I like Klingspor Zirconium
Grant in Iowa
I keep 80, 120, 150 and 220 on hand, and I prefer the zirconium paper (blue from Klingspor). I find that this paper not only lasts much longer than aluminum oxide (two to four times as long), but it seems to not load up as much. When I discovered it, I still had a good supply of Aluminum oxide paper, which I do plan to use up. I have had good results from 3m Zirconium paper as well, but it seems to be harder to find, plus supporting Klingspor helps WC. Be sure to click through from the Klingspor ad on this site if you decide to go that way.
I just upgraded from a Performax 10/20 10" sander to a Performax 25" sander(stealth gloat). I am now eying the larger sander as a way to flatten boards that are wider than my 15" planer. In light of this, I am considering getting some 50 grit paper to make the job go faster. I have not used paper that coarse, but am told by others that it makes heavier stock removal jobs go much faster.
While I am aware that drum sanders aren't thickness planers, lately I have been collecting more and more large slabs and figured woods that would either not fit or be ruined by the planer. The potential of these pieces is great for unique pieces of furniture. Abrasive planing is an alternative to allow me to incorporate these slabs in to more projects. I suppose I could get some hand planes and learn a few new (old?) tricks, but I am addicted to electrons.
FWIW,
Grant in Iowa
