Chain saws and stumps
Dustmaker Mike
Well a few weeks ago I pulled a River Birch stump from my front yard. Lets just say it was a lot bigger then I figured and it took longer to pull it then I figured it would, even with a termite digger. Well Monday I started pressure washing the dirt out of it so I could use the chain saw to cut it up into a lot smaller pieces. Monday I sharpen the Poulan 14" chain and start at it. I get a lot done but the sun decided it was time for me to stop working for the day. Yesterday I adjust the chain sharpen it again add gas and oil and away I go. The cutting started to get harder the closer to the core I got. I also noticed the bar would not track straight it wanted to drift to one side or the other. I figured it was a dull chain and a really hard stump. I did a touch up filing of the teeth and went to start cutting again. Then it happened, I watched as the saw just bounced off the stump. I shut down the saw to see what was up when I noticed the Raker teeth are higher then the cutting teeth I guess I sharpened it a bit to much. I will be getting a new chain today on my way home from work. Then maybe I will grind the raker teeth down or just recycle the chain. Lots of Fun around my driveway.
Re: Chain saws and stumps
Moses Yoder
Moses Yoder
In this area small engine repair shops sharpen chain saws with the tools to do it right. That means grinding the rakers down the right distance and grinding the teeth.
Larry in nw ohio
Yes Mike you need to also grind the rakers each time you sharpen, just so we`re talking about the same thing, the raker is the little "bump" in front of the tooth. ALSO when the saw is cutting sideways, at an angle, take a little square, if you have one :D , and put it on your bar and see if the two trakes where the chain rides in are straight with each other. If not take a file to them and square them up and make sure the chain isn`nt to sloppy in the trake. Good Luck. Larry
Ken Oakley-Sunny St. Cloud, Fla
Same here--The Stihl dealer charges $4.00 to sharpen any chain. Also there is always a box of sharp chains people never picked up and they sell them for $5.00
I always have a couple sharp changes for each of my saws.
Jim Rahbe, Bedford Texas
Chain saw blade/chain question - Hijack
I noticed that when I cut something, even with a new chain, it is never as quick as what I see on TV. I have always used the Low Kickback style of chain that came with my saw. Do regular (non-low kickback) chains cut any faster? If not, what is the advantage of using the “Professional” chain over the low kickback version? As long as you are not cutting near the tip of the bar, is there really a significant increase in the likelihood of a kickback if using the professional blade?
Thanks,
Jim R.
Re: Chain saw blade/chain question - Hijack
Dick Coers
The low kickback style do cut slower. They usually are ground to take a smaller chip, I never buy them.
Dick Coers
Oh man, a new chain going into a stump. That is going to hurt when you hit more foriegn objects in there, AND YOU WILL! You will want to keep an eye on the bar too. You can run some sand around the bar when cutting, and you may be making a groove in the bar, or wearing it unevenly. DAMHIK I once cut a slice off a palm tree to get those crazy root tenacles. Cost me a major chain sharpening, and bar wear. I square up the face of the bar on a disc sander. Works great. I also never cut stumps anymore. The last one I hit dead center on a 2" diameter rock and took off some teeth on the chain. If you really want some fun, try cutting that stump at night. All the sparks coming off the chain is kinda pretty like!
Keith Newton
Mike, unless you know that there is some fabulous wood in that stump, I would advise abandoning the idea. I have sawn out some big wLnut stumps before, and ruined a bar plus about ten sharpenings.
The best figure is on the top of the largest root buttresses. Those roots down in the bottom are not worth anything.
FredD
Get yourself a "Full Chisel Chain" and you will be amazed at the difference in cutting speed.
Low kickback chains are no substitute for paying attention to what you are doing with a Chain saw.
FredD
All Done
Dustmaker Mike
I got a new chain this afternoon on the way home from work. I pressure washed the dirt out of the stump before I started so it was pretty clean. I cut enough off of it so I could lift it into the truck and get rid of it. It is in the back of the truck and the rest of the roots I cut with my sawzall I did get some good pieces I may be able to turn when I get my lathe set up again.
The chain saw is old and the bar was on the end of life side so I didn't hurt it to much. I will take the chain to a good sharping shop and get a good bar while I am at it.
Later All
Jason Roehl in Lafayette, IN
There's no replacement for displacement...
Also true for chainsaws. More HP means you can get more work done. I have a Husqvarna 372XP (pro-level saw). It came with a 20" bar, and all other 20" saws I've used don't hold a candle to it. That's because many consumer-grade 20" saws might come with about a 50cc engine on them and run maybe 3.5 HP or so. Mine is over 70cc and runs about 5.3HP. With a freshly sharpened, square-chisel chain on it, I can use the dogs to lever it into the wood without it bogging down. Using the same type of chain on a lesser saw, I've had to hold the saw back.
Now if you're talking about the Lumberjack competitions, even the stock saws they use are pretty high-dollar and large displacement. The "hot saws" are all custom-built and in a whole different league.
Jason
Larry in nw ohio
Last year I bought an Echo 270 w/14" bar and low kick chain and it runs through a log like a raped ape. I can not believe how fast it cuts through a log and I also noticed that the chain lasts longer than they use to, do they make the teeth a little harder than they did 20 years ago?Larry
Soooo much to say....
Tom Dunlap
My laptop is in for repAirs so I'm thumb typing on my phone :(
SAw bars rarely wear out. They can be dressedand the rails
Straightened eAsier than sharpening chisels or turning tools. Chain saws Are NOT precision cutting tools.
Lots of myths about depth guages/rakers
The chain shRpening tool I use is mAde by Pferd. it has a flat file for
Rakers and round for the tooth.
