Lumber press?
Lumber press?
Lumber press?
Todd
Hey everyone,
A local sawyer has a log (about 3 ft long) with a large burl on it that I am thinking about buying. I was going to have it cut into 4/4 or 3/4 lumber, focused on maximizing the burl grain exposed. It's green though. I was thinking about building a press and storing it in my crawl space for a year. But I don't know anything about presses.
If anyone has a press design or other advice on this, I would appreciate it. Thanks!
Re: Lumber press?
Re: Lumber press?
Dick Coers
You will need to do some more research. Ventilation is a very critical requirement to drying wood. Too little, and everything molds, too much and it splits. Burls will move a lot, and I had one cut too thin. It warped so badly, it may be 3/8" out of flat. I've never seen anything about a press. I've heard of steel strapping used to hold a bundle together, and lots of iron on top to keep it weighted flat, but no help with a press.
Re: Lumber press?
Re: Lumber press?
Bill Tindall
I don't know what a lumber press is but if the surface of the cut pieces don't get dry quick it will mold, the sap wood quicker than the heartwood.
The only two ways I have seen burl used is either turning or veneer. How do you intend to use it? If you need veneer than have the sawyer cut it thick and then slice the veneer off when the pieces are dry.
Re: Lumber press?
About burls and drying techniques
As Dick says, wood is inclined to move as it dries, so it pays to weight it down somehow, while allowing air to circulate around it. The usual method is to put it on thin sticks and let the weight of successive layers keep the lower ones flat. Top it off with something heavy. We used to use old lead sash weights and miscellaneous chunks of I-beam and other heavy items on the top of the heap.
Burls are not commonly cut into lumber although they certainly can be. The grain in burl goes every which way, so it tends to move dramatically and unpredictably. For this reason, some kind of weight is particularly recommended during the drying process. The wild grain also means that the burl doesn't have as much strength as straight-grain lumber, and that it will want to move a lot in service, so you should plan to enclose it in a frame or otherwise constrain it when you design your projects.
Because of it's preciousness, weakness and tendency to move a lot, burl is most often sliced into veneers, which can then be glued to a stiff substrate such as plywood or MDF.
Ellis Walentine, Host
Re: Lumber press?
Re: About burls and drying techniques
Todd
Thanks fellas. I really appreciate the insights. Usually my lumber is stickered and air dried when I buy it, so this is a bit different for me. The press idea was to minimize the movement, in the same vein as the weights (threaded rod that runs top to bottom through the stickers).
My plan is to build a china cabinet with this log, using the burl grain for the doors and face of the cabinet. The rest of the lumber would be used for the side panels. It sounds like you guys think going the route of cutting a thicker slab and then resawing it to veneer would be best.
I did not realize the importance of air flow though. Would it be better to have the stack kiln dried after it's cut? This sawyer doesn't have a kiln, but I can probably find one. It would seem like having different thicknesses (along with sapwood and heart wood) could be a problem. I appreciate all your help!
Re: Lumber press?
Grant in Iowa
Todd,
How the log should be best milled is dependent largely on its size, and the size of the burl it hosts.
If I were to come across such a find, I would take the following direction:
-Attempt to determine the soundness of the burl and log by tapping on it and listening for voids. Determine the species and do some research on what burls of that species usually look like, and in what direction theyare best sawn. An internet search for whatever species it is and burl should yield some useful information in this area. There are burls that are all but unusable... cottonwood for example or rotten burls. Offer money for the log/ burl accordingly and accepting the fact that the beauty it may hold is a gamble at best. Offer accordingly.
-Milling: I would suggest once the best direction/ orientation to saw the burl is established, a test pass be made with the mill to establish the internal condition of the burl, and to determine which direction(s) further cuts would be best made. Generally, sequential parallel cuts are best to yield bookmatched pieces. Further, much beauty lies in the wood that joins the burl to the "normal" part of the log. In my mind, 2-3" slabs would likely be best. Such slab thickness allows the lumber to begin air drying while preserving enough thickness to allow almost any use of the wood going forward. You can resaw these slabs later as needed for use either as veneers, boards, or turning blanks.
Sticker and stack the slabs in a well ventilated building or outdoors. Weight them heavily under a cover of some sort. I place around 100 lbs atop each sticker column, meaning a stack of boards ten feet long will usually get six columns of stickers and get 600 lbs or so. Your "press" idea is intriguing, but keep in mind that it would mean regular adjustments of the clamping mechanism as the lumber shrinks throughout its drying cycle. Simple weighting of the stack right over the stickers means the pile can be largely forgotten as it dries.
It may be wise to coat the ends of the slabs and burls with anchor seal or a similar green wood sealer. opinions differ on this, but I have not heard of anyone say it will hurt. Coating the burl will greatly slow the drying process, and may not allow the rapid drying you seem to be hoping for.
Burls are not known to be dimensionally stable when cut into boards(my experience). Usually, veneers are either left as thick slabs, or are cut into veneers 1/8" or thinner(the latter shortly before use). This helps allow the wood to either remain stable or move with whatever substrate it is glued to. I will defer to more experienced woodworkers for further burl advice, and invite comments and corrections or cautions on this subject.
