Hang'n Drill Press . . .
steve mackay
Don't have a floor model DP ? Swivil the head out over the edge of the bench and clamp 'er down. Boy-Oh-Boy did THIS save the day !
Re: Hang'n Drill Press . . .
AZ in Colorado Springs
I have a floor model drill press. One day last year I had to cut tenons onto the ends of 4' long 1x2s. The DP was several inches too short to do this. So I went to the AF Academy woodshop and did exactly what you've done!
So, once in a while, even if you have a floor model DP you're out of luck ...
Wondering . . .
steve mackay
Now I'm wondering if I can't put a "plate" on the end of the bench and clamp the DP SIDEWAYS (horizontaly) then clamp the work piece to the bench top. But I guess that sounds like a busted DP and a couple stitches doesn't it ?
Re: Wondering . . .
Robin Corell in Atascadero Ca
I did something very similar to your hozontal idea. I had a recurring job that required drilling a lot of small holes in the ends of long narrow boards. I bought a small bench top drill press and then made a table for it. the sides of the table were 2" thick and also served as legs for it to sit on the bench top. The sides also had holes boared in them for the collumn to fit in and thus was born my horizontal drill press. My needs required 3 different heights so I just used a sub table for each operation I think you could come up with a more usable solution by making the collumn rotate in the table to adjust the height of the hoorizontal drill press, perhaps with an eliptical board pined to the column and another eliptical board pivoted against it. Sorry but I never took any pictures of what I made and I ended up giving it away when I no longer needed it.
Robin
Re: Wondering . . .
Joseph Mulherin
Drilling these small holes could be done on the Shopsmith on the horizontal table bed. I have done it before and it is very easy to setup and accomplish.
I've seen plans for a permanent rig like this
...basically, a sideways table with T-slots and clamps. Can't recall where I saw them, but it wouldn't be hard to figure one out for yourself, if you find this coming up frequently.
Or do it the other way around.
I made a table for my lathe. I put the drill bit in a jacobs chuck in the headstock and set the table up for the correct height and side to side adjustment and then just push the board into the bit. I used to own a shopsmith so it was just a short hop and jump to make me think of doing it in reverse. Drilled holes in the ends of 8 foot boards for that project.
