larry
Re: An Idea, Maybe? (OT) Kinda
Jason Roehl in Lafayette, IN
Not good enough.
Power companies (particularly their linesmen) don't like to see generators hooked up to a house without a transfer switch. It may even be illegal in your area. Promising to turn off the main breaker isn't good enough for them because there could always be that one guy that forgets. And when you put 240V INTO your side of the transformer that feeds your house, they get 7000V on the other side--all the way to any line that might be down, with enough amperage available to kill them.
Jason
Steven P. Bellner
That arrangement is referred to as "backfeeding" and is against code almost everwhere (or should be). You could do this, but use a transfer switch so the generator is physically disconnected from the main when it is operating. If you decide to backfeed and the main power comes back on, you may be treated to a spectacular light show at your generator, and you'll be down one generator.
As for putting an internal combustion engine in an enclosed structure, I believe that is also against most municipal building codes. You could install it outside with a small roof or awning over it, but the probability of exhaust vapors (e.g. carbon monoxide) killing you or leaking fuel causing a sturcture fire preclude the use of an engine inside a building.
Larry in nw ohio
Where can I get a transfere switch and how much are they. I`ll bet there are a LOT of people that do this without a transfere switch. There are hundreds of these generators out there and I`ll bet a lot without a transfere. I wouldn`t do it without being all kinds of safe, but I wouldn`t be afraid to bet the power compay has a way to check to see if there is power in the lines before they touch anything. Larry
McKay
I hired an electrician to put my transfer switch in. I have a covered plug on the outside wall of the house to plug the gen. into. I throw the transfer switch and wa la my freezer, swamp cooler, furnace and fridge will continue to work. I was amazed at the latest storm in the east. There was one guy that said that he had to throw food away because his fridge did not work. There was snow on the ground in back of him so I was wondering why he would not use nature to keep his food cold rather than throw it away.
Well lets see now....
Bill Hammond
I check the line for power, it's dead. I hook on to the line to make a splice and you start up your generator.......
I think it's called involuntary manslaughter.
And on another note, if you power the grid from your generator you will overload it and pop the breakers, wouldn't want to have to go out and reset them now would you.
There is always someone who will flip that main breaker on to see if the power has returned.....
Put in a transfer switch, put the generator on wheels and put a covered slab where you will hook it up. Then when the power goes out you wheel it over to the spot and plug the house transfer switch into it and start up. Throw the switch and you are good. When not in use you can store it in the shed to keep it dry and safe.
Many who do not install a transfer switch have an extension cord octopus that leads to all the important stuff and they just replug to the generator as needed.
Some history....
As a Home Inspector, 15 years ago we never saw a generator or generator hook up. Then we had a terrible ice storm and we began to see generators and boot leg hook ups. Some people used a bunch of extension cords. Some would back feed, probably through the dryer. This situation is very dangerous as others have spelled out. Then we began to see strange pig tail arrangements dangling from panels. Then we began to see legitimate transfer switches. A hurricane or two whipped them into a frenzy and we began to see permanently installed generators with automatic transfer switches. In some cases they were whole house units. Generally those units are connected to a large propane tank.
Many people shove their portable generator under the work bench and forget about it until the next storm. Might be three years later. They don't run well or at all on stale gas. The owner has failed to keep a supply of fresh gas and may have no way to get more in the middle of a storm.
Now I see trucks running around advertising Generator Maintenance.
Every year I hear about somebody killed by CO from running a generator.
So get a transfer switch and keep some fresh gas or at least some with stabilizer in it and do not run the generator indoors.
