23 gauge nailers
23 gauge nailers
23 gauge nailers
Carol Reed, Strawberry, AZ
Had an HF. Failed in a short time. Not going there again.
Don't need it often, but when you need it, you need it.
Other suggestions, without breaking the bank (too bad!)?
Re: 23 gauge nailers
Dave's Not Here
My experience with the HF pin nailer has been the exact opposite of yours so I really can't recommend any particular one base on experience. I have read some pretty positive reviews about the Ridgid Pin Nailer so you might want to check that one out.
http://www.ridgid.com/Tools/R138HPA-Headless-Pinner/EN/index.htm
William A. Roland
Re: 23 gauge nailers *LINK*
William A. Roland
I have had one of these for a few years and it has worked flawless.
Bynford
Larry in NW Ohio
Carol, what happened to it, can`t be fixed? How long have you had it, can`t take it back? Larry
Had it a couple of years - can't take it back. Didn't use it much. Have had it open a few times. Darned if I can see what the problem is. I have other nailers - 18 gauge - and I have always been able to sort them out. Usually a jammed nail. No this one. Has me flummoxed.
Thanks, Bill. Less money than the Rigid, too. Maybe 'll bite on this one.
Kneale Brownson
Is that an offshoot of Tim Taylor's outfit?
Kneale Brownson
Should be powerful, eh?
Kneale Brownson
^^^^Reply to Bill's post^^^
Joseph Mulherin
Carol, I have two HF nailers and they both still work just fine. You have to lubricate the cylinder with some oil occasionally to make sure it slides properly and the "O" ring is lubricated to seal properly.
While oiling do the nail slides too.
Larry in NW Ohio
What is it doing or not doing, it may just need an O-ring. Larry
Re: Check alignment of nosepiece
Carol, recently I had a bad jam with my HF pinner. I had to remove the front nose-piece to clear the jam. re-assembled the thing and it wouldn't work. It took me a while to find that the channel that guides the pins was not lined up with the nose-piece. The pins stopped just before entering the last 1/8" / 3/16" slotted area at the end - just before they were supposed to be under the driver. Found that by forcing the nose-piece off to one side of the channel that holds the pins when I tightened the bolts, I could get the pins to feed. Took a couple of tries to have them feeding smoothly but works ok now.
Re: 23 gauge nailer surgery
Operating on the premise that I couldn't make things worse, I took the thing apart again.
2 1/2 hours later it appears to be working OK.
There is a sliding slotted piece of metal that adjusts for the length of the nails. It was stuck and poorly made. I filed the slots until it slid smoothly. Then the nose wouldn't line up with the nail barrel. That took some finesse - meaning a small hammer. I could line things up with a clip of nails, but when I tightened all the screws the nails wouldn't slide. Thus the hammer. And Marvel Mystery Oil all over everything. Finicky thing.
Can't say I have confidence in this thing, though. We shall see. Thanks for your help. Your comments gave me some ideas.
