Built in closet (pics)
GolfSteve in Calgary
My house has a tiny third bedroom that is too small to fit both a single bed and a dresser in it. 35 yeas ago my sister had a double bed and a dresser in this room. You had to turn sideways to walk into the room and none of the drawers opened all the way.
To make the room more usable for my 2 year old daughter, I thought I would install a built-in closet into the closet opening, removing the need for a separate dresser. I had removed the original metal bi-fold doors in 1995 and my wife installed a curtain over the opening in 2006 and we've lived with that ever since.
Here's the design, sketched up in about 10 minutes after a particularly frustrating day of rearranging all the junk in our house and throwing about six garbage bags full of toys into the garage. Eight minutes of the design process consisted of looking up the fibonaccci series on google to determine the drawer height progression.
My goal on this project was to build something quick and easy without messing around forever like I usually do, so I bought the doors and drawer boxes from a local cabinet shop (www.multiwood.com). The doors were as nice as anything I could build, but I can assuage my pride by gloating that I can make nicer drawers so long as I have a weekend to make each one...
I've never done any built-in work before, so I just winged the installation.
My woodworking consisted of making the false drawer fronts (resawn from 8/4 maple from the bottom of the wood pile just to make things difficult and time consuming), pondering the grain and rearranging the boards for 6 to 8 hours to ensure a visually pleasing grain match :-), edge banding some plywood I had lying around, sanding the store bought Shaker knobs, cutting some 3/4 construction grade plywood scavenged from work into strips to support the drawer runners, and visiting Lee Valley about a dozen times to buy things I should have bought on the first trip.
Blum hinges (110 degree on left, 90 degree on right) with blumotion dampers. Accuride full extension, soft closing drawer runners.
Everything was sanded followed by two coats of Zinsser sealcoat, two coats of Oxford Target gloss WB lacquer, a quick sand with 600 grit, and one coat of Oxford Target satin WB lacquer. This is my first time using satin lacquer, and I love it. the final coat went on flawlesslessly, so what you see is right off the gun.
Now I just have to keep my youngest daughter from climbing into the drawers and convince the other daughter to not write on them with her new markers.
The rear of the closet was about 3/4" narrower than the front of the closet, requiring quite a bit of shimming at the front to ensure a square opening for the drawers.
And a shot of Multiwood, the place that built the doors:
Re: Built in closet (pics)
looks great to me. Nice work. Your daughter looks pleased and that is the important thing.
I just spent WAY to much time fitting drawers under the base we built for my son's washer and dryer. I should have known better. Next time I will build a separate box with the drawer in it and the install the boxes in the holes and avoid all the fiddling and fitting.
Larry in nw ohio
That is an outstanding job for nor "just messing around like you always do?" I`d have a hard time doing that good when I try very hard :b 8) You also did a great job on that pretty little inspector you have there. Be proud. Larry
Would building a box that slides into the opening be the standard way of doing this?
Barb Siddiqui
Priceless!  Happy girls, Great job.
Nat Robison
Great-looking project. Good luck keeping markers and crayons off those vertical surfaces. When my daughter was 2, she colored on everything.
Just the look on her face...
doug f, san clemente, ca
makes all the hours worth it!
Outstanding job!
Doug
FredD
I know Ladies that would kill for that installation Steve ;-))
FredD
Re: Built in closet
Nice job, Steve.
I did something similar for my son (way back when) and I too made it a permanent install. Put who lots of work into the room. Then the situation mandated that we sell and move. My son was a bit upset because all the stuff that "Daddy made just for me" had to be left behind. If I had it to do again, I'd do it in re-moveable units (or at least the drawer section.
Either you got the doors unfinished or did a very nice job matching the finish.
Pssst: Don't get PO's when your little angel fills those nice drawers up with "junk". She'll grow out of it. :D
Bill Tindall
Nothing beats the satisfaction of a house improvement job well done.
I have read about various mathematical means to establishing a progression of heights in a bank of drawers. The problem is that they all lead to a wide variation in drawer heights, more than I wanted in most cases.
If one looks to Period furniture for guidance the "formula" for a progression in drawer sizes is quite often h, h+d, h +2d, h +3d etc. where h is the height of the top drawer and d is the drawer divider thickness. This progression results a tighter spread among the sizes, if that is desirable, and it is attractive.
Re: drawer height progression
From memory, the drawer front heights are:
3-7/8"
4-3/8"
7-7/8"
11 or 11.5"
Interestingly multiwood makes drawer boxes in height increments that nicely fit into this progression.
But if I were to do it again, I would have made the bottom drawer around 10" tall, coinciding to the widest maple board I had in stock, negating the need to glue-up a wider drawer front, and I think the bottom drawer is a bit too deep to be practical. I would have made the top drawer the same height as the second drawer. I find the 3-7/8" height a bit too shallow to be practical.
Bill Tindall
Your proposed range is the range I stay in for chests of drawers, a quite different application than yours. I like your built in. It looks both attractive and functional, a winning combination.
I don't know what is "standard". I have seen many houses that have what is basically a cabinet that projects out into an attic space but very few that have drawers built directly into the house. I really struggle with trying to capture every useful cubic inch of space, but in the end there may be too many advantages of going with the cabinet in the closet idea. For example, most closets are not accurately framed. At least not to the accuracy required for drawer runners. Houses shift over time and with changes in season. Something that fits perfectly today may not by next summer. The cabinet or box would be easier to build and install and would "float" a bit inside the house and retain its shape and fit better, I think. I just know it was a bear of a job laying down on the floor struggling to install drawers under a washer and dryer and it would have been easy to slide a couple of units into place and walk away.
Great job and a question?
Ken Krawford
You project looks terrific and really was a clever way to fill a need. One question I have is why did you "farm out" the doors? They don't look that complicated and you obviously have the skills to make them yourself.
Re: Great job and a question?
Simply to save time. I have more than enough other projects on the go.
Right now I joint all stock by handplane and thickness using a power planer. I find that stock preparation takes a lot of time. I also don't have a truck, so buying plywood is a pain. When I saw their price and quality, I said "it's not worth my time on this project".
Jason Waters
Nice Job!
I prefer built in cabinets, for everything!
They give you more space (no wasted space on sides or back, and can be built to suit what you have to work with), are generally stronger (tied into studs properly), and more eye pleasing, at least to me.
You done good!
She seems happy. That's what matters (oh, and that the clothes and toys are off the floor....)
Jason
