Resaw King Blades...Steel or Carbide Tipped???
TMStock
So a little confused...Laguna's ad copy claims these are C8 steel tipped - to include their YouTube vids and Amazon listing. Both Rockler and Woodcraft sell these blades as C8 carbide tipped. C8 is clearly a carbide grading, rather than a type or tempering spec for tool steel.
All three of my RKs have either died early deaths after cutting a few dozen LF of mixed stock or required sharpening right out of the box, and if Laguna is actually selling steel tipped blades as carbide, it would explain why these will handle mahogany and ash, but not any of the stuff that I actually need to cut (rosewoods, anigre, etc.).
Re: Resaw King Blades...Steel or Carbide Tipped???
larry in nw ohio
I don`t think to many prople buy blades from the company they bought the saw from. I found a blade maker that have the best blades I have ever used, their web site is, www.superbandsaw.com not to be to prejudice I think Highland hardware also handles very good blades. There is another blade maker but I can`t think of it right now. Some else will chime in here I`m sure with there prefrence. Larry
Bruce, a MN Galoot
I have two resaw blades right now, a Lenox Trimaster (carbide tipped) and a Highland Hardware Wood Slicer.
The Trimaster lasted me three years. It takes a fairly wide kerf and runs very true. Being carbide tipped, it was very durable. Keep in mind, though, that Lenox says they can't be resharpened and don't recommend it. However, they can be,and I found a place that does it (Jackson Saw and Knife, Rochester, NY, $2.50/ft) Seeing as how they are nearly $140, you'd want to resharpen them.
I am now using a Highland Wood Slicer that gives by far the best cut I've had from a resaw blade. It has a very thin blade and not much set, so it tracks extremely well. I've cut >1/16" slices with it easily with no drift. I'm told it can't be resharpened, but then it's a lot cheaper than the Lenox.
All this is on a Delta 14".
    super saw cut blade's
del schisler
thanks for the link larry I have been using their blades now for 6 mo. I know they cut better than the wood miser which i used for a couple yrs. They cut good but the blades from the super saw cut better and faster. the link http://www.supercutbandsaw.com/
TMStock
Yes - there are a number of good blade manufacturers...I've had a couple Lenox Trimasters in the shop for my little Delta 14", and they work as advertised, handling milling of anigre and other abrasive exotics to the usual .100" thicknesses I work with. When I picked up my 18" saw early last year (not a Laguna), I went shopping for a couple carbide resaw blades (I am a luthier as well as cabinetmaker, etc.) for work in rosewood, anigre, and other abrasive tropicals, and Laguna was running a $150 for two blades on special. At the time, Laguna's advertising copy stated C8 carbide teeth, just as this dated Amazon listing shows...
http://www.amazon.com/Laguna-Resaw-Carbide-Tipped-Bandsaw/dp/B005JRI8V2/ref=sr_1_1?ie=UTF8&qid=1316433012&sr=8-1
Since then, Laguna has dropped reference to the actual tip material on their own site, and the new ad copy on Amazon refers to 'C8 tool steel' welded tips. Obviously, C8 is a carbide grade, and both Woodcraft and Rockler advertise the RK blade as a carbide-tipped blade.
My question is really not whether there are other good blades like the Woodmaster CT, but rather why there is so much confusion over whether the RK is indeed carbide.
My specific interest here is determining whether others have had issues with this specific blade, and whether the advertising has been misleading or simply in error. I have no idea why anyone would want tool steel tips welded to a band, as bimetal blades already provide increased wear and fatigue resistance versus plain high carbon steel.
Re:     super saw cut blade's
Larry in nw ohio
Del Thanks for the correct web site address, sometimes I can`t see what`s right in front of me. Larry
Re:    could happen to us old fart's
