We value your privacy.
On nearly every cut I make on my table saw (a Delta Unisaw), the blade burns the wood pretty badly. I am using a 40 tooth Forrest Woodworker II blade. Is there something I am doing wrong? Cutting too fast? Too slow? Too high? Dull blade? I don't have any powered sanders, so I have to sand out the burn marks by hand, and it is starting to not be very fun. Any help would be appreciated.
The possibilities are: feed rate too slow, blade dull, fence closer to blade at the back of the blade, or some form of binding on the cut. Are both the workpiece and the cutoff burning?
As been said could be several things. Simple solution is to change the blade out to see if that helps, don't have an extra blade? Could you borrow someones to see if that helps? Has this been a problem ever since you brought the saw home? Is it happening more on cross cuts vs. ripping?
Check the fence. It should not be closer to the blade at the back of the blade as it is at the front. And we are talking thousandths here.
If you are using a splitter, that can also be slightly misaligned and pulling the wood into the back of the blade. BTDT. Was most frustrating until I found it.
Change blades. That will point at or away from the blade.
Finally, scrape burn marks out. It is faster and cleaner. Good reason to learn how to use and sharpen a scraper. You'll find lots of other uses for a scraper as well.
All that said, yes, some woods do burn easier than other, cherry being one of them. But a well tuned saw with a sharp blade goes a long toward eliminating burn marks.
So far I have cut quilted and hard maple, bloodwood, white oak, plywood, and poplar. It all burned both crosscut and ripping. I looked through the support box my dad had for the saw and found a brand new Forrest Woodworker II. So I will measure the distance from the fence to the blade with a micrometer, and put a new blade on it and see what that does. Thanks for the help.
Guaranteed the fence is closer at the back of the blade than at the front of the blade. If not, a build up of residue on the teeth of the blade could be the problem. I clean my blades with Simple Green.
You mention it was your Dad's saw. Did you move it to your location recently? Just wondering if there was disassembly/reassembly involved with the possibility of some jostling.
I would put the new blade on the saw and using the the miter gauge, check to see if the blade is parallel to the miter slot. I don't have a micrometer so I use a pencil. (Unplug the saw for this) With a Magic marker or Sharpie mark one tooth on the blade. With a hard sharp pencil hold it tightly to the miter gauge and "set" it so that it just snicks that tooth at front where the tooth plunges into the table. Slide the miter gauge to the rear and rotate the blade so that you are dealing with the same tooth and see if the snick is the same. You can hear and feel the contact. You want the tooth to just touch the pencil point and not actually shave it off. Having the blade misaligned in the slot can have the same effect as the fence being out of alignment.
You can check the fence the same way. Since we are guessing the fence is too close to the blade at the far end lock the fence in a position that is near the miter slot and set the pencil to just touch the fence at the far end. You could use something as a feeler gauge. Pull the miter gauge to the front edge of the table and see if the fence is parallel.
The other likely culprit is a dull/dirty blade, but your new blade takes that out of the equation.
If you find the problem your manual or YouTube or the manufacturers site can be your friends in fixing it.
I have an old Delta/Rockwell Contractor saw with a a Forrest WWII blade and an after market Beis fence. Oddly, in forty years I have never adjusted the blade parallel to the slots or really checked to see if it is. I installed the fence and put it beside the slot and looked at it. It looked good so I went to using the saw and get very little burning. Works for me.
Don't discount that it could be a defective blade. I had the same problem with the same blade. I tried everything and isolated it to just that new blade. I called the manufacturer and they just didn't want to believe me. I made a deal with them, I would pay to send it to them and pay for a blade sharpening only if they promised to inspect it first. It took a few weeks but I finally received a phone call apologizing that in the initial grinding / sharpening they over did it and removed the set. They sent me a new blade in the end.
Be sure you measure to the same tooth on the blade; i.e., measure at the front and then rotate the blade and measure to the same tooth after rotating. A most annoying problem. Good luck. As Carol said, use a scraper to remove the burn. Way quicker than sanding. A useful tool.
The two most likely culprits are a blade in need of sharpening or a table saw that needs to be aligned.
Here is the low tech, low cost way to align a tablesaw that I learned maybe forty years ago and use to teach to my students.
Make 3/4 x 3/4 x 12" hardwood stick. Drill a hole somewhat centered in one end and insert a brass #8 x 1" round head fine thread machine screw about half way. UNPLUG THE SAW. Raise the blade completely up. Clamp this board in your miter gauge (if you determine that there is some slop in your slot to miter gauge, use a playing card to take up the slop) so the screw head just about touches the blade at the front. Now rotate the blade by hand and determine which tooth is the closest. Adjust the screw in or out until it just touches this tooth. Mark this tooth. Rotate the blade so the tooth is now at the back of the table and move the miter gauge/stick assembly to the back and see if it touches the marked tooth to the same extent. If it doesn't, adjust the trunnion (if a contractor saw) or the tabletop (if a cabinet saw) until it does.
For a contractor saw, first use a small c-clamp on the rear trunnion and cradle to keep the assembly from moving. Then loosen the two rear trunnion bolts and one front trunnion bolt. Slightly loosen the other front trunnion bolt and use a stick to tap the trunnion until the blade and screw lightly touch. The blade does not move directly around the center so you will need to repeatedly go back to the front of the blade, readjust the screw, and then again measure the back. Be sure to check after tightening the trunnion as the trunnion frequently moves when being tightened.
For cabinet saws, loosen the bolts that hold the tabletop and tap one corner until things come into alignment.
The same adjustment gauge can be used to set the fence parallel to the miter slot. Slide the miter gauge to the front of the table and move the fence over to the screw head and insert a playing card between the screw head and the fence just so you can move the card as it touches both the fence and the screw head. Now move the miter gauge to the back of the table and see if you have the same feel when you insert the card. I like my fence absolutely parallel--if you want to have a slight opening to the fence (Forrest recommends this for their WWII blades), you can easily estimate the opening by adding a thickness of paper to the card.
I always show my students with a dial gauge that their adjustments are within .001 - .002.
You can also use the same gauge to measure blade runout by using a $5.00 feeler gauge.
Finally, after you are satisfied with the above adjustments, check the position of the splitter to make sure it is exactly in line with the blade.
Bottom line, there is no need to spend more than the $0.05 for the brass screw.
Before you mess with the fence alignment, check to made sure the mitre slots are parallel to the blade,especially in a Unisaw.
There is a bolt at each cprner of the saw table , determine which way you would need to bump the table to align the saw and then loosen three bolts and leave the pivot bolt fairly snug and bump the table corner into alignment. Then tighten the bolts and check to see if the table slipped on you.
Then check the fence for parallel to the blade.
Even with everything perfect, with Cherry and Maple , a fast rate of feed is needed, any hesitation will give you a burn.
