We value your privacy.
I am framing a picture my wife cross-stitched to be entered in competition at the county fair. Last year a judge deducted points for not using non-glare glass, so this year I got some. When I hold the glass up, objects at a distance are really blurry and look terrible. When I lay it on my bench it looks almost clear. Is this normal? Is there any special processs to be used when using this glass, or do you just use it like normal glass? I have always used clear glass, and the way this glass looks now makes me nervous.
Seems I recall the glass has a scratch pattern kinda like a matt finish on wood, hence very little glare. I recall the blurred look until the glass set on the surface of an object. As always I think a matt is a good idea to keep the glass off of an object. I have a very nice picture I took years ago and it has adhered to the glass, if the glass ever breaks I'm up a creek! On second thought, the showing object might be slightly out of "focus" . Try putting something around the object about as thick as a picture matt and see for yourself.
Non glare is just that, it eliminates reflections that can ruin your view of a picture.
I have it done by Danner Funeral home in Abilene if you can believe that.
If that seems a unlikely combination of business. my favorite hardware and the one that sponsors our Men's bowling team is Londeen's Hardware in Chapman ,Kansas who also owns the Funeral parlor there and when Jon is't selling hardware, he is .....
The man is a hero in that town , at the age if 72 he does all of that work and when the twister hit Chapman four years ago , it took out his home , the separate Funeral Parlor and about the back half of his Hardware and he kept it open though the days afterward when it was Hell on Earth in that town and basically held the town together.
Other than the business of it having and inside and outside, there are no special handling instructions. It makes a world of difference for the picture , or cross-stitch. It's relatively more expensive, so we use it only for our best pics.
It seems rather picky for a judge to deduct for not using non-glare glass, especially for something that has a bit of a depth dimension to it like needle-work. As you have said, anything that's not right at the back of the glass is increasingly fuzzy-looking.
The fuzzyness is normal. If only on one side, fuzzy should face out. Do not clean with ammonia cleaner as it will outgas over time and can affect the art. Microfiber cloths or unprinted newsprint paper will help eliminate lint. Don't spray the glass, spray the paper or cloth. The glass will need to press up against the art to provide the best image, but don't do that. I almost always use a mat to keep the glass off the artwork and live with the minor distortion caused by the separation. Test it to your eye. Make certain that an acid free mat board is used under the art and tape only any fabric that you don't care about. I've had luck with Aileen's Glue (Craft shops) on the reverse side of the mat board edges, and the fabric is then wrapped over the edge. Keep fabric weave straight vertical and horizontal and any seams aligned. I also place two very small brad nail holes through the frame bottom drilled before sealing in the fabric to allow moisture to escape and to let room air in. You might have to alert the judge that these holes are on purpose so he/she doesn't think it's a mistake. On the back of the frame I include a note not to block the holes so that the artwork can "breathe". By the way, don't expect whatever glass you use for it to stop UV damage, so keep it away from the sun.
Moses I use non glare glass to when doing copy work in photography. Laying directly on something it's almost perfectly clear and doesn't degrade the image. When you move it away however it does. When I display my photographs in galleries that have windows the glare can make it very hard to see. This is what the judge was complaining about.
With Photographs you don't want the glass in direct contact with the surface because it will stick and can ruin the photo. consequently we leave a gap. However as you observed leaving a gap creates a less than sharp image. I usually leave as little gap as possible so I lose as little sharpness as possible. However for that reason I don't use non glare glass unless I don't have a choice. I work hard to get my prints really sharp and don't want to lose that.
Needle point because of it's nature isn't as sharp as my photos. I would just leave a little space and not worry it.
When I looked at the glass, it appeared to have a light layer of something on both sides, like texturing. I didn't see a difference really flipped one way or another, so I just siliconed it into the frame on Saturday afternoon. I will look at it again tonight with a picture of some sort on both sides to see what it looks like, I may need to flip the glass. My wife will not get the needlwork stretched onto the interior frames until Thursday and the pics have to be taken in to the fair on Saturday so there won't be mutch time to futz around after the pictures are ready to assemble.