Google: Pferd
Google: tim Ard or Forest ApplicAtions for great tutorials
Re: There's no replacement for displacement...
FredD
And you can't buy the chain used in competition, every guy has his own grind .
FredD
One of your statements bugs me a little...
"Chain saws are not precision cutting tools."
I'd agree that they are not used to make precise cuts on the level of a planer or tablesaw, but I see a chainsaw as a precision tool in how it operates. That is, precisely ground teeth and rakers are necessary for optimal operation. Even one or two teeth that take a smaller bite because they (or their associated raker) are misground can make a noticeable difference. Also, considering a typical cut depth is 0.025"--I'd say that's pretty precise. Never mind the dimensions and tolerances inside the engine. ;)
I have one of those chop-saw-style grinders, and with its depth stops, I can sharpen all the teeth, then use a depth gauge to set it to grind the raker teeth to a consistent depth. It's pretty quick, and I've done a few chains for friends who normally get theirs professionally sharpened, and they like the results better. They've also commented that I don't grind as much of the tooth off (I'll warn them if the teeth are really rounded and I do have to take quite a bit off).
Jason (itching to use his saw on that ash tree out front...)
Re: Soooo much to say....
I have to agree with you Tom. I heated my home exclusively with wood for over 7 years (2 story 4 bedroom/2 bath 12 foot ceilings down). When I started it was not insulated and had leaky windows and doors so burned between 14 and 20 cord first year down to about 6 in last year I heated with wood. Really gave my chain saws a workout. I sharpened all my saws with a clamp on jig and file for over 5 years. Usually lowered the drags below the plate gage I used to get a bigger bite. I purchased Jonsred and Olympik (not sure of spelling) saws ordering them with undersized bars - saws rated for 20" I ran 16", one rated for 48" ran 36" bar so had plenty of Horsepower. I later got a chain grinder - then lowered drags with a Dremel. Never had any problem and have cut up to 8 large pickup loads in one day with 2 cutting and 3 loading/transporting/unloading. Can't do it any more due to back issues and hip replacements, but still have saws and my sons and grandsons use. I think I replaced one bar in over 10 years of cutting. One big thing is that I did all maintenance at home - cleaned sharpened, tuned up, made sure oiler worked well etc. - before we went to the woods. During this time a friend always worked with me and we cut his wood also, using my saws. My youngest son was in his teens and sawed with me, I made sure he was always safety conscious and during all the years the only injuries were due to cuts during sharpening or carrying a non-running saw + (few smashed fingers and sore backs) nothing that required a doctors visit.
kickback and chains, and other editorial
Bill Tindall
By way of back ground I cut timber professionally for a short time( and other than learning to use a saw it was an especially dumb choice). I currently own 2 professional Stihl saws and a better consumer grade small Husky that is light for packing.
There are three kinds of chains commonly available- "safety chains with less kick back potential, semichisel and full chisel.
If you don't have a powerful saw and/or don't need to cut a lot of clean wood forget the full chisel choice. The semi-chisel dulls slower in dirty wood. Unless I am felling trees semichisel is the chain I use the most because it stays sharp longer in the stuff I typically cut. There is a safety chain on one professional saw and I don't see a remarkable difference in its cutting speed vs a semichisel. Hence, unless you have a compelling need to avoid it, use the safety chain. Personally I don't experience kick back, I suppose because I subconsciously know how to avoid it. But son-in-law came within an inch of cutting his toes off so the safety chain got installed on one saw.
The RPM and HP of the saw will have a much greater effect on cutting speed than the chain choice. However, too large a saw and it becomes work to lug it around and lift it for limbing. I would have to be cutting big stuff frequently, or felling trees to consider anything above a 3 to 3.5 cc engine. And, engine rpm is important. The modern high speed engines cut circles around saws of 30 years ago of the same displacement.
Additionally, the width of the teeth is important. I have a good consumer Husky with a more narrow chain than my smallest professional saw. This Husky cuts nearly as fast in spite of its smaller engine. For small jobs the Husky has become the saw I am most likely to pick up. Well, the fact it starts easier than Stihl also is a factor. Another reason to hate my government and EPA. Like chain saws are a significant source of pollution!
And finally, buy chain saw chaps. My neighbor cut his leg and bled to death before anyone could save him. They have become cheap- $70 from Bailey's in CA. I don't start a saw with out suiting up. They are sized strange. Order by measuring from top of shoe to belt, not crotch.
Another reason to hate my government and EPA.l
Dave Bair, Eaton Rapids, MI
I guess I missed your point; you were praising your Husky as easy-to-start as compared to your Stihl. Did the EPA make your Stihl hard to start?
In a nutshell, yes.
Assuming his Stihl saws are newer, then they do comply with some newer EPA emissions regulations. Unfortunately, emissions controls do not scale well to smaller engines, and the small engine market does not have the sheer number of dollars available to do R&D like the automotive industry.
I'm sure the EPA absolutely hates chainsaws. For one, they're mostly 2-cycle by necessity* (some electric and hydraulic, of course). Two, they probably also don't like their primary purpose.
*Two-cycle engines get almost twice the horsepower out of the same displacement as a 4-cycle engine (major weight savings), and because the lubricant is in the fuel, they can run in virtually any orientation, whereas 4-cycle engines generally have to remain close to upright, unless they have a special lubrication system that would be more complex (tough to do on a small engine) and heavier.
Jason
yes again
Bill Tindall
And more yes. The reason any small engine starts harder and has more gimmickry to get it started is EPA emission regulations for both the engine while running and the engine when not running(evaporation). At least we are not required to use biodegradable bar oil.....yet. A complete waste of regulatory and product design effort for no measurable benefit.
Kneale Brownson
There is a guide available for leveling rakers
