Ebonize - Stain for Red Oak
Bill G
i have a red oak kitched table for my son. He requested a black finish with the grain showing, not painted. I usually use Minwax stain-finishes, but their 2718 Ebony darkened but did not turn black as expected. I'm looking for another dye-stain method that would be compatible with a polyurethane top coat suitable for a kitchen/dining table.
Re: Ebonize - Stain for Red Oak
Ebony 2-Step
I use two.
First, I apply water-based dye in black. Flood it on. When it dries, it raises the grain that then gets taken off with a fine scotchbrite wool pad. Vacuum off well.
Second, I use black leather dye for what should be the final black.
If spraying a waterborne top coat, you can lightly tint the film with black Transtint for some nice depth.
David Barnett
My favorite is from Brian Boggs *LINK*
David Barnett
Gives a deep warm black on red oak. Incomparable penetration and appearance on tight-grained woods. A heat gun on low setting can enhance and speed things along.
Sprinkle some Quebracho bark powder on your bbq charcoal for terrific churrasco Argentina, too. Van Dyke’s price for bark powder has gone up a couple bucks, but two pounds lasts forever.
Brian Boggs - Popular Woodworking, July 2009
Glad you asked...
Tony - memphis
I have an upcoming project for our new excercise room (the old spare bedroom where the treadmill and other equipment resides now). We have a nice new tv in there and I would like to build a nice stand with storage and space for the dvd player and other stuff. All of the equipment is black, so I thought about making the stand "match" by staining it black as well. I was going to use oak just because it is cheap and easy to get. We have no hardwood dealers in the area anymore - bummer. Anyway, I was lokoing for some good black stain techniques. Never done black before.
Tony
Like Mark, I use black leather dye. Very effective stuff.
I got mine from Tandy.
Tom
Re: Glad you asked...
Larry in nw ohio
Tony Yes Colco was an outstanding Exotic and Hardwood dealer and a great place to Browse all day. Whenever I went there and after a few hours I would float out the door on my own drool. Larry
India Ink
Craig in Silverdale
Buy it at the art or office supply store. A couple coats will give a very black finish. Top with a few coats of water based poly for a really nice glossy black finish.
JMOHNIKE
I assume (should never do that)that you mean something like fumed oak. There were two ways that they would do this. both used ammonia. One method was to place the wood in an enclosed area (tent) and place containers of amonia in it seal it up an waite, several days color will be gray to black. Another was to place rusty iron, nials screws ect. in the ammonia and let it turn dark then place it in a sealed unit along with the oak and waite. Or, I have applied the rusty solution directly to the wood and it turned black. I have used both of the methods on white oak and do not know how well they will work with red oak.
Wants BLACK
Not brown - ammonia fumed gets to brown. He needs either a stain or an iron/tannin chemical reaction to get there.
Jim Hager
I use a water based dye stain from wdlockwood.com in almost all of my projects. My cabinet shop is well known for our ability to get a dark, rich color on almost any wood. The water stains from Lockwood's are easy to use, inexpensive and extremely color fast. They send it to you in a powder form for you to mix in regular tap water and can be made for around $20 per gallon. Once you use the dye stain you will probably be back for more. I rarely use oil based stains or solvent based stains. Their web site ain't much but the products are.
Re: Ebony 2-Step
FredD
When I worked with Leather which is the same as wood for dyeing, we first used Omega or any other brand of alcohol based dye in a dark blue, like Navy or Royal then after it dried , used the Black dye .
This cuts out the purple tones often seen with just black dye.
FredD
Febings USMC Black leather dye first,
Ketih Newton
Then lightly sanded, followed by a mix of Minwax Special Walnut, 90% and Ebony 10%.
An earlier poster suggested really flooding on the dye, but this one can sometimes blush if you use too much. I was driving by Tandy, andI happened to remember that I needed some dye. They had the black about half price.
Good stuff
Tony - memphis
I use their stuff too. Guess I'll try their black. I believe the dye that Lee Valley sells is theirs too. Love their stuff on maple and mahogany. I think I bought some VanDyke crystals from them for walnut too.
Tony
It's GREAT to see you back!
Bruce, a MN Galoot
Thanks for the reminder on the Boggs article.
Jim Hoeller
I have used iron oxide (rust) and it provides a deep black color on red oak. Take a small glass jar, a pad of 4x steel wool and enough white vinegar to cover the steel wool. Put the lid on and let the vinegar oxidize the steel wool. You will end up with a brown liquid that should blacken the oak quite well. You may have to experiment with the concentration of iron oxide needed to get the results you want.
