Help: need glass removal advice
Pat Evans
I'm trying to remove double pane glass from existing wood frames. A multi-tool with a scraper blade does a great job removing the wooden glazing bead. I just slide it between the glass and glazing bead and it cuts through the caulk nicely. Then I pry off the bead.
However, when I flip the window over and use the multi-tool to separate the glass from the frame, the glass invariably breaks. The sealant on the inside face of the frame is more like an adhesive than caulk and it is much more difficult to cut through it.
It's not that I'm trying to salvage the glass. It's just very difficult to handle a large double pane panel that is badly broken up.
Any suggestions?
Re: Help: need glass removal advice
Larry in nw ohio
Pat Try heat from a hair dryer that may help get it loose. Larry
Not Likely
the heat will break the seal between the panes, releasing any inert gas left and putting water vapor in to condense as fog when it gets cold.
Not sure what he doing here, but lots of "energy" windows are basically designed to be permanent and only removed to replace the glass when broken.
I know a company that does it for a living. I will try to remember to ask them, if they will tell me. They may not want to reveal their trade secrets. I would lay them over a trash can and bust them out.
