Cutting 18" diameter tops on BS
Joe in a Cleveland suburb
Hello.
I am about to cut out a couple 18" diameter table tops on my band saw for a couple Shaker round tables I am making.
What are some suggestions on how to do this regarding attaching a temporary top to my BS with a pin/screw 9" from the blade.
Seems simple enough, but it seems no matter what I think of, clamps will be in the way. I know there is an obvious answer looking me in the face, but it hasn't hit me yet.
Thanks for any suggestions.
Joe
Re: Cutting 18" diameter tops on BS
Cover the entire top of the saw with your plywood jig (you'll have to cut the slot) then use two clamps at the corners on the left of the blade. You can also use a bit of carpet tape to secure the edge of the slot to the table top to prevent the plywood's twisting. Pretrim your workpiece so that you only have an inch or so of waste to the left of the blade so it won't contact the clamps.
Ralph Lipeles
You could run a strip, maybe 1 by 2 under the table and bolt it through your plywood circle cutting fixture with carriage bolts or flat head screws.
Ralph Lipeles
Jim Toews - Walla Walla, WA
What I did was to attach a runner that fit the miter slot to the bottom of a piece of plywood (about 14" x 20" in my case). Ran this into the saw until I'd reached about half way through, turned off the saw and attached a stop-block to the underside of the runner. I then marked a line perpendicular to the end of the saw cut (the front of the blade), measured the radius of my table top on this line and installed a brad at that point. Cut the head off the brad, leaving about 1/8", drilled a small hole in the center of my workpiece to fit over the brad, and ran the whole assembly into the saw. The stop-block stopped the workpiece at the desired radius, so all I had to do was rotate it around the center-point and cut a circle. Quick and easy, and the jig is almost infinitely adjustable: all I need to do is remove the brad and drive another into whatever radius I want. With this jig it was easy to cut circles up to 30", which was the largest I needed. For larger circles some sort of outrigger support would probably be needed.
Cheers!
Jim
What's already said, but with a picture
Henry Higginbotham
Using the aluminum extrusions that are everywhere you look at any woodworking show, a piece of plywood, and two fairly big clamps (the other one is hiding behind the blade guide). Set screws in the T-slot runner lock it into place, and the centering pin is just a 1/4" bolt, cut off below the threads and held in with JB Weld.
I suppose you wanted a quick solution for the size you need today, but it's handy to have something like this available for any size circle from about 4" to 94" diameter. Depending on the size of the blank, you might have to lop the corners off first to clear the clamps.
Alternative Method
George Colonel's Workshop-Havertown PA
Good Afternoon Joe,
My Shaker Tops were oval, so a circle cutting jig on the bandsaw was not possible. I developed a quarter temlate and used that to establish layout lines. Then I used my Bosch jig saw to rough cut the ovals, and a oscillating spindle sander to fine tune the surface edge. I also could have developed a full size template, and with double stick tape, done it with a router or on my router table. The same techniques could be applied to a round shape.
George
Re: Alternative Method
Larry in nw ohio
Years ago I made an oval mirror with my router and something called a thingajig. It worked quite well. Larry
Its Something To Reflect on, Larry
Great ideas!  Thanks much.
