OT Help w/ Lawn Tractor Screw fix
Gary Smyth
Several weeks ago the throttle spring on my 1450 Cub lawn tractor broke. When I took off the air cleaner assembly to fit the spring found the old carburetor gasket split. I removed three screws and replaced the old gasket with a new at that time. Today I found the new gasket in the driveway. When I checked the air cleaner cover, I found all three 10 x 32 x ½ gasket screws at the bottom. I thought that I Loctited them in but apparently not. Now I find that they are loose in their proper location. Only one holds well and the other two are very wobbly. I’m hoping not to have to search out a new, and expensive (old stock) carburetor (it's a 1974). Can I tap the screw locations to a different size? I have taps but not a bottoming tap. Do they make helicoils that size? Never done it before on a carburetor. Looking for suggestions how to make a fix so that I have three secure screws. By the way, I have to be able to remove them so permanent, permanent is not an option.
