Planing Panels
Planing Panels
Planing Panels
TNorred
I am a little new to planing and woodworking in general. I am looking at making a Bed with raised panel's in the headboard and footboard. If I purchase a small portable planer (13" or so) how to i plane the panel after i join the wood together so that it is all uniform prior to routing etc. Do I use a hand planer or is there a better/easier way to do this? Any advice or suggestions would be very much appreciated. Also little side question; where is the cheapest place to order wood on the internet. I just moved where there are no wood stores within 100+ miles.
Re: Planing Panels
Re: Planing Panels
Welcome to Wood Central.
Why can't you run your panels through your planer? Are they too wide? How about a redesign of the project to make the panels narrow enough to go through? Or you could glue them up and take them to a cabinet shop and have them plane or sand them for you. Many of them have wide belt sanders that do a good job of this at reasonable prices. (Often up to 36" wide)
This might be a good excuse to buy a drum sander. (new tool Arrr, Arrr, Arrr.)
Or you could glue up your panels in two separate pieces, plane them with your machine and then glue the two together. That would only leave you one joint to level. Biscuits or a spline will help keep the joint nearly level to make the smoothing easier. A hand plane or even a card scraper will do this job. There are about as many ways to do this as there are people doing it. You can also sand them with a belt sander or a random orbital sander.
As far as wood goes, go to MarketPlace (upper left) and look for Visit WoodFinder. Numerous sources there. If you buy through the Market Place, Wood Central may get a nickle or two in support.
Re: Planing Panels
wood suggestion
Bill Tindall
See if there is a cabinet shop near by. You may be able to convince them to sell you some wood.
Also, most areas have some distributor that runs a truck around the area delivering wood to within a 200 mile radius. Again the cabinet shop would know of such a source. For example, here in NE TN trucks deliver lumber from Chattanooga, TN and Roanoke, VA, each about 200 miles away.
Re: Planing Panels
Re: Planing Panels
Larry in NW Ohio
Welcome to WC and hope you like it here and come back often. Since you did not give us your location it`s kind of hard to give you actual places to go. But if you are anywhere near NW Ohio Frank Miller Lumber will deliver if you buy a certain amount. They are in Union City Ind., they also have a web site. You could also contact Woodmaster Sanders and they will give you addresses of people that have one of their sanders and you could contact them to sand your wood. Good Luck. Larry
Re: Planing Panels
Re: Planing Panels
Prior to my current 20" planer, I used my Dewalt 13" - on occasion I did use panels wider than the Dewalt would handle. I made them then by gluing up narrower panels, planing them to thickness (plane all at the same time so they are exactly the same thickness). Then I glued up the 2 sections as follows, I laid a straight / flat 2" thick board down on my workbench, laid a piece of wax paper on top, added a couple of more 2" boards spaced out so my panels laid flat with the joining area right over the center flat board. Then I dry fitted with my clamps on the top side to be sure I was ready and prepared a clamp or two for the other side. Then you can apply the glue to the joining edges, lightly clamp one end and using a wooden mallet, tap the panel seam flat down on the 2" board, continue to add clamps and tap (sometimes you really have to tap hard) until you have the panel joined as flat as you can with the clamps really tight. Then flip the clamped panel over and add clamps to the other side, making sure you don't have any bow from the clamps. I use Titebond 3 due to the long open time, after the glue has set (45 min to 1 hr.) remove the clamps and scrape off any excess glue. The seam should be flat enough to smooth out with a scraper or orbital sander. Then I trimmed to length and width, and routed the edge of the panel. After final sanding I always do all the finishing on the panel prior to assembly - otherwise you may have light or dark area show when the panels shrink during humidity changes.
Re: Planing Panels
Re: Planing Panels
Bob in NE Ohio
If you are close to NE ohio drop me a note, I would be happy to let you try out my 16/32 sander. It might convince you that you "need" one for your next project.
Bob
Re: Planing Panels
That's Exactly What I Do
Re: Planing Panels
Rick L
Re: A better way...
Rick L
Taking care to glue your panels so you don't need to rethickness is the better approach. I can glue up panels 4' x 8' and all I need to do is remove the mill marks. Technically one only needs a planer as wide as your jointer. Using curved cauls for glue ups insure perfect registration. I finish plane to thickness before I glue up and I'm done. The curved cauls is the key as well as prepping your wood better in the beginning.
Re: Planing Panels
Re: Planing Panels
Joe in a Cleveland suburb
Bob,
Where are you in NE Ohio. I'm near Cleveland (West of).
I am curious where you buy lumber.
Thanks.
Joe
Re: Planing Panels
Re: Planing Panels *LINK*
Bob in NE Ohio
Joe
I am in Hudson, off of route 91 and north of the Turnpike. I used to buy wood from a sawyer in Streetsboro but now I buy from Kiem Lumber in Charm Ohio. They have a great selection and can deliver if it is too much for my truck. Check out their site.
Bob
http://www.keimlumber.com/
Re: Planing Panels
Re: A better way...
FredD
That is the way I do panels and it unfailing gives good results.
In addition I go to considerable lengths to ensure the edges fit tight without any clamp pressure, this pays off off in a better job and less hassle , no gaps etc,
FredD
