200+ woodworking book reviews
Quick Framer Kit
Quick Framer Kit
Quick Framer Kit
Hal (on the York River in VA)
I recently purchased on of these kits to construct a golf cart "Garage" to replace one that the recent hurricane destroyed. I'm having a devil of a time putting this thing together. (I bought the kit from Northern Tool).
Has anyone used one of these kits?
The main problem that I've encountered is the upright studs are splayed out several degrees. I seem to be following the directions, though, so it's a puzzle to me.
Any suggestions would be appreciated.
Re: Quick Framer Kit
Larry in nw ohio
Hal Look in the instructions for a help phone number, they usually have something like that with such projects. Thay may have put the wrong parts in there. Good Luck Larry
The parts are correct. Simply "a" and "b" brackets. I've already contacted the manufacturers in Montana - G & T Sales, and they allow I must be doing something wrong since they've sold hundreds. I had a handiman friend of mine look at what I'd done and he can't figure out why the studs are not perpendicular either. I might end up lining the studs up the way I need them and drilling new holes or something.
Thanks, Larry
Joseph Mulherin
Hal, Rather, It seems to me that it is you and your handiman who do not understand the way the kit is constructed. I looked at the quick framer kit you mentioned and I did not see any problems with the construction they offer. The brackets are supposed to be angled and you just cut the boards and fit them into the brackets...simple construction.
Easier said than done!
