How to clean keyboard?
Bill Tindall
Mine is, well, gross. Wife threatens to put it in dish washer. It is an ancient IBM with those wonderful click keys like a type writer.
Re: How to clean keyboard?
mdclor
Use your compressor to blow out all the accumulated sawdust, then wipe the keys and adjacent areas with q-tips dipped in DNA or acetone.
HTH,
Merle
Nat Robison
Don't know if it's possible with your particular keyboard but about twice a year, I pop all the keys off and soak them in bowl of soapy water. Blow out and wipe down the rest of it. It only takes about 15 minutes.
Gary Smyth
Blow out the foost with air. Spray Fantastik or soap and water (damp) on a soft cloth. Disconnect the keyboard and rub off the rest of the gunk. It should work fine. Acetone will be a bit harsh and dissolve the painted letters on the keys.
del schisler
Bill here is what i do and it works for me. I take the key board and turn it up side down and tape the board on the desk . the chunk's and dusk will drop out. Next i get a good cleaner and soak a rag enough that it doesn't drip and wripe the keys and board. this will take a little time but it will clean the key's like wripe each on the side's and it will look like new but will still have the type writer sound . Like a good old underwood ? or royal ? those were the days
I turn mine face down and blow it out with compressed air. I use my air compressor in the shop At about 25 psi as I am too cheap to buy canned air. I discovered where my cat stored his winter coat. I was astounded at how much crap was in there.
I would not use Acetone. Pretty sure you will end up with blank keys. If you decide to remove the keys, it might be good to take a picture of the keyboard first.
You Got That Right, Ken
George Colonel's Workshop-Havertown PA
Periodically, I donate my keyboard to one of my kids, and go buy another one.
George
Dishwasher--no joke
Joanne in Point Pleasant, PA
I have actually put keyboards in the dishwasher. No kidding. I turn off the heated dry and put them in the top rack, face down. After the cycle, I shake out the water and lay it on a towel in a sunny spot for a day or so to finish drying out. Hook it back up and voila! Clean keyboard. It is very hard to find (other than eBay) a clicky keyboard like those old IBM's. This will give yours a little longer life.
Yes, but it's basically a $5 piece of junk
Henry Higginbotham
... with no tactile quality and no long-term serviceability. The difference between it and an IBM Model M is beyond night and day. Really. And the old IBM doesn't have that those stupid WinBlows keys.
As already mentioned, you can just pop the keycaps off with some appropriate prying tool, giving access to the frame between the keys. 409 or similar cleaner works fine. Q-tips help, too.
The IBM is well worth whatever effort you choose to put into it (but I think you already knew that).
warm soapy water
Chuck in Mtl.
In the past I have cleaned an occasional keyboard by removing the back and soaking the front panel with the keys still in in warm water. This removes all dust, food and other stuff very well. Like a new one afterwards. Take time to get all of the water out from around the keys before reassembling.
Jesper, Denmark
Jesper, Denmark
Remove from PC. Turn upside down and tap vigourously. The actual keys are caps, fitting on the board, and can be removed for cleaning - make sure you put them back in the right place :D otherwise some funny abberrations could occur.
If you find more old keyboards like the IBM on fleemarkets - hoard them for replacing keys with worn off symbols.
Oven
Dustmaker Mike
I use warm soapy water and give it a good bath. Blow out with low pressure I read 25 PSI here but I am a coward and would turn that down to about 10PSI. After it stops blowing all the water I place it in the oven at 125 Deg F and leave it for about an hour. Take it out let it cool and away you go. You want to dry it with a warm dry air or like someone said with the rays of the sun. I have cleaned many of coffee spills this way and coffee with milk and sugar is the worst thing too get out of a key board.
Good Luck
thanks to all
Bill Tindall
Q-tip and 409 did the trick....slowly
You can still get clicky IBM-style keyboards
Kurt
They don't advertise much -- I think they do mostly B2B sales.
http://pckeyboards.stores.yahoo.net/customizer.html
They're in Lexington KY. so I suspect they bought the keyboard business when IBM spun off the hardware biz. They ain't $19 though.
Old PS/2 Keyboards
Jerry Nicholson
The keyboard I am using right now came from a PS/2 Model 80 and has a 1987 manufacturing date. I like the feel and the weight - it never slides around - and plan to use it forever. I have 4 others around here too.
Jerry
Re: Old PS/2 Keyboards
Bill Tindall
a man after my own heart. I have three in waiting.
Jerry Nicholson
The keyboard on my secondary computer is much newer - it was manufactured for IBM by Lexmark in 1994. I am not sure you can wear out one of these old beasts, at least I haven't worn out one yet. I have a Data General keyboard made in 1992 that runs a close second to the IBM keyboards. I picked up some of my keyboards at a Boeing surplus store several years ago for $1.00 each. They had been used on a manufacturing environment and were pretty grimy but were no problem to clean up. I wish I had bought more.
Jerry
Joel Moskowitz
I feel totally outclassed. I only have one waiting in the wings. I guess I should better stock up.
Of course if keyboards are anything like tools - which they are they are a writing tool, in 50 years you won't be able to get old IBM keyboards and folks will be arguing over who makes the best "new keyboard"
LN will sell copies from IBM from 1990.
LV will add brass knobs to a touch screen
We will start making fountain pens.
