Planer
Ray J
Will be buying a planer soon and need to build a stand. What is recommended and convenient for the planer stand height for a bench top type planer? Such as the Delta or Dewalt.
Thanks for your help
Ray
Planer
Ray J
Ray
Re: Planer
Marv Horn
Portable planers have a fixed bed height so you just want to be sure the final bed height on the stand will clear any obstructions ie workbench, tablesaw etc. This also allows obstructions to serve as infeed- outfeed tables and as board storage without constant lifting.
Re: Planer
Dave Bair, Eaton Rapids, MI
I sometimes plane very thick stock and find that a lower stand height helps. A mid-thigh height lets me lift with my legs and a straight back and keeps the back fatigue to a minimum. It also means a lower center of gravity for heavy stock. My stand is wheeled and I don't need to take into account the height of other tools. I can also do long stock by positioning the planer to feed in or out a door.
Re: Planer
JMOHNIKE
I have a roll around cabinet apx 27" high X 48" long. I keep my planer and power miter saw in it. both ends of the cabinet have a support which can be raised for either tool. It is on casters so I can move it outside when needed. I also have outlet boxes on it. Works very well for me.
Joe
Planer height
Bill Tindall
Stand holding a board in a comfortable position. How ever high the board is off the ground that is how high to make the infeed table. You don't want to be stooping nor lifting it any higher than necessary.
Re: Planer height
Larry in NW Ohio
My DeWalt stays on the floor and likes it, so I do not need to lift anything to high up. Matter of fact,all I need do is lift the front end and put the back end on rollers, short, very short rollers. When He`s done I just push him into a hole just for him under the garage cabinents. Works out very well for both of us. Larry
Re: Planer
Steve Strickland
I use one of these (the larger 48" one for $200) from C&H. It's a 1500 pound adjustable height 16 gauge steel table. I don't plane any large or heavy stuff.
Re: Planer
I have a Dewalt, one of the older two knife ones. I put it on a roll around stand I made. Basically a box on wheels. The bed height is about thirty inches off the floor and the stock will go under the table saw wing and under the work bench. (Tiny Violin playing the Small Shop Blues here) That's a very comfortable height for me. (I have a drum sander and set it up much lower so I can store it under the TS wing. The table is about 14" off the floor. It works well enough, but is too low to be comfortable. Too much bending over.)
The best thing I did was make the top of the planer the same height as my Band Saw Table. So I can use it as an in Feed or Out Feed table. This has been a wonderful thing in my shop. Recently set it beside the saw to let me cut some curved ends on pieces. Also means its out of the way when not in use.
