Twist Bit Suggestions?
Let's face it, my twist drill bits are shot. Ok....so I abused them terribly....what's your point? Sharpening would help but at this point I need a new set. The old ones were Hanson HSS. What's out there these days that are reasonable cost and lasting performers?
TIA
Tom
Re: Twist Bit Suggestions?
Larry in nw ohio
Tom The last three sets I bought was off ebay, and they were excellent, but I made very sure that they were made in the USA, because I would ask before I would bid. Or you could go to sears.com and look on their site, I got a couple from there also, but make sure they are made in the USA, because they are starting to get some from outsidethe US. Larry
bits? we don't need no stinkin bits
Robin Corell in Atasscadero CA
Maybe instead of new bits you should consider getting a bigger hammer.
I have a set of brad points that I made as an apprintice, 3/16, 1/4. 5/16, 3/8, 1/2"- they are nothing special but those bits only touch wood and stay sharp much longer that way. for metal I have a miss matched set that I too should consider upgrading, and I will if my dad ever turns his back long enough.
To be honest.....
....the reason I don't want to break the bank on a new set is because I am hopeful someone will come out with an ajustable diameter laser beam drill.
Tom Dunlap
I've gotten great servicefrom the dewalt bits from the Borg. They come in a plastic organizer case too.
I just bought a Drill Dr so that I can sharpen them better than my freehand attempts.
George Colonel's Workshop-Havertown PA
Good Afternoon Tommy,
I am in the enviable position of using drill bits somewhat less often than many of you. Accordingly, I treated myself to a Drill Doctor which seems to keep my HF and HD bits reasonably sharp. The higher price twist bits are probably better, and may require sharpening less often. Either way, all bits need sharpening at some time, except the ones horses use as chewing gum.
George ;)
Colonel....
Thanks for drilling home a point with your bit of wisdom.
T.
I have been looking at one of the big sets with numbered and lettered drills. I have an older set of fractional drills that I've had forever. Well let me clarify that. I bought a set a very long time ago with the idea that when one drill bit gets unusable I go out and replace it with a high quality bit. Now after all those years I only have about 5 or 6 of the original cheap bits left. The rest have been replaced one at a time.
I do now have a drill doctor. I don't believe it gives me the same accuracy of cut of a brand new bit but it does sharpen them well enough for cutting wood. Anytime I suspect I've hit something hard or it just doesn't seem to cut as quickly I give it quick touch up.
Me too....by default
John,
I have a brad point set from Lee Valley. They stay in the shop and only drill wood. Then there is my "all purpose" twist set. It travels everywhere I am drilling something. Like pencils in a workshop....where do drill bits dissapear to? So I buy replacements. Unfortunately I am not smart enough to label the replacements. The tell-tale sign...they are the sharper ones. ;-)
Tom
Tony - memphis
I have had very good luck with Lee Valley bits. But I have also used the various Lowe's and HD bits for emergencies and they are fine too (Hitachi, DeWalt, etc.).
Tony
Larry in nw ohio
John Like I said in my post above, I get mine from Ebay or Sears on the net. I bought a 115 bit set a few months ago, made sure Made in USA. A very nice set, paid something like $50. I thought it was a good bargain and had all the Number, decimal and lettered. Larry
Jim Dillon
Thomas,
Like others, I have had excellent luck with the LV brad point bits. I keep them for the good stuff and am always impressed with them. I have an old, old set that, IIRC, I got as a freebie maybe 30+ years ago and they still work fine for noncritical stuff. Think they were called Woodtrend or Woodline or something like that. Anyhow, all my new bits, especially in off-sizes, are LV. Even have a 3/4-inch one that is a real hunk of sharp metal. My 2 cents.
Jim
