Gear advance box joint jig *LINK*
Michael Donaldson
Michael Donaldson
Not sure if I would have any use for this, but I think it's kinda cool.
http://woodgears.ca/box_joint/plans/index.html
Re: Gear advance box joint jig *LINK*
Does WC get a commission for this?
Neat mechanism...
John in NM
But... was it really necessary?
Bruce, a MN Galoot
Matthias Wandel is an engineer by trade, one of the originals in RIM (Research in Motion), the guys who created the Blackberry. He retired from that outfit a couple years ago and devotes his time to inventing stuff like the box joint jig. He has a YouTube channel, and from his appearance he can't possibly be over 40.
Take a wander through his web site. He's made some pretty amazing stuff.
Lynn's Box Joint Jig is simpler *LINK*
Craig Daymon
Well, to build. And it works great. I think it is basically the same design as one presented in Wood magazine many years back and is in one if their compendium books of jig plans. (Besides, I personally think threaded rod is greatly under utilized in - magazine plan - jig making.) Also, I question the long term durability of the wooden gears, but I guess that is a replaceable part.
Still, a pretty cool jig and site. I like the wooden camera stands.
-Craig
still too complicated...
John in NM
google "simple box joint jig", it's about as complicated as the wheel. :D
Jim DeLaney, Austintown, Ohio
Re: Lynn's Box Joint Jig
That one was actually published in one of the magazines about twenty years ago. Might have been Woodsmith, or Shop Notes, I dunno...
Anyway, I built it, way back then, and am still using it.
So long as your dado stack is exactly in 1/8" increments, it works perfectly - just count the turns of the 3/8-16 lead screw (rod) and your box joints will be dead-on. Not so good if the dado stack is off, because the error will get compounded with each advancement of the screw, or els you'll have to very accurately guage the fraction of a turn you'll need for each advancement.
Recently, I got the Freud box joint blade set, and it is dead on ¼", so the combo of that blade set and the jig makes the joinery easy.
Craig Daymon
You are talking about the one John mentioned, right?
The whole idea about using Lynn's is that you don't have cumulative error that is frequent in simple jigs. You are also not limited to evenly spaced teeth, or teeth of a single fixed width, and you can adjust the fit of your joint, even after cutting all the teeth because you can go back and recut (to make a looser cut, you can't make it tighter).
The jig could be made even more precise by using ACME threaded rod, but that is pretty much overkill for woodworking. If you don't like turning the crank as often, you can go with a coarser thread.
No, Craig, I'm talking about the "Lynn's jig" you referenced in your post. I don't know who "Lynn" is, and or whether he/she wrote the original magazine article or not - but that doesn't matter to me.
When using the jig:
With the 3/8" X 16 shaft, each turn moves the jig 1/16"; half a turn for 1/32"; quarter turn for 1/64"; etc.
Problem arises if your dado setup is, let's say, 31/128" instead of exactly 1/4". Now, you have to turn the crank 7 and 1/8 turn between each cut, which can become a bit concusing over a couple dozen cuts, and when you add in the (admittedly minscule) play in the jig, it confuses things even more.
It's still my 'go to' box joint jig. I just take extra care to make sure the dado blades are accurately set, and then there's no problem.
Alan in Little Washington (NC)
"Problem arises if your dado setup is, let's say, 31/128" instead of exactly 1/4". Now, you have to turn the crank 7 and 1/8 turn between each cut, which can become a bit confusing over a couple dozen cuts, and when you add in the (admittedly miniscule) play in the jig, it confuses things even more. "
Yup, and that can be a problem with both, Lynn's and Mathias' jigs, and really the bane of many box jigs. A dado not precisely set or an over or under-sized router bit can result in bad fitting joints.
The governing dimension for box joint jigs is not some "published" dado or router bit size, but the width of the notch actually made by the cutter. The jig must be set to that precise dimension - all three, the cutter notch, the space between the cutter and the index pin, and the width of the index pin, must be must precisely the same! No jig does that, at least not easily or almost automatically . . . . . not yet, anyway!!!! ;) ;)
Help is on the way, you only need to wait just a little more.