Kiln drying is often preferred by "modern" woodworkers, if only because it seems a prudent extra step. If you own a moisture meter, take readings of furniture within your home that has been in place for long periods of time. Your reading will depend on your climate control methods, your region, and the season in which you take your readings. In my area, people seem to want their lumber kiln dried to 6-8%, which is curiously at odds with the average moisture content of furniture in my home, which usually reads between 10 and 12%. Further, Kiln dried lumber doesn't stay at a given moisture content any more than air dried lumber does, so long term storage of kiln dried lumber while you await a project build means it ends up at or near your areas equilibrium anyway. There are benefits to kiln drying such as the ability to "set pitch" and kill insect infestations with high heat. Kiln drying should be considered, but is not necessary in most cases. I would submit that industry utilizes kiln drying more to speed the process, rather than to better the product. When Kiln drying a stack of lumber of varying thickness, it is common practice to dry the lumber at the recommended rate of the thickest boards in the stack. This means a Kiln operator may charge more for a stack of thicker lumber because it takes more time and (heat) energy.
My approach is to simply air dry sawn lumber under cover outdoors, and then once it reaches 10-12% moisture content(usually about a year for 4 and 5 quarter lumber, longer for thicker material), I bring it in to my climate controlled shop for further aging. I generally skip plane the lumber and then flat stack it as it comes inside. This further aging allows thicker wood to reach internal equilibrium, meaning the moisture content becomes constant within a given board. When selecting lumber for a project, the lumber is then selected and either stickered again or leaned against the wall for a week or two to allow it to equilibriate to the immediate humidity level within the shop. Of course I always build for wood movement, but I believe starting with lumber that is near my regions equilibrium is best policy.
But we are putting the cart before the horse here. Lets start with what wood species are we talking about?
FWIW,
Grant in Iowa
Re: Lumber press?
Todd
That's a lot of great help. Thanks Grant! The log is a red oak, a little over 3 ft long, 18" diameter. The burl wraps about 2/3 around the log. I've only seen pictures so far. I live in VA, so it can get pretty humid here. I could put the stack under my porch, where it is dry and there is some airflow. I would like to use the wood within 2 years. The kiln drying idea would speed things up, but I was thinking about that more from the perspective of if it would reduce some of the warping/twist risk. My primary goal is to get maximum yield of usable burl grain.
Re: Lumber press?
Robin Corell in Atascadero CA
If it were me I would pass but mostly becasue I think red oak should be used exclusively to make pallets.
As for burl wood my experiance is contradictory to some of what has been posted. I have been milling all my own wood for over 15 years but my experiance with burls is limited to a few walnut burls, a sycamore burl and a few small elm burls. As surprising as it sounds the sycamore burl was a huge disapointment and was less interesting than quarter sawn sycamore. The elm was actually more interesting than the walnut.
I milled a walnut log that had a couple of large burls and I chose to mill it the same as I mill everything, 2 1/4" thick, through and through. I did flip the cap cut and continue milling 1" slabs, more as an experiment than anything. I brought the 1" slabs into my shop and stood them on end to dry. I have actually had better results drying wood standing the freshly cut slabs on end but it takes more space so I usually stack and sticker the wood like everyone else.
My experiance with walnut burl is that the burl itself is actually more diminsionaly stable than even quarter sawn wood. If you think about it it makes sence becasues the grain is running in all directions so it should move the same in all directions. Also the burl is increadably strong, again this should not be as surprise since the grain is riunning in all directions at the same time, kind of like hyper-interlocking. Unlike true interlocking grain which does have a direction a burl lacks direction so when trying to do intricate joinery the edges tend to be a bit brittle and realy thin sheets act as much like short end grain oyster venneer as any thing else as far as strength goes. But take that same burl as a 3/4 board and it will out perform a non-burl board for strength. where this all falls apart is with the wood surounding a burl. The burl shrinks much differently than the wood around it and something has to give. this results in some wild warpage and even some nasty checking.
Again this is only my limited experiance with a limited number of claro walnut burls.
Robin
Re: Lumber press?
Red oak burls may have a fair amount of bark.
Dick Coers
I have only seen one good oak burl, and it was white oak. The other oak burls have a fair amount of bark, and not the really nice limb bud type of pattern the comes with maple. They do have a lot of swirl grain in them, so will still be pretty. I suggest you look for a supplier of Tim-bor insecticide if you want to put it under the porch.
Re: Lumber press?
I have built a press
Barbara Gill
It is simple for a small amount of wood. Get some 4x4's some all thread and some large wing nuts to fit the all thread.
Plan on stickering the boards every 18". You will want to have a line of stickers at each end of the stack so to keep the ends of the boards under pressure.
Drill the 4x4's in 3 places so there will be a rod going through the stack on the edges and up through the center of the stack. put the first 4x4's down on the floor with the all thread in place. I would start stacking the wood on stickers placed on the 4x4's. When the pile is stacked, put one more layer of stickers and then the other 4x4's, running the all thread through. Use the wing nuts with washers to put pressure on the stack. If you don't want to use wing nuts, use nuts, etc. Evenly apply pressure and then check the stack occasionally and tighten as the wood dries. I wrote this in a bit of a hurry.
If you have any questions, let me know.
