Dovetail Jig *LINK*
Dovetail Jig *LINK*
Michael Donaldson
Dovetail Jig *LINK*
Michael Donaldson
No brand listed. I think this guy makes these himself. Does it seem like it would work?
http://www.ebay.com/itm/NEW-12-DOVETAIL-JOINT-FIXTURE-MACHINE-JIG-DOVE-TAILS-/310352147924?pt=Routers_Bits&hash=item48426df5d4#ht_720wt_1151
Re: Dovetail Jig *LINK*
William A. Roland
Re: Dovetail Jig
William A. Roland
Looks just like others I have seen.
Re: Dovetail Jig
Looks just like one I bought new in a box at the Flea Mkt for $15. They come from China but I don't remember the brand. Yes it works. It's not great but is a lot better than the old Craftsman one I had before this.
Re: Dovetail Jig
Bill Earl
Those were marketed under several brand names. I have a "Reliant" version from 14-15 years ago. It is fiddly to set up but cuts good repeatable dovetails once you get there.
I have seen some where the cam-lock bars are plastic instead of steel. These don't clamp very securely and I would avoid them.
Re: Dovetail Jig
C. John Hebert
I bought mine through Grizzly around 25yrs ago and still use it in my Pro shop. Best and quickest repetitive jig out there. I'd buy it again in a heartbeat! for blind dovetails. I use a dedicated router and can whip out accurate drawers withing minute of other jigs. This one looks like a Rockler if I'm not mistaken. Mine is Grizzly's and love it
Re: Dovetail Jig
C. John Hebert
oops...15yrs ago
Re: Dovetail Jig
Dale Lenz
Hello Mike,
I did an image search in google for " 12" DOVETAIL JOINT FIXTURE MACHINE " . Seen the jig in several places, appears to be a China made item. Does it work, I would think so, but how well it works and will hold up is another question. I never have owned a dovetail jig, wish I had one a few times in my WWing career.
Good luck in your decision making
Re: Dovetail Jig
Jesse Cloud
Yeah, it works. The price is not a huge bargain. I took a "router joinery" course one time and everyone had to bring in a dovetail jig. That make of jig appeared as Rockler, Central Machinery (Harbor Freight), and unbranded. They were fidgety, but I never seen a DT jig that didn't require careful tuning.
Ditto to what John said
Terry Alexander
This looks just like my Rockler. I have a dedicated router setup and like John said, I can whip out drawers in nothing flat. One of my better investments.
Terry Alexander in West Texas
Re: Dovetail Jig
FredD
"but I never seen a DT jig that didn't require careful tuning."
Then you have never used a Keller.
FredD
Re: Dovetail Jig
Jesse Cloud
True... tell me more.
FredD
You can look up Keller online and see some of the merits of this system.
For myself I have Kellers Pro jig set up permanently with two routers and there is no adjustment except for depth and this on the router, not the jig.
It never changes , you can mix thickness's , though why you would want to beats me.
You can cut multiple pieces at the same time , and as fast as you can put a drawer side in the clamp and run the router.
The Pins and tails are cut with one pass , so you need a two horse or better router for Maximum speed.
The jigs are 1/2 thick Aluminum and wouldn't wear out in a lifetime of drawer making. You can buy them in different lengths machined for different Pin and Tail size .
For a project assembled with Keller dovetail jigs , look at this Triple dresser, out of Pecan which being a Hickory is very hard and heavy
https://picasaweb.google.com/FredD17209/TripleDresser?authuser=0&feat=directlink
https://picasaweb.google.com/FredD17209/TripleDresser?authuser=0&feat=directlinkhttp://
Using the Keller on your router table...
Dick Coers
is one of it's greatest features. You don't have to balance the router, or deal with the vibration, or eat the dust. Put a dust collector hose on the far side of the router table, and have at it. There is not match to the Keller as far as I'm concerned. The fixture shown for the original poster, can really be trouble. The one I tried to set up for a guy was a mess. The front flange on the bent metal base was not square. It took 9 layers of tape to get the two pieces clamped together at 90 degrees. Even at $40, it's overpriced. Some of the positive responses were from jigs with age. Maybe they don't even make crappy fixtures like they used to.
Michael Donaldson
Re: Dovetail Jig
Michael Donaldson
Thanks for all the input. I ended up buying a front vise (which I needed desperately) and I already have a dovetail saw I got from my dad, so I will be cutting my first dovetails by hand, until I can afford the Keller.
Kneale Brownson
Careful!! You may never WANT a jig after this
Tis true
Bill Tindall
Force yourself to make dovetails on every occasion to get the practice. Accept reasonable standards for the joint. (It is hard to make one that isn't stronger than any alternative.) A look at antique furniture will reveal that most of it is assembled with less than visually perfect dovetails. To speed things along, if you have a band saw use it to remove as much of the waste as possible. With little practice and reasonable standards you will no longer have need for a jig........unless you face a twenty kitchen cabinet drawers and a tight schedule.
Dovetail tricks
Whoo, now there's an enticing subject line, eh?
Back in the late '70s, we had a woodworking guild here in PA and northern NJ, and one of our eight original members was Frank Klausz. When we had our meetings at his old shop, he would always try to impress us with his Eastern European methods and tricks. One night, we were talking about dovetails, and Frank pulled out one of his smaller bowsaws, with about a 1/8" wide blade that was kinked 90º in the middle. He would saw down with the vertical part of the blade and, at the bottom of the cut, pull the saw into the horizontal section and pull the blade across the bottom of the cut, popping out the waste in one swell foop to the delight of everyone. Frank said he had often dovetailed drawers that way. He could do an entire corner joint in a couple minutes if he had to, and it went together fine and looked okay, too. He also used to judge his spacing and angles by eye, so his only layout marking was the gauge line.
Dovetails needn't be visually perfect, and historically they were cut quickly and efficiently, with whatever skill the craftsman could bring to the process -- without the fussing and fretting that accompany them today. There's a lot to be said about those old ways of doing things. It's a different aesthetic, but a logical and time-honored one.