John in NM
"No jig does that, at least not easily or almost automatically . . . . . not yet, anyway!!!! ;) ;) "
Sure it does :D The only limitation is it won't work for rectangular pins (for that one of the fancier jigs would be better)
1. Set up dado set and make a cut in the future back plate of a traditional jig.
2. Make box sides with thickness to fit that cut.
3. Use small scrap of the box sides as the jig pin, glue and tack it in the first cut.
4. Use another scrap or one of the box sides to set the distance between the dado blade and the jig pin.
5. Make cuts in one side, then use the first pin on that side as a spacer to start the complimentary side.
As long as you always use the same dado set up with the same jig, you can always make the stock thickness to match and have everything come out fine. If you're using plywood stock, you often end up making a new jig for every run of plywood, as all our industrial know how can't seem to make dimension lumber and plywood consistent between runs (which makes me wonder why we call it "dimension" :D )
If you're doing a lot of boxes with different runs of plywood, then the efficiency of a traditional jig kind of falls apart and something like the lead screw jig would be a bit nicer if confusing to count partial turns.
Doesn't sound too easy, certainly not close to automatic, and too many "as long as" caveats.
But just wait. I know a guy who has a jig that works with 1+" thick drawer sides while making tiny 1/8" to robust 3/4" wide fingers, with any random dado setting- he doesn't even need to know the setting!! Just stack 'em and go!! Though I certainly would never recommend it, he can literally set up and use his jig blindfolded!!
Well, it is what you make of it...
John in NM
I find it trivially easy, but that's just me and the way I work :D
I bet you could find a blindfolded woodworker somewhere on youtube, they've got everything else, why not that! :D
oh... now you've done it!
John in NM
Got me thinking... doesn't happen often, but good when it does :D
Don't like all the "so long as's"? Ok, you can use any thickness of wood you want, you can have rectangular pins, or lord help you, use cdx plywood that measures 27/64" or some such. You can even make the front of the box thinner or thicker than the sides.
Instead of using your box sides to set up the cuts, just make a reference piece the same thickness as your dado cut and use part of it for the pin in the jig and part of it to set the distance from the blade and the first pin offset cut.
The only exceptions I now see are those that occur with any woodworking operation that any competent woodworker should anticipate. Like the difference between snug fit (good) and force fit (bad), and the assumption that a wood part made 6 months ago might not still fit in the dado :D
I now have absolutely no use for either of them fancy pants jigs, it can all be done better with a simple two piece jig, saving ooodles of time for actual woodworking :D
Now you've done it! I hope so!!
I'm not disagreeing that if you understand box joints and how the jig must work, a one-off jig can certainly be an alternative. Just like dovetails, a skilled craftsman can crank them out by hand almost as quickly and precisely as a Leigh or other jig- certainly a lot cheaper- because of the time it takes to set up the jig.
But, I have seen too many threads here and on other forums about people pulling their hair out trying to get a good box joint- too much "set", "test", "adjust", "re-test," etc. or too much fiddling with a jig that worked once but didn't work the next time because it was mounted to the miter gauge a few thousandths off; the user believed the manufacturer's advertised dado width instead of testing the cut; there was a very minor (few thousandths of an inch) variation when re-stacking the dado due to shim error, dust between blades, or arbor nut torque; a router bit wasn't precisely the advertised size; or it was different than the one used the last time, etc. This is the reason many small cabinet shops, once they get their router/bit and dovetail jigs dialed in, dedicate the router/bit to the jig- never adjust anything or use it for any other operation.
Wouldn't it be nice if none of these things mattered much, if the size of the dado or router bit didn't really matter, and you could pick up the jig, quickly dial in finger size without using calipers or other measuring devices, and precisely make fingers of any width (between 1/8" - 3/4")?
One that would make these all with the same amount of ease and precision?
