ADVERTISE HERE - FREE TRIAL
Shop Accident
Shop Accident
Shop Accident
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
I was wheeling my DeWalt planer from between the SCMS and Router table onto the main shop floor when a caster snagged a small piece of poplar. The planer sat atop a shop-made cart, scarcely larger than the planer's footprint. On the cart's shelf, I stored a few bandsaw blades coiled in the USPS boxes Timberwolf ships them in.
I was pushing the planer fairly hard from an awkward position when the thing tipped over and smashed onto the tile floor. Its too heavy for me to lift, so I have to wait until a couple sons arrive for the dinner party tonight. However, I noticed one of the boxes slipped enroute to the floor and bent one of my unused (3/16") BS blades. Why couldn't it have happened to an older dull band?
I am hoping that the blade is the only loss, an I need to finish planing the QS sycamore veneer as drawer fronts to the almost completed cherry longerie chest. I am not a happy camper right now. :(
George
Re: Shop Accident
Re: Shop Accident
Larry in nw ohio
I`m sorry to hear that, I hope nothing else is damaged, and I happy to hear you weren`t hurt. That`s the main thing that you were not hurt. Larry
Re: Shop Accident
I need to think about this....
I have my Dewalt planer mounted on a cart/box also about the same size as the planer. I have about 3" casters on it. I tend to roller it around by either pushing or pulling. Those little wheels tend to get hung up on almost anything. If I were getting rambunctious and pulling on it I could dump it on myself. HMMMM. I need to be more careful. Thanks for the warning.
Glad you weren't hurt. Hope the blade sacrificed itself to save everything else.
Is it face up or face down? if it is outfeed down, perhaps you could plane a piece of wood and it would stand itself back up ;)
Re: Shop Accident
Dale Lenz
Re: Shop Accident
Dale Lenz
Glad you were not hurt, George. Could have hurt your ????? I know machine problem are a real downer, but a busted foot or what ever would be worst. Sounds like it's time to consider a bigger stand for your planer. Accidents like that one makes me re think the situation.
Try to have a good Sunday, you have alot to be thankful for.
Re: Shop Accident
All fingers and toes still atatched ?
Re: Shop Accident
Re: Shop Accident
Ken Oakley-Sunny St. Cloud, Fla
Next time pull it instead of pushing it. That way if it tips over it will have something soft to land on.
Re: Shop Accident
Re: Shop Accident
Ron Jones
I'm glad you weren't hurt. I have my planer clamped to the top of a workmate which is on one of the HF Delta type bases. Works great! That setup takes a little more room, but it is very stable.
Re: Shop Accident
Re: Shop Accident
Andy Lincoln,in Dearborn MI
George,
Glad your accident wasn't any worse.Is it possible to cut and reweld the blade ?
Re: Shop Accident
Re: Shop Accident-The Good News
Good Evening Andy,
I doubt it, as the "bend" in the blade involves at least six inches of its length. If I lay it on the floor uncoiled, those six inches are raised above floor level by a good inch. I haven't mounted it on the bandsaw yet, but I can't see how it would track very well, given more than customary tension.
The good news is that the planer wasn't damaged, oweing to the blade's box absorbing much of the crash. I just reduced several planks of QS sycamore to 3/16" thickness, and the result was uniform, smooth, and very little tear out.
Good thing. I priced replacement planers before dinner, and lost my appetite.
George
Re: Shop Accident
Re: Shop Accident
Dave Peebles Lyons, Ohio
Good morning George,
That is one of the best shop accidents I have ever read here.
Just a little money, and no real damage.
It is a little annoying, but no skin or flesh damaged.
Best wishes,
Dave
Re: Shop Accident
Re: Shop Accident
Jerry Roberts
Sorry to hear the Dewalt and you wernt hurt. When I built my tables for my CMS and my Dewalt planer I made it just slightly larger than the footprint like you did. The only thing I probally did different is I made the table legs at a miter and bevel. It was either 8 or 10 degrees. I have to roll both of mine a lot in my garage workshop and it feels somewhat safe to roll about.
Re: Shop Accident
Kneale Brownson
Those carts need bigger casters
Kneale Brownson
Or a cleaner workplace.
Re: Shop Accident
A.J. Hamler
Re: Shop Accident
A.J. Hamler
Colonel...
As a few posters have already noted, put some larger casters on there asap. That'll help prevent snagging and catching on floor debris or irregularities.
Does the cart have handles? If not, consider adding some handles low on the cart, maybe a foot down or so. If you always use these handles to move the cart, that will help prevent tipping, as you won't be pushing or pulling on the top where all the weight is. Instead, you'll be applying force lower down, lessening the tendency to tip.
However, the very best thing you can do is to lower the center of gravity, which is the real problem here. You don't say which DeWalt planer you have, but if the cart is right about the same size as the planer, that makes it about 22"x22" or so. If the cart is high enough to keep the planer at a good working height, then that center of gravity is way, way up there. Just asking for trouble. You can make a new cart of greater dimensions, of course, and that might be a good future project. (A larger rolling cabinet can also be designed for lots of storage.)
But in the meantime you can bring down that center of gravity and add stability by adding a larger bottom to the cart. Consider removing your current casters from the bottom of the cart, and then attaching a 26"x26" piece of 3/4" plywood to the bottom (a sandwiched double thickness of two pieces of 3/4" ply is even better). Re-attach the casters near the corners of that 26x26 piece, and you'll lower the center of gravity considerably. You'll be surprised at just how much extra stability that will add.
A.J.
Re: Shop Accident
Or BOTH!
Re: Shop Accident
Re: Shop Accident
Good Morning AJ,
I will do as you suggest. When the planer (#734) tipped over, I thought of replacing the casters with larger ones. I do like the idea of making a wider platform from double ply: the footprint must be commensurate with the available storage and maneuver space.
I was lucky. It still works and needed zero adjustments following the accident.
George
Re: Shop Accident
Re: Shop Accident
Fred Davis
Colonel..., if the footprint is to large for the available space , you might consider the hydraulic load levelers like you see on Backhoes, just a thought mind you ;-))
FredD
Re: Shop Accident
Re: Shop Accident
Colonel, A J is right. There are basically two ways to lower the center of gravity. Lower the weight and spread the base. Obviously you want the palmer at a comfortable height, so figure out what your minimum is and then spread the casters as far as you can. And, from personal experience bigger casters roll better than little ones. The low handles are a good idea too.
My planer Base is a storage box and I put heavy stuff in there. Skilsaw and belt sander live there along with other stuff. The sit right on the floor of the box and help a lot. Big wheels over come rolling resistance, even with extra weight.
