Volts, amps and you.
Jason Roehl in Lafayette, IN
It's often said that it only takes about a tenth of an amp (0.1A, or 100 mA) to kill you. This is true, but doesn't tell the whole story. That 0.1A has to go through the heart. But, the body has some resistance, so the more of the body that is involved, the higher the voltage has to be to get to that deadly current.
Ohm's Law is V=IR, where V is voltage, I is current and R is resistance. Solve for I and you get I=V/R, which shows that to get a high current, either V must be large, or R must be small.
Higher voltage can be dangerous because it causes the muscles of the body to involuntarily flex, possibly not allowing the release of dangerous contact with a live wire. For example, Tasers use two electrodes at about 50,000V, which will take away all muscle control of most people. However, the amperage is very, very small, in the neighborhood of 3-4 mA (about 1/25 of what could be fatal).
Higher voltage is also dangerous because of a greater ability to arc over a greater distance. 120V won't arc very far in air, but the 7000V on the other side of the transformer that feeds your house will jump a little ways, which is why downed power lines are so dangerous.
Then there is the concept of power available. P=IV (power, current, voltage) So, when there is higher current and/or higher voltage available, the potential for damage beyond electrocution is there--welding, arc flash, explosions, molten conductors splashing, burns, etc.
Be safe, folks.
Jason
