Sorry to bring this up but (OT)
Larry in nw ohio
with winter coming on in a few months, I`m wondering does anyone know how small of a hole does a squirrel need to have to get into a house. Last year we had quite a few nuts in our attic, so I`m assuming it was squrriels that had lunch a few times in our house without an invitation. Boy that`s pretty forward, just to barge in without an invite and help yourself. At least I as far as I could tell they didn`t take anything or do any damage. Thank you Larry
Re: Sorry to bring this up but (OT)
Jesse Cloud
Doesn't take much of a hole at all. Also check for loose screens on vents, loose fascia, etc that they can pry up to get in.
incredibly small. I had a log home (actually still have it and it's for sale if you want to move to TN) and one got in through a small joint in the overlap of the logs. We were sitting there watching TV one night and one just walked across the living room. The 2 dogs just sat there and watched it. I got my gloves and went after it. it ran into the study and crawled out through a hole that looked way to small to even get it's head in.
Nat Robison
I'd say a hole the size of a tennis ball would be fine, until they fatten up. FYI, I had a juvenile woodchuck in my attic this summer and contacted a critter control outfit on the assumption they would bait/trap in the attic. Once they came out and set up a trap and I had to to sign the contract, I saw they didn't go into attics, probably for fear of causing damage. He baited/set a trap in my garage where the woodchuck came in. For lots less money, I could have done that myself. If you end up getting a contractor, see what they will and won't do and determine if it's easier to DIY.
and if it isn't big enough they will gnaw it bigge
Tennis ball my a..... Try a Ping pong ball sized hole. And if you have one that size and its too small, they will enlarge it themselves until it is just right. Once they are in and discover the luxury living available in your attic, they will be very hard to get rid of. Window screen won't even slow them down. Hardware cloth might, but even if you cover their holes with sheet metal they will likely chew a new hole beside the metal. You have to relocate them far far away.
A favorite spot for the hole is above the gutter, under the shingles, through the fascia in the very corner of the attic.
Actually as far as metal goes, lead is the best. From a gun.
A 22 caliber hole keeps them out...dead out!
Steve Strickland
Re: steel wool and pie plates
Steve Strickland
Stuff the cracks with steel wool. They won't chew through that.
I've seen rats run in on a power line. A pie plate stops that.
Moth balls run everything out.
Rodent . . .
steve mackay
You gotta figure that they're a rodent. If the head'll go in the rest can be pulled through. But don't forget . . . those suckers can enlarge an itty-bitty hole into a four-lane in about five minutes !
Re: Rodent . . .
Larry in nw ohio
Yea the two holes I saw were about big enough to drive a truck through. They are about the size of a 2X4 at the end of the house where the end cap, fasia and roof meet. I have been figuring on using the steel wool, the really rough stuff and maybe soak it in oil or something like that so it doesn`t taste very good when they chew on it. Larry
Barry
Metal pie plates and power lines? I wouldn't want to go there!
Re: Rodent . . .
Haven't tried it on squirrels, but when I a lad I helped a farmer re-seal a corn bin. He broke up old glass jars and mixed the broken glass into the concrete, then packed in the holes. - Yeah the rats will chew through regular concrete or at least inlarge cracks. Might try wood filler mixed with broken glass - should stop them.
Sister had flying squirrels, harder yet.
Keith Newton----Little Rock, Arkansas
They like to work at night, so you get to hear them when trying to sleep. But you are not likely to even see them during the day.
These chewed through at the peak of the barge rafters, under the ridge vent plastic.
james runchey
Nuts don't have to mean a squirrel. Living on a farm we have lots of mice, and they love to haul in hickory nuts, in particular. We used to find them allover the place. We have since tightened up and rarely have mice anymore.
Larry in nw ohio
Mice or sqirrels the steel wool or glass mixed with something should slow them down or make them leave. Thanks everyone and if someone thinks of something else please chime in. Larry
NO!!! No pie plates on electric lines!
Tom Dunlap
Even cable/phone lines can carry over 100 volts
putting anything on thelines is dangerous.
Tom
So far, so good . . .
steve mackay
I've been useing that new-fangled metal plaster/stucco "lath". Comes in sheets and looks like really big cheese grater. Easy to work with and cheap at The BORG.
You have nuts in your attic?
Where is the Colonel when we need him? ;-)
My son uses the copper kitchen scrubbies (can't recall the name) or very coarse steel wool, sticks the nozzle of some spray crack-filling foam into the center, and squirts in a shot. The foam fills up the spaces and, as it always does, sticks to the edges of the opening, so the mice (in our case; squirrels in yours) can't easily pull the steel wool out.
He prefers the copper kitchen scrubbies because the openings in the scrubbie are larger than he can find in any steel wool, so the foam can more easily spread through. They are more expensive - on the other hand, you're less likely to get rust if your openings are exposed to the weather.
Better
than a tic in your nuts, right?
Or bats in your bellfry?
