Split chair seat
Split chair seat
Split chair seat
Joe in a Cleveland suburb
Hello.
My daughter brought home, for me to fix, a chair she is using at college. It's similar to the one pictured here:
It's nothing special, but she asked me to fix it. It split right down the middle. It appears to be a glue joint failure.
Would something like Gorilla glue work for this? I've never used that glue. I'm not sure I could completely dismantle it and use biscuits or something.
The bottom of the seat is flat. I thought maybe I could do a dovetailed key kinda thing, but I've never done that before. Not even sure how...
Any suggestions for a quick fix? She comes home this weekend.
Thank you.
Re: Split chair seat
Dick Coers
If the failure was on the glue joint, I suggest epoxy. I suspect that Gorilla glue would require fresh wood pores to work, just like Titebond.
paul in AZ
as a guess I would think that if you can clean out the split you could reglue and clamp it. If you can't pull it together with clamps you may be screwed -short of taking the whole chair apart.
If the underside is flat you could use a strip of plywood glued and screwed to the underside to help hold it. Butterfly keys on the seat surface may be overkill but the decorative effect would make it worth doing.
George Colonel's Workshop-Havertown PA
Good Afternoon Joe,
I've fixed my share of split seats. I favor Titebond II over gorilla glue, which would also work well despite all the foaming. As the seat is split, I'd double some medium sand paper and scuff sand, inserting the doubled up paper between the seat halves. Clamp well and get even pressure across the seat and make sure the seat halves are on the same plane. Your idea of butterflies has appeal since they would give the chair more of a family story. Installation on the flat bottom of the chair would not be a problem. If you do it on the top, you may have to contend with the scallopped form the chair may have already. Possible, but a hassle beyond worth of a salvaged chair. I'd go with the glue by itself, as it would provide sufficient strength. My repairs withstood several 200 pound + sons and didn't fail.
George
Probably a PVA glue (like white or yellow glue). To get a good bond, you'll need to scrape off the existing glue; otherwise, you're gluing to glue. And scraping off glue that's gone into the pores of the wood's not easy.
Really bad klugey fix: in addition to gluing it, you could get a high grade 1/4" plywood* and glue/screw that under the seat, holding it back from the edges so it's not visible. The larger the size, though, the more holding. Watch the wood thickness, which will vary, as far as length of screws. Scrape off any finish where you're gluing.
A couple of dovetail keys (aka butterflies) underneath would help and be more elegant: cut out the stock for the keys**, trace around them, rout slightly less deep than the thickness of the keys (check to see how much wood you've got there: the center of the seat is thinner than the edges), glue, plane/sand flush.
Alternatively, go to the store that sells new ones...
A lot depends on how much time you have.
*When I say "high grade," I'm thinking of maple or birch. This is sometimes sold as "craft plywood" in model stores at obscene prices, but in the size you need rather than a 4x8, so the savings in gas not having to roll out the pickup truck could make it worthwhile. I don't know (never looked) if the box boxy stores sell it.
**The magazine articles always describe complex ways to cut out these keys, but, really, all you need is something with a narrow waist. They don't have to be symmetrical for reasons other than appearance; knocking them out on the bandsaw/scrollsaw, or even cutting them out with a coping saw, should be fine, as long as they're straight enough to facilitate cutting out the housing that will receive them.
Last one I repaired for my Sister was pretty old and had been glued with hide glue. You might test to see if your chair was the same (hot water will re-activate the glue and make it "tacky"). If it is hide glue, you can re-glue it without much hassle. If you don't use hot hide glue, buy a bottle of liquid hide glue. Clean out the joint to remove any loose derbies, apply the glue and clamp. Hide glue is one of the very few glues that will adhere to itself (even after years of use) and the joint should be as good as new. Right after clamping, you can clean off any excess hide glue with a damp, (not wet) towel or rag.
I'm with the Colonel on this. I suspect that if the chair is factory made sometime in the last thirty years there is a strong possibility it was glued with PVA glue. If you can get the joint far enough apart to slide a piece of sandpaper through it, you can slide it through the joint either doubled up and clean both sides or first one way and then the other if you can only get a single thickness in there. Be careful to keep the sandpaper flat and not allow it to roll the edges over. Once it is clean(ish), glue it with Titebond and clamp it carefully.
I fixed a set of about six for a friend that were painted white. They were in bad shape and I sanded them, removing about fifty percent of the paint with the understanding they were going to repaint them. They liked them with significant wood showing and left them alone. To each their own.
their are 2 kind's of gorilla glue
del schisler
the one that look's like syrup will form. The white will not foam. I use the white kind . Unless you can stay on top of the glue and wipe it. Now it will not clog up the sanding belt's. That is one good thing. But you have to be able to sand. Now another thing keep it off the skin. It will turn brown and have to ware off. One the glue has set up or harden nothing breake's it down. no solvent. That is the brown type. Now the white style if you get it on your hand use water right away and it will wash off . I have been around this glue ever sence it first came out I have a leter telling about it from the company when it hit the market. Good glue Maybe not the best for certian item's ???
Jesse Cloud
I'll put a brown paper bag over my head from shame and suggest a trip to Walmart to buy a new one. Cheapest and most dependable approach so far...
Dale Lenz
For a college chair that may get the dumpster after graduation, I'd do the epoxy reglue and the plywood scab under the seat if possible.
LOL!  Best one yet
Thanks all for the replies...
and suggestions. I decided to take the easy route. I was able to spread the seat apart enough to get a piece of sandpaper in there with a piece of flat scrap and sand it. Then glued and clamped it. It should hold for a while longer I suspect.
My thought of doing something like a butterfly key or something was over engineering/overkill.
Thanks again.
Screw It?
John McGaw
Do you have a Kreg jig? I'll bet scraping the joint clean, applying some epoxy, and then applying a half-dozen screws into Kreg jig-generated pockets would hold it.
Re: Screw It?
Larry in nw ohio
Joe As John says I think I`d put a few Kreg type fastening in there and that would hold for sure, a little over kill doesn`t hurt. I wouldn`t want it coming back sometime in mid winter. it would not take very long and if you do not have on I may have a single hole Kreg I could lend you. I even made a crude one that you could drill a 1/4" hole and drive a 1/4' dowel in the hole.Larry
I have a Kreg jig and
may go that route if needed.
Thanks.
Charlie Lenz
A few years ago I refinished an old Caboose chair made of oak for a friend of mine that has since passed away. What I thought that was really neat about the chair was the front and back edge of the seat ( end grain ) had an aproximatly 5/16" spline dadoed into the chair about an inch and a half into the front and back edges. the grain of the splines at 90 degrees to the grain of the wood in the seat. Following me ? Not only did I think that it looked good and gave the chair some character, it was good engineering.
