Harbor freight multi tool
james runchey
Anyone have one of these? I think maybe I'd have occasional use for one these, but not if they are useless junk. What do you use yours for?
Re: Harbor freight multi tool
Carol Reed, Strawberry, AZ
As it happens, I got one about a month ago on sale for $30. Really did a great job for what I needed it for. Got into a space nothing else would have. Also trimmed our carpet with the thing. Worked slick. Downside will be the replacement blades. $8 apiece for the one I like and I went through a couple real quick. Part of that is learning what it won't do. LOL!
I don't have the HF version, but I do have a Bosch. Can't tell you anything about the HF but I really enjoy the one I have. I bought it on the closeout at the blue borg as an impulse. I can't tell you how many uses we have found for it. It cuts drywall like butter. Wonderful for cutting out let boxes. I needed to cut recesses in the edge of deck board for the posts. Worked great. Used it with a scraper blade to help remove some vinyl flooring. Cut off the bottoms of door jambs to allow for hardwood flooring. Trimmed the inside of a cabinet facing to allow a lazy Susan to turn freely. Trimmed a sliver off a new floor for a cabinet to make it fit better. The sanding pad worked great cleaning up some stairs. The other sort of weird thing is that you can touch it to your skin with a saw blade in it and it doesn't cut you. (I'm sure you CAN cut yourself with this thing but it harder than it looks.) This tool I thought was almost a joke gets frequent use.
Re: Harbor Freight Multi Tools
George Colonel's Workshop-Havertown PA
Good Morning James,
There are several models sold by HF, one of which is cordless. Some are single speed, and about 1.5 or 1.6 amps.
My #3 son is a contractor who bought me a Dremel Multitool last Christmas. He got himself one also. Two weeks ago he called me from job site and asked me to go get him one from HF. The Dremel had quit. Ken also specified I buy him the far more capable 2.5 amp machine for about $55.00. I found the HF blades are less expensive than the HD Dremel replacements. I haven't used the HF model he has, but he really likes it. I still like my Dremel, but when it dies, I'll buy one from HF.
George
Larry in nw ohio
I don`t buy much of anything from HF unless it`s just for maybe a one time job or something like that. I bought a 4" handgrinder from there once and used it a few times and the wheel all of a sudden was wobbley, so I took the head off and saw why. The so called bearing that was on the shaft for the grinding wheel was just a block of steel whit a hole drilled into it for the shaft. It had wore the hole oblong so the shaft was loose. So i got a REAL bearing and that fixed it. Larry
Re: Harbor Freight Tools
Good Afternoon Larry,
It is surely prudent to be watchful of any tool, regardless of brand or origin. We've all been burned once or twice, and not necessarily just from Harbor Freight. I can add Bosch to my vex list, and DeWalt. I had a P+C lemon sander once, too.
However, all my HF purcheses except an 18 guage nailer, turned out well for at least occasional use: My original trim router is over 12 years old and is still in use by #6 son. I am on my 2nd pin nailer, and still have the first as a back up. I bought a small table model disc and belt sander years ago, and it works in #1 son's shop. And my 4 1/2 inch grinder is a real workhorse, and I've had no bearing problems. All these tools have worked as intended and saved me a few bucks.
George
Joseph Mulherin
I, too, have bought several different HF tools over the yrs and have not had any problems with any of them.
Air compressors(2), hand grinders, air pin nailers, routers and several others too.
Leo Cuellar
Lemon sander? Is that for removing the zest?
Leo Cuellar
:D
blades
Robin Corell in Atascadero, CA
I have the rockwell version and their blades are also a bit more than I like paying. I found that I can cut new teeth in the metal cutting blade using a dremel with a cut off wheel. My teeth look ugly and not very even but they work just fine and double or triple the life of the blade.
Re: blades
This is sort of funny. I don't buy much from HF but I did buy a set of tiny files and diamond files and use the to file the teeth on my blades. You are right, they are really ragged, but work pretty well and at least triple the useful life. HF has a three pack of blades that is fairly reasonable, but one or two of them are the scraper blades. I wish they had a bundle that just included saw blades.
Great Tip, Robin
I have it and the Fein
Jason Waters
I bought the HF version initially. I have found it very useful. I took my original one over to my mom's house for the occasional repair there. The best thing I ever used it for was to cut those dang sharkbite fittings off her plumbing up behind the toilet where getting a saw just stinks (there was enough left to glue on a male adapter for a new valve). It's great for cutting out rot at the bottom of door jambs to piece in new pieces (I never replace the whole piece, I just cut out a little more each year, and piece some more back in).
I bought another (when I had the $25 coupon I think) for my house.
My main complaint is the allen head screw does come loose while using it. It's not the end of the world, but it is annoying. Keep it tight before each cut and you should be fine.
Talking about extremes, I started using it enough for small jobs, I bought the Fein. More than 10x as much!!!
The Fein is much smoother, and works great, doesn't come loose, and has quick change. The blades are better (and more expensive!) too.
The HF version works, and is probably worth $30. Hey, if I've fixed 1/2 dozen door jambs, I feel I got my money. That may seem wasteful, but that's how I look at it.
If you want a little nicer one, sometimes you can find the Dremel for $50-60 reconditioned.
HF=Yugo
Fein=Porsche
In between, I can't comment, don't own any myself.
